Broke a bolt :(
Discussion in '4th Gen 4Runners (2003-2009)' started by TN_FunRunner, May 3, 2022.
  1. May 3, 2022 at 4:46 PM
    TN_FunRunner
    TN_FunRunner [OP] New Member
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    I was replacing the front sway bar bushings this weekend and broke the head off one of the bolts. Went to Toyota and ordered the new one but has anyone had any luck getting a broken bolt out of the frame. It’s a clean break - pretty even with the surface.
  2. May 3, 2022 at 5:18 PM
    08tnt
    08tnt New Member
    Toby
    Do you have a welder? Can you drill a hole in it and try an easy out? Also may can cut a slot in the shank and use a screw driver. A torch may help as heat will be your friend.
    TN_FunRunner[OP] likes this.
  3. May 3, 2022 at 5:21 PM
    TN_FunRunner
    Jay
    W. TN
    I don’t have a welder but just bought an easy out so will be trying that out. I wish I had a welder because that would make this a easy job.
  4. May 3, 2022 at 5:25 PM
    08tnt
    08tnt New Member
    Toby
    A torch may help. Heat it as hot as you can.
  5. May 3, 2022 at 7:11 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    There's a couple ways to remove and broken bolt.... first spray it with wd40(a couple times). Center punch the bolt(as close to center as possible), smack it a couple times, uses heat(propane torch), weld a nut to the broken bolt, what kind of tools ya got?
    Edit only read the first post, sounds like ya know what you gotta do
  6. May 3, 2022 at 7:13 PM
    TN_FunRunner
    Jay
    W. TN
    I got just about everything except a welder. Just never had this happen before
  7. May 3, 2022 at 7:16 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You can try center punching it in a rotation.. try that with some heat, then try the easy outs, they are nice IF they work. if not you got a even bigger mess
    Scoobyvroom likes this.
  8. May 3, 2022 at 7:17 PM
    TN_FunRunner
    Jay
    W. TN
    That’s what I was afraid of. I appreciate all the help. I will let y’all know how it goes.
  9. May 4, 2022 at 8:53 AM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    I'd be careful whacking it you can jack up the threads. Left handed drill but may be helpful. I've used them to extract broken bolts. I'd let it soak in some sort of lubricant and start with an easy out.
    2Toys and LandCruiser like this.
  10. May 4, 2022 at 10:51 AM
    beedee
    beedee Member
    I had a broken bolt where the head broke off flush where the rear bumper attaches, just beneath the lift gate on my 5th gen. I bought a set of left-handed drill bits and that did the trick. Sprayed some PB Blaster prior to going to work on it.
  11. May 5, 2022 at 6:17 PM
    TN_FunRunner
    Jay
    W. TN
    I got it out. Sprayed it down with some lubricant and started drilling on it and it started turning- got it to where I could get my fingers on it and backed her out.
    Thanks all.
    4-Funner, AuSeeker, trlhiker and 4 others like this.
