Brake line ruptured
Discussion in '4th Gen 4Runners (2003-2009)' started by dvto2, Sep 8, 2020.
  1. Sep 8, 2020 at 4:10 PM
    dvto2
    dvto2 [OP] New Member
    2005 4runner Sport V6 4.0
    2005 4runner Sport, 265000 K. One of my brake lines ruptured today, as I was driving to get parts on my Tacoma. It's right behind the gas tank and has a right angle to get over the gas tank. Can I get a prebent piece? Anyone know how hard it is to get around the tank? It's the one on the right.
  2. Oct 10, 2020 at 1:30 PM
    dvto2
    I did buy new flex lines for this job, but the old lines are so caroded that I can't see how to take them out.
  3. Oct 23, 2020 at 7:49 PM
    WarChild
    WarChild New Member
    2005 JRU 4Runner
    If I remember right there use to be a slide clip holding them in place
  4. Oct 25, 2020 at 10:40 PM
    4R777
    4R777 New Member
  5. Oct 26, 2020 at 4:27 AM
    dvto2
    Thanks. I spent the weekend drilling out the gas tank strap bolt that snapped off. I tried grinding the bolt flat, starting with a smaller bit, but still ended up drilling off center so that I then had to cut off the rest of the bolt and welded nut. I always have a hard time drilling a perfect center on a busted bolt.
    It's an awkward place to cut but I was able to get an oscillating multi tool blade in there and cut it off so I a flat place for a nut. Im such a slow mechanic. I can finally get back to the brake lines.
  6. Oct 27, 2020 at 2:05 PM
    dvto2
    So, I cannot just replace my ruptured middle lines because the rear lines are looking awful. The flexible hose is none too pretty either. However, I cannot get the rear brake lines out of the flexible hose and I cannot get the flexible hose out of the top brackets. The bottom brackets have visible clips, the tops do not appear to have clips. I tried taking the top bracket completely off, but I rounded that bolt very nicely.
    I would prefer to get the tops of the flexible hose out somehow so I could neatly replace the flexible hose cause I don't think I can get the rear brake lines out without tearing things up. Alternatively, I could just zip tie or otherwise attach my new parts to existing parts. The pictures are my ugly rear brake lines with the clips on the flex line showing, the tops of other end of the flex hose, and the bottoms of the other end of flex hose.
