C4 Fab diff skid install
Discussion in 'Suspension' started by MyWyfsRnnr, Mar 28, 2019.
  1. Mar 28, 2019 at 6:16 AM
    MyWyfsRnnr
    MyWyfsRnnr [OP] Have you seen the mall?
    Chris
    Citrus Heights
    2018 4Runner TRD
    Last night I installed my new C4 Fab diff skid and ran into some things that will help the next person. I decided on the C4 skid because it goes the furthest forward from the others I have seen. I like protecting the yoke and driveline joint here.front.jpg
    The C4 Fab skid does not come with instructions, it just has a strip of paper that says to visit their website, which also did not have anything on it for the diff skid. It is only 6 bolts so it is pretty easy to figure out but there are a couple tricks. FIRST and foremost, grab 2 beers and open one or both. Second, you need to install the E-Locker motor plate shown here prior to mounting the skid on the KDSS Bar bolts if you purchased this option. This plate is next to impossible to install once the skid is bolted in place.
    Next, remove the nuts from the KDSS Sway bar (19mm). You will also have to back the driver side bolt out about 1/2" to get the skid tab to slide onto the bolt on that side. Slide the plate onto the bolts and loosely reinstall the nuts, this allows the plate to pivot upwards on the bolts without slipping off and cracking you in the dome.
    Lastly, pivot the plate up on the rear bolts and install the top ring over the front of the diff and lock it down tight. It is a TIGHT fit so some small hands and creative angles will be required.
    Hopefully if you get one of these this will turn your install into a 10 min project and avoid a little of the off and on again ended up doing.
  2. Apr 2, 2019 at 6:03 PM
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    Thanks for the how to and pics. It's on my to buy list since I do some rock crawling with some friends :thumbsup:
    WallyT4R and MyWyfsRnnr[OP] like this.
  3. Apr 2, 2019 at 7:46 PM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    I am pretty happy with it and it seems to offer more protection than others I found on the market. I will report back after I've mangled it up a bit haha! It protects the drain plug without hanging down to far.
    Doglover2003 likes this.
  4. Apr 4, 2019 at 11:48 AM
    Doglover2003
    '18 ORP w/KDSS
    I'm glad there's a option for us KDSS guys, other brands don't offer a KDSS version.
  5. Apr 4, 2019 at 2:00 PM
    MattMo
    MattMo Life's too short not to!!
    Matt
    Nor Cal
    2019 TRD ORP KDSS Magnetic Gray
    TRD Cold Air intake system Pro-Comp Vertigo with BFG LT285/70R17 KO2 ICON 0-3.5" Suspension System - Stage 2 (Tubular) ICON Rear shock shin guards ICON Adjustable track bar RSG METALWORKS Angled sliders with a kick RSG METALWORKS KDSS Skid plate Metal Tech Rear Bump Stop Drops RAD RUBBER DESIGN Nitrile Rubber Engine SPLASH GUARDS Body Armor BackBone Hitch Skid AVS Hood and Window vents Front windows and Moon Roof Tinted Pedal Commander Wet Okole seat covers LED lights in and out RAGO Modular Storage Panel System Driver and Passenger RAGO Low Profile ditch light brackets with Baja Designs Squadron Sport Driving/ Combo LED Lights RAGO Ditch Bracket Antenna Extension for the Go Pro RAGO Antenna Mount - Stainless Steel Secondary Air Pump replaced the foam to a Uni Filter UP-107 1” clamp-on breather. Fog Lights changed to Xenon Depot Xtreme LED Pro H16 Yellow Bulbs Lamin-X protective film in Yellow C4 Fabrication Rear Diff Skid Plate Lamin-X door cup clear scratch protectors Diode Dynamics Tail as Turn Kit (Tail as Turn™ Module +Backup Module) with XP80 LED Cool White for old turn signals GOBI ladder Overland Equipped Bolt-On Steps RotopaX Ladder Mount Brackets for RotopaX Fuel cans SDHQ ABS Speed Sensor Guards Smittybilt Element Ramps ArcLight LEDs Icarus Hatch Lights eXtreme ARTEC INDUSTRIES Toyota 5G Venture Roof Cross Bars Silver Wing Clam Shell Rooftop Tent Anytime Backup and Front Camera Full Kit (Camera and Switch) ARB Differential Breather Kit Diaz Fabrication Devil Horns clear anodize Pro-Comp LED Rock Lights ARTEC INDUSTRIES 5G Venture bumper with Smittybuilt winch ABB 2500 awning GOBI Stealth full w/moon roof (ARB and Shovel Axe mounts) On order:
  6. Apr 4, 2019 at 2:04 PM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Yeah, Those would have saved me one off and on haha! Thanks for posting them for everyone! I just went on their site and found the directions, I missed them because they were under the '10+ (5th gen) not the '14+ (5th gen).
