Cabin air filter gets dirty very fast
Discussion in '5th Gen 4Runners (2010-2024)' started by 4Runner75, Apr 16, 2024.
  1. Apr 16, 2024 at 7:46 AM
    4Runner75
    4Runner75 [OP] New Member
    2023 4Runner Limited Full Time 4wd
    Hello to all
    I have a 2023 Limited and since I´ve got it I´ve noticed that I have to at least shake the A/C or cabin air filter outside the vehicle because it gets full with dust and leaves. This happens every 3 to 4 months. At 6 months it´s very evident that the filter is way past it´s working life and I replace it. (If it was for the appearance I would replace it every 3 months). I drive relative low mileage, about 1,300 miles every 3 months, but city heavy traffic. The ambient and temperature in my country is tropical: high temps and very humid, but I´ve never had a vehicle that would get the cabin air filter dirty so fast, it usually lasts 1 year or a bit more (on other vehicles).
    Any ideas? something wrong or stuck open? (I always use my a/c in re-circulation mode) so all the debris and leaves got me wondering.
    Before I claim this to the dealer I post it here to see what you guys think, the dealer usually don´t have a clue or a twisted biased theory when I ask anything.
  2. Apr 16, 2024 at 8:14 AM
    I've noticed even though I select re-circulation mode it switches to fresh air as needed.
    I have a feeling all that dirt is coming from the tree you are parking under not from the road. When you start the vehicle all that dirt might be sucked in to the cabin air filter from the top while hvac on fresh air. By the time you press re-circulate it might have sucked all that already.
    Just a thought...
    4Runner75[QUOTED][OP] likes this.
  3. Apr 16, 2024 at 8:15 AM
    4runningMan
    4runningMan New Member
    New Mexico
    Normal. When you shutdown the vehicle the recirculate vent likely opens back up to allow for air exchange from outside. This prevents mold, etc. in humid, warm, wet, cold environments.
    You can change this setting via carista (or at the dealer) to keep it closed when you power off but I wouldn’t recommend.
    4Runner75[OP] likes this.
  4. Apr 16, 2024 at 8:40 AM
    4Runner75
    Interesting, I always try to park in the open and not under a tree. Trees usually drop lots of leaves, some drop little fruits that make me wash the truck to prevent stains and also birds use trees to rest and drop dong. Anyway I´ve notice that even doing that some leaves would enter the cowl and would drop inside the ventilation.
  5. Apr 16, 2024 at 8:45 AM
    4Runner75
    Ok, thanks letting me know how the system works. As you say, I wouldn´t change the setting, doesn´t seem like a wise idea.
  6. Apr 16, 2024 at 9:02 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    The intake leading to the in cabin filter is terrible, i had a whole bunch of snow get jammed down there and destroyed my in cabin filter.
    I think replacing the filter every 6mo is what it states in the manual. Just sounds like you happen to drive through more debris than others may.
  7. Apr 16, 2024 at 9:10 AM
    4Runner75
    Thanks for the info!!
    Will replace it at 6 months
  8. Apr 16, 2024 at 7:59 PM
    i’ve saw a thread on tacoma world where someone removed the cowl trim pieces to mount a screen or prefilter on the intake. Not sure if it’s worth it, but maybe it would be in situations where it can bet packed with snow or debris. That could also help with keeping critters out.
  9. Apr 21, 2024 at 8:30 AM
    4Runner75
    The cowl grill seems pretty sealed up when the hood is closed, I began to wonder how leaves would enter the actual cowl and end up in the filter.
    I can confirm that when the truck is off the opening where the A/C takes fresh air is 100% open and the cabin filter can be seen. Also I just caught a small leaf sneaking in the wiper´s hole in the cowl grill. So that´s the way the leaves are finding it´s way to the filter. Haven´t been able to find the post on the Tacoma Forum, but I get the idea. Is either a mesh or some kind of rubber to narrow the wipers hole, but it could lead to some rubbing and damage of the cowl grill. Or just service the cabin filter every 3 months and replace every 6. Even if I can stop leaves, dust would still find it´s way. I think the best solution is to find the best price of the cabin filter and stock up a few.
    So that you all know the cheaper of them all (cabin filters) is the 87139-YZZ82 which is OEM and made in the USA, not Japan. They run @ $16.50 + shipping. That is a save of almost $5 from the Japanese made.
    McSpazatron likes this.
  10. Apr 21, 2024 at 12:58 PM
    Hey sorry for the slight derailment — does recirculated air go through the filter when the climate control is set to recirculate?
