Can’t open trunk - keyless entry
Discussion in '5th Gen 4Runners (2010-2024)' started by TheSponge, Sep 19, 2023.
  1. Sep 19, 2023 at 2:35 PM
    TheSponge
    TheSponge [OP] New Member
    So I removed my garnish to paint it and was sure I plugged everything in before closing the tailgate back down. Well now I can’t open the *astard.
    Is there some sort of trick to open this think? Window down function doesn’t work either so I clearly forgot to plug something in. But what?
    Help, lol. Is there a emergency release somewhere?
  2. Sep 19, 2023 at 2:55 PM
    wingo
    wingo *****
    2020 Venture
    Look on the panel of the hatch for a square cover. Remove it, there should be a manual release in there. At least that is where mine is on my 2020.
  3. Sep 19, 2023 at 3:07 PM
    TheSponge
    Luckily I didn’t reinstall the plastic cover plate.. the 2 plugs I removed I didn’t plug in. Total knob. Anyways all works. Just crawled in through the back and pulled the vapour barrier down and plug it in and voila.
  4. Sep 20, 2023 at 3:33 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Do you have a picture of this? The only square access panel on mine is under the pull strap and that's just basically a bolt cover. I've had the entire panel off several times on projects and I've never seen a manual release, and your post is the first I've seen referencing such a thing. I have a 2019.
  5. Sep 20, 2023 at 4:07 AM
    TheSponge
    This is what I found when I was frantically searching how to open the gate. Did not try it as my plastic piece was off and like I said I just plugged in my connectors and was to open it the proper way without testing the manual release handle as in the below thread. There is apparently a white box that hides the handle.
    MeefZah[QUOTED] likes this.
  6. Sep 20, 2023 at 5:13 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Damn that's good stuff. A little more complicated than just removing a cover but still useful info for sure!
  7. Sep 20, 2023 at 6:04 AM
    Daddykool
    This procedure is for a Gen4. Is the Gen5 similar enough to it?
  8. Sep 20, 2023 at 6:32 AM
    TheSponge
    My '16 Limited had that white box inside the hatch also. I did notice it while I was poking my head around in there and spraying rust inhibitor.
    Daddykool[QUOTED] likes this.
  9. Sep 20, 2023 at 6:40 AM
    wingo
    wingo *****
    2020 Venture
    Here is the page in my manual.
    Daddykool and MeefZah[QUOTED] like this.
  10. Sep 20, 2023 at 7:05 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Interesting, thanks for taking the time to post that.
    wingo[QUOTED] likes this.
  11. Sep 20, 2023 at 10:42 AM
    Interesting! It would be nice to make some sort of extention to that lever. Too bad it seems so buried in there. I wonder if that cover is necessary to protect the latch actuator from the elements (since it’s behind the valor barrier.
