Cargo Tray Liner
Discussion in '5th Gen 4Runners (2010-2024)' started by AM330, Oct 23, 2024.
  1. Oct 23, 2024 at 4:32 PM
    AM330
    AM330 [OP] New Member
    Paul
    2022 TRD Pro
    Anyone use the Weathertech trim to fit for the cargo tray? I bought the Toyota OEM one but returned. felt really cheap for $100...
  2. Oct 23, 2024 at 4:54 PM
    Its better than the factory one.
    I usually use Husky because I can Amazon it.
  3. Oct 24, 2024 at 9:53 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
  4. Oct 24, 2024 at 12:50 PM
    UncleShorty
    UncleShorty New Member
    Can't go wrong w/ Husky...
  5. Oct 24, 2024 at 4:40 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    I like my Oedro. Fits well.
    JET4 likes this.
  6. Oct 24, 2024 at 6:38 PM
    Husky has held up well in my use case. If only I had a truck (or friends with trucks) to haul tires and large steel objects...
    [​IMG] AP1GczMXexTlZzXe09zv3onggw8OckgYsAk_8DPG_35fc75cc9900e376706568125f46592b4e3c5afd.jpg
    Mr.DRZ likes this.
  7. Oct 25, 2024 at 5:07 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    I’ve got the Toyota liner and it fits rather loosely and does not cover the area where the rear cargo hooks are located.
    It appears that the Husky liner covers the rear cargo hooks.Does the Husky cargo liner have cutouts for the cargo hooks? Or, is it solid where the cargo hooks are and you cut out if you want to reveal the hooks?
    Cheers,
    Bob
  8. Oct 25, 2024 at 5:21 AM
    Another vote for Oedro
    Rocko9999 likes this.
  9. Oct 25, 2024 at 2:04 PM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    Me three! Wifey bought me one. It's by Oedro. I like it perfectly fine. My T4R as a whole is and will be leading a pampered life- so that Oedro cargo floor mat should last a very long time.
    It does cover the cargo tie-down rings, but as you can see it has marked areas molded right in to the mat at both rear corners showing you where to cut the mat to expose the tie-down rings. I haven’t needed to do that yet, but if it were me, I think I’d try cutting through the semi-circle portion of the “D” shapes on the mat, while leaving the straight edge uncut, creating a sort of “flap”. That way, you could conceivably keep that flap closed when not needing the tie-down rings?
    Or, alternatively, maybe just fold the corners of the mat up out of the way as I’ve done in the one picture, to expose your cargo tie down rings. Later the mat corners should just lay back down in place, with the possible exception of during cold frigid weather. Even then, they will most likely eventually lay back down flat.
  10. Oct 25, 2024 at 2:32 PM
    Looks like the Oedro cargo mat is the same way. Apparently if you want the cargo hooks to be used, you have to cut a hole for those.
  11. Oct 25, 2024 at 5:46 PM
    Nhmountainman
    Nhmountainman New Member
    2024 TRD Pro Terra
    I usually buy weathertec, but bought Husky for all floor coverings. I like Husky better, would buy again.
  12. Oct 25, 2024 at 9:42 PM
    So that's one thing I don't care for on the Husky - how the back edge has a lip that sticks up. That would drive me nuts. Does the Oedro cargo mat have a lip like that, or does it lie flat?
  13. Oct 25, 2024 at 9:50 PM
    Rick G.
    Check out my series of pictures above of my Oedro mat. You may be able to see it does have a bit of a raised lip to it around its outer edges. But perhaps not as much as the Husky.
  14. Oct 25, 2024 at 10:16 PM
    I did see your photos, but couldn't really see a lip, thus my question, but thanks.
  15. Oct 26, 2024 at 4:39 AM
    wingo
    wingo *****
    2020 Venture
    You can cut out the cover over the tie downs.
  16. Oct 26, 2024 at 9:11 AM
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    I like the lip as if something was to spill, it would be contained by the mat.
  17. Oct 26, 2024 at 10:59 AM
    salvojimmy
    salvojimmy New Member
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    My husky is on its 2nd 5th Gen. as are the floor mats
  18. Oct 27, 2024 at 5:41 PM
    Correct, with the Husky, there are molded lines show you where to cut if you want to reveal the hooks.
  19. Oct 28, 2024 at 1:55 PM
    RDCoug
    RDCoug 20 years of modding cars & trucks
    23' Lunar Rock ORP
    I posted about this a while back.....My issue was items sliding around. Also the small pockets of the Lloyd's mat contain any spills.....See Below
