brake shake
Discussion in '5th Gen 4Runners (2010-2024)' started by s&sguy, Jun 27, 2025 at 9:07 AM.
  1. Jun 27, 2025 at 9:07 AM
    s&sguy
    s&sguy [OP] New Member
    Yesterday
    2015 2wd has brake shake and some shake in the strg wheel in normal driving
  2. Jun 27, 2025 at 9:21 AM
    jgalt
    jgalt New Member
    Wheel bearing or suspension worn out?
  3. Jun 27, 2025 at 9:27 AM
    Tonnnks
    Tonnnks New Member
    Also have this...thought it was tires, Got new tires and still happens every now & then. Seems to be when braking above 50-60 mph 80% of time
  4. Jun 27, 2025 at 9:28 AM
    @Tonnnks,
    When was the last time you inspected brake pads and rotors?
    How many miles since changed and how hard are you on braking?
  5. Jun 27, 2025 at 10:13 AM
    welcome, check your brake pads and rotors
  6. Jun 27, 2025 at 10:41 AM
    rotors and pads. USUALLY that is a sign of warped rotors.
  7. Jun 27, 2025 at 11:30 AM
    Tonnnks
    Tonnnks New Member
    No hard braking, however the brakes are rotors are original and I am at 80k.
    Sounds like its time to replace the brakes and rotors.
    Thanks
    Saker[QUOTED] likes this.
  8. Jun 27, 2025 at 12:18 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Steering wheel shake can be caused by tire balance. If your tires are AT or chunky balance at least every other rotation. I bought lifetime rotation and balance when I upgrades to AT from the All Season stockers. I do my oil change and tire rotation in same week.
  9. Jun 27, 2025 at 1:15 PM
  10. Jun 27, 2025 at 2:04 PM
    s&sguy
    Yesterday
    have two vechiles doing the same thing.they have good michelin tires and had the rotors turned in the past year.neither driver is hard on the brakes.maybe the rotors just are not good on these models.but there is still some steering wheel shimmy at times without brakeing.
  11. Jun 27, 2025 at 5:38 PM
    Rotors and/or brake pad issue. How many miles on them?
  12. Jun 27, 2025 at 5:39 PM
    time to change
