C4 Lo Pro Install with TRD Skid
Discussion in 'General 4Runner Talk' started by Mr. Snuffleupagus, Dec 9, 2022.
  1. Dec 9, 2022 at 8:12 PM
    Mr. Snuffleupagus
    Mr. Snuffleupagus [OP] Light Runner
    Brandt
    2022 TRD Pro
    Elka 2.5 DC, Sherpa Crestone, C4 Lo Pro, Baja Designs S8, Morimoto 4bangers, Switch Pro 9100, Westcott Designs sliders, Toyo Open Country RT Trail 285 75/R17
    Looking for advice from anyone who has installed a C4 Lo Pro with factory TRD skid plate. Did you need to remove the plate during the lo pro install or were you able to leave it in place? Based on the C4 video the bumper needs to tightened in its highest position to accommodate the skid and the bumper itself has flange on the bottom. It's unclear in the flange sits behind or in front of the skid. Im sure this will be clear during the installation but always easiest to know what needs to be taken off in advance. Appreciate any advice.
  2. Dec 10, 2022 at 10:54 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    The c4 doesn’t interfere with the pro skid unless something has changed between the 2019.
  3. Dec 11, 2022 at 8:13 AM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    Thanks @Jynarik i know the skid won’t interfere with the Lo Pro I was just curious if the skid needed to come off for ease of install. Appreciate your help!
  4. Dec 11, 2022 at 4:21 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    oh, yes it will. The lip of the skid sits over it
  5. Aug 25, 2023 at 9:39 AM
    xrptrdpro
    xrptrdpro New Member
    2021 4Runner TRD Pro
    Yes. Good call, I never noticed the contact until the coating wore off and I get creaking in the front end. See pics for reference.
    I'd think a solution will be to cut back.the skid or get a longer bolt spacer pair. Should only need to make a 1/4 gap. Will be my next project. This is a 2021 trd pro, for reference.
  6. Aug 25, 2023 at 11:10 AM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    Interesting and it maybe the height I have mine mounted but my Lo Pro does not touch my skid. I have a small gap between the two. I did mount the Lo Pro as high as I possibly could give the flexibility of the mounting holes.
  7. Aug 25, 2023 at 11:47 AM
    xrptrdpro
    I went back through my install steps and determined it has to be at the highest mounting point with trd pro skid plate.
    Wasn't easy installing myself but I'll use a floor jack to boost it up. This appears to be a non issue so take my prior post as simply my experience. Hope it helps anyone in need
