Cali Raised OEM Switches (or others)
Discussion in '5th Gen 4Runners (2010-2024)' started by Metalsaber, Dec 6, 2022.
  1. Dec 6, 2022 at 9:06 AM
    Metalsaber
    Metalsaber [OP] New Member
    So I got my lightbar installed and the Cali Raised OEM switch wired up. The thing I noticed is that the switch sits too far back into the dash and thus doesn't allow the switch to stay on/engaged. I put some electrical tape to get it to sit a little further out and it sort of works. Just wondering if anyone else had a solution to this issue and/or if there were other makes that worked better in the the factory dash slots.
  2. Dec 6, 2022 at 9:24 AM
  3. Dec 6, 2022 at 11:07 AM
    I wonder moving to a different spot in dash would work better. Would you try to move the switch to this location?
  4. Dec 6, 2022 at 5:37 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    Do you plan on other accessories? At some point you might want to check out switchpros or spod or something like that.
    Cheers
  5. Dec 6, 2022 at 6:54 PM
    HankL818
    HankL818 New Member
    2020 ORP w/KDSS
    I had the same exact issue with an OEM style switch (possibly CH4X4) that I ordered with my light bars recently. It just doesn’t sit or operate like the other factory switches.
    Did some research and promptly ordered the AOB version as suggested by the gentleman above.
  6. Dec 7, 2022 at 5:57 AM
    Metalsaber
    I'll give them a shot as well.
  7. Dec 7, 2022 at 5:58 AM
    Metalsaber
    I had only tried the 4 openings down below and none of those positions worked. Didn't try the 2 above as pictured.
  8. Dec 7, 2022 at 7:43 AM
    You better send me a goodie bag if this spot works..:p
    It was an easy spot to turn on an off without looking too.
  9. Dec 7, 2022 at 12:05 PM
    bajadesigns
    bajadesigns New Member
    Hey, if you ever plan on adding any more accessories I would strongly recommend checking out our in-house sister company sPOD. The best alternative option to any AUX switch setup on the market with a fully integrated Canbus system for your accessories for anything with a battery, 12 or 24 volts. They have been the leading Switch module developer since 2005 and always provide satisfaction with their products. Eliminate the rat's nest of wiring with a sleek design that will have just one wire running into your vehicle. The BantamX powers an extensive 100 amps per unit utilizing 8 30 amp switch terminals with the capability to chain in 3 additional units allowing up to 32 fully programmable switches. The Bantam X allows you to switch link which allows you to have a master link that controls multiple switches at a time .
    k_zrDYc-Uf1fnD-yBxspReP_qFefn9C_73FS2uyO_0296eed2033c59162426cdabba220271bad20876.jpg
    sPOD BantamX Touchscreen:https://www.4x4spod.com/bantamx_w_touchscreen_universal
    The BantamX offers two options upon purchase: the touchscreen controller featured in the image above or the HD Smart Panel featured in the image below. Both options will come pre-programmed with the sPOD downloadable phone app allowing you to incorporate a wide variety of features from strobe, dimming, momentary, and switch linking. These features will allow you to have full control via Bluetooth from outside your vehicle whenever desired.
    9kws2mGEhWCPLLAAPqa2-ZuHOXBYF0Mvb8_cf6xg_adde02ba77481e030f56392287d9951097ad58b5.jpg
    sPOD BantamX HD:https://www.4x4spod.com/bantamx_w_hd_universal
  10. Dec 7, 2022 at 6:44 PM
    HankL818
    HankL818 New Member
    2020 ORP w/KDSS
    AOB switch arrived today, 3 days CA to NY via USPS. Installed earlier, and switching action is much better - only requires a light touch for on/off. Where as the other one needed a much firmer tap, also sticks at times.
    AOB’s wiring is a bit different, if you are not familiar with it, I suggest trying the red and green wires’ combo before joining permanently. Their text and symbol can be wired to lit up separately - I only want symbol lit when on. Took me a couple of tries.
    Metalsaber[QUOTED][OP] and Saker like this.
  11. Dec 8, 2022 at 2:26 AM
    All I ever use is AOB Switches. Always worked well!
    :facepalm:
  12. Dec 8, 2022 at 4:11 AM
    Metalsaber
    Thats great to hear!!! Mine are expected to arrive Monday
  13. Dec 8, 2022 at 4:12 AM
    Metalsaber
    I like these products but the price just keeps me away.
  14. Dec 12, 2022 at 10:59 AM
    Metalsaber
    Got my AOB switches today. Got my Roof lightbar one installed and it clicks and works correctly. I just need to rewire it so that part of the light works when the interior lights are on and then fully illuminated while the switch is turned on.
    HankL818 and whippersnapper02 like this.