  11. Apr 21, 2024 at 1:46 PM
    4Runner75
    The air should always go through the filter because is right before the blower.
  12. Apr 21, 2024 at 6:51 PM
    4runningMan
    New Mexico
    With the carista app you can change the setting that automatically opens the air vent when you turn off the engine. The setting allows you to keep the vent at whatever it’s at when you shut off the vehicle- open or closed.
    Generally, its good to have it open for air exchange when the engine is off. But if you have rodent problems, you do have an ability to keep it closed.
  13. Apr 22, 2024 at 9:16 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Rinse with hose, air dry, put back.
  14. Apr 22, 2024 at 12:15 PM
    2016Pro
    Or buy a new one for $10
    Ripper238 likes this.
  15. Apr 23, 2024 at 11:10 AM
    Rieby
    Rieby New Member
    2023 TRD Pro Solar Octane
  16. Jan 6, 2025 at 10:56 AM
    4Runner75
    Revisiting this post, I took off the cowl and it had the dirt you would expect with 2 years of use.I cleaned it like new. Also I noticed that the fresh air opening seems like its missing a part, I may be mistaken and it's like that from the factory. If someone can confirm if this is normal, pic attached.
  17. Jan 6, 2025 at 11:03 AM
    Ripper238
    2019 TRD OR
    With the amount of snow i got jammed down to the air filter one time that looks about right.
    But if that's what it looks like i'll be taking off my cowl and making something more protective. That's ridiculous.
  18. Jan 6, 2025 at 11:06 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Anyone know what this setting is called in the Carista app? I may have changed it inadvertently if its called "AC Eco mode"
    oops
  19. Jan 6, 2025 at 3:51 PM
    4Runner75
    It seems it´s like that from the factory, I´m searching if maybe there´s another model that Toyota actually put a part there. It's a longshot and I think I would need to get creative and put some sort of cover or filter.
  20. Jan 6, 2025 at 4:15 PM
    The protective cover is your cowl...
    There are people who developed a mod to take your money: https://www.tacomaworld.com/threads/for-sale-cowl-intake-snorkel-kits-and-hvac-screens.811746/ or you can put some bulk wire mesh material there. However, that just causes the leaves to collect on the mesh instead of the air filter.
    Better to put a deflector over the intake, so air has to take a less direct path into the opening, without any tendency to trap leaves:
  21. Jan 6, 2025 at 4:34 PM
    4runningMan
    New Mexico
    Eco Mode is something else I think. Best I could tell from some internet sleuthing, eco mode cuts/lessens power to some things like heater/AC and heated seats when idling at a stop. So as to save on gas. But I haven't confirmed this.
    1SilverRunner likes this.
  22. Jan 6, 2025 at 9:49 PM
    1SilverRunner
    Tejas
    Well that’s good. I just remember seeing that “AC Eco mode” was enabled and I thought
  23. Jan 7, 2025 at 6:54 AM
    4Runner75
    Thanks, it gives me a very good idea of what to put there.
  24. Jan 7, 2025 at 7:03 AM
    Is that deflector on your 4R, or a photo you found?
  25. Jan 7, 2025 at 8:31 AM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    I always thought ECO mode uses engine geat for heating, non eco heats up a filament of smth. Dont remember having ECO mode on my '23 ORP tho. My '08 Camry Hybrid has it.
  26. Jan 7, 2025 at 10:11 AM
    It's a photo I found on Tacoma World. The cowl inlet stamping is similar if not identical, also with unused holes on the flange.
    eurowner likes this.
  27. Jan 7, 2025 at 11:12 AM
    4runningMan
    New Mexico
    Yeah I don't know for sure. Best I can tell, it cuts power to some systems to reduce load on alternator, thus saving gas. You know when you're stopped and you feel the engine surge a little to keep up with the AC? I suspect ECO stops that from happening. And as a result, you don't get as cold of air until you start moving again.
  28. Jan 7, 2025 at 11:34 AM
    West Coast, Sierra Mountains
    I think I see my next project…up in the mountains it’s getting tiresome to have to tap out the filter in my rig every two weeks, replacing every month in the late summer-fall.
  29. Jan 7, 2025 at 1:25 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    A filter, catching debris ? What the hell is goin on in this world.
  30. Jan 7, 2025 at 3:19 PM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    Looks like a good fix! I have some nice thin aliminum sheet from home depot. Going to make something like that when I have some free time in my hands. Stay tuned!
