CEL, traction control, both Vsc lights on
Discussion in '4th Gen 4Runners (2003-2009)' started by RepentOrPerish, Jul 18, 2025 at 3:31 PM.
  1. Jul 18, 2025 at 3:31 PM
    RepentOrPerish
    RepentOrPerish [OP] New Member
    4thGenv8
    Hoping to receive some insight on where to go from here. Originally thought that i overflowed my gas tank and was having some evap canister issue. Or my gas cap was bad(the easy fix i was hoping for)
    Unfortunately after a diagnostic scan I find 4 advanced crankshaft position codes and no evap code. I have P0011 P0016 P0018 and P0021. Internet search has me fearing my timing belt jumped a tooth or two. Just checked and at TDC my pullies are in alignment with the marks on the castings. Whew...
    So where should I go from here? Hate to just wing it and start throwing sensors at this issue.. but maybe thats where I am at :/
    Thanks for any insight.
    Also; Ive tried the battery disconnect and cleared the codes with a scanner and they came right back.
  2. Jul 18, 2025 at 3:33 PM
    RepentOrPerish
    4thGenv8
    I should note that the idle seems higher and i believe i notice a slight decrease in low end power. All these lights came on randomly on my drive home from work.
