Busted Nut Plate inside Frame
Discussion in '5th Gen 4Runners (2010-2024)' started by Porch Dawg, Aug 7, 2024.
  1. Aug 7, 2024 at 1:05 PM
    Porch Dawg
    Porch Dawg [OP] New Member
    2017 4 Runner Limited
    None, yet
    I was attempting to remove my front sway bar. I was removing the front bolts and they got bound up so I sprayed them with PB Blaster then started working the riverside bolt in and out. As I was running the bolt out it got tight and when I applied pressure it broke. The bolt was flopping around and stuck to the nut plate in the frame.
    What are my options, besides trading my 4runner in for another one
    UPDATE: I found a custom auto shop close to where I'm at, like 3 miles from me. I talked to the guy and figured if they can do all the custom work they have on display my little mess up should be easy. I have an appointment to drop it off this Tuesday. They are also going to finish the install on my recovery points. I have no doubt it's going to cost me some $$$. I will update this when I get the 4runner back.
    Harringbr99 and djwantke like this.
  2. Aug 7, 2024 at 1:23 PM
    Can you see any access available to the back side of the frame there, as in a nearby hole? One option is a captive nut - a nut with a piece of steel welded to it that you can fish in there to thread the bolt into when you replace it...if you can fish the captive nut in, you could also probably fish out the broken piece with a retractable magnet.
    Another option is a rivnut.
    djwantke likes this.
  3. Aug 7, 2024 at 1:44 PM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    I hate it when I bust a nut....:amen:
    Is it broke off flush? If it is maybe you can drill it out and re thread hole? Maybe go up a size? Helicoil?
  4. Aug 7, 2024 at 2:28 PM
    So the bolt is still there and just spins with the nut in the frame? If you have access, cut the bolt with a sawzall. If there's no saw blade access, take it to a shop and liquify it with a torch. There are some larger holes nearby, covered with plastic plugs, that'll let you fish out the remains with a stick magnet.
  5. Aug 7, 2024 at 2:41 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Ya’ll are giving some great advice, I can’t help OP much but I’m watching this thread.
    I think I used a captive nut (attached to a metal wire) style solution in order to fasten my KDSS Apex Recovery Points to the front end frame rails?
    GOODLUCK @Porch Dawg
  6. Aug 7, 2024 at 2:44 PM
    Shrockworks, which no longer exists, used to provide what they called 'stick nuts', which you fished into the frame to use on a couple of their slider mounting points, AND you needed to drill holes to use them. Which seemed totally inappropriate, as the 4R frame has way more than enough pre-threaded mounting holes already.
    djwantke and TrailSpecial22 like this.
  7. Aug 7, 2024 at 3:10 PM
    Porch Dawg
    None, yet
    Someone mentioned installing the APEX recovery points, that's exactly what I was attempting to do when this started! Grrrr!
    There is a plastic plug on the frame very close to where the broken nut plate is.
    And yes, the bolt is still stuck in the nut plate and spinning around in the frame.
  8. Aug 7, 2024 at 3:14 PM
    Why the removal?
  9. Aug 7, 2024 at 3:15 PM
    Porch Dawg
    None, yet
    I was installing my recovery points. To do the install you have to remove the bolts that hold the sway bar in place.
  10. Aug 7, 2024 at 4:07 PM
    Damn recovery points!
    My 4R has KDSS as opposed to XREAS (I think you have a Limited)
    I didn’t have to touch the sway bar. But, I did have to drill out the frame, one hole per side :eek:
  11. Aug 7, 2024 at 4:11 PM
    Porch Dawg
    None, yet
    Yes, you are correct mine is a Limited.
  12. Aug 7, 2024 at 4:14 PM
    I see, indeed.
    I had to remove the front bumper cover and crash bar to access the hole for the nut on a wire. Luckily, I’ve experienced taking my bumpers off before so it wasn’t bad.
    Goodluck sir
  13. Aug 7, 2024 at 4:14 PM
    Higgbra73
    Higgbra73 Nitrous Fixes Everything
    Brad
    Chicago
    16' SR5 Premium 4WD
    Voxx "PRO's" Bronze (17x8.5) wrapped in 285/70-17 Mickey Thompson Baja Boss A/T's, 5100's with Dobinsons C59-302 2.5" front coils and Ironman 1.5" Light Load rear coils. RCI Engine Skid plate. CAT Shield SS. Freedom Offroad UCA's. 14" Borla Pro XS Muffler (40358)
    This happened to me when changing bushings… I just used a magnet and dropped bolt down thru the frame and nut from the bottom..:
  14. Aug 7, 2024 at 4:15 PM
    Explain more plz
  15. Aug 7, 2024 at 4:22 PM
    Porch Dawg
    None, yet
    Talking to the shop that's going to do the repair, I think they are going to use a locking nut and a bolt, IF they can't weld another nut inside the frame.
    Harringbr99 likes this.
  16. Aug 7, 2024 at 4:24 PM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    1. Saw or cut disk off broken “spinning nut”,
    2. Fish out remainder of broken bold from hole in frame with a flex magnet
    3. Purchase new bolt from dealer $2.43
    4. Ace had a nut that worked. $.52
    5. Use Flex magnet to drop in bolt from top
    6. Start nut, this is where it gets a bit trick… get nut above the bottom of bolt enough to grab it with some plyers… once snug… use impact to tighten.. . I’m not home to take a pic… but super easy.
  17. Aug 8, 2024 at 11:10 AM
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Notice the diff?
    Porch Dawg[OP] likes this.
  18. Aug 12, 2024 at 9:57 AM
    Harringbr99
    Harringbr99 New Member
    Brian
    Kentucky
    2021 Barcelona Red Limited
    I think your shop has the right plan. I think there's about a 90% chance they will be installing a rivnut in place of that captive nut with the busted welds.
    I've had this same problem with the threaded captive nuts for the skid plates. I've broken the welds off of 4 of them and had to replace each of them with a rivnut.
    I have a few "out of the box" options for you OP. (These are ideas i've been toying with, I too have a Limited that I wheel often)
    1. Take out the swaybar and never look back. Enjoy all the flex that comes from living without the swaybar! Saves all the effort of trying to put it back.)
    2. Get the Apex Designs Kwiklynx swaybar disconnect: https://www.apexdesignsusa.com/products/kwiklynx -- Since you will move the swaybar forward and drill new rivnut/nutsert holes you won't have to worry about those old bolt holes and that old captive nut ever again. And you also get a disconnecting swaybar. If you're gonna mod, go hard or go home. :D:yes::spending:
    Porch Dawg[OP] and ChessGuy like this.
  19. Aug 12, 2024 at 12:42 PM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    How did you break all 4 ? Was is from corrosion ?
  20. Aug 12, 2024 at 1:32 PM
    Harringbr99
    Brian
    Kentucky
    Not from corrosion, the welds are just so tiny. The first nut came when the shop was doing an oil change and after a particularly hard hit to the skid, they said the nut/bolt were just spinning when they tried to change the oil.
    The remaining three came from another time when I was trying to swap the skids. they never seem to break on the way in, it was when loosening the bolts.
    Here is link to the picture of the welded nuts. let me know if it doesn't take you to the image:
    https://www.4runners.com/posts/565140/
