Brake Failure
Discussion in '5th Gen 4Runners (2010-2024)' started by 4Runnnnner, Jun 6, 2019.
  1. Jun 6, 2019 at 6:56 AM
    4Runnnnner
    4Runnnnner [OP] New Member
    2016 Pearl 4Runner
    Hey this is for the 4runner Nerd. Brake pedal went to the floor at a 25 mile an hour stop.
    Reapplied brake pedal by returning to normal brake position, reapplied brakes and the problem went away. Has this happened to anyone with 2016 4runner Limited?
  2. Jun 6, 2019 at 9:22 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    WTF?? I'd get that checked professionally now... Don't want that happening at a school crosswalk.
    scottalot and Bob like this.
  3. Jun 6, 2019 at 1:18 PM
    poncho65
    poncho65 New Member
    New England
    I know of a least 2 other 4Runner owners that have experienced similar issues on another forum....definitely make an appointment with your dealer to get the brakes checked and the issue logged in their system.
    LandCruiser and Bob like this.
  4. Jun 6, 2019 at 2:42 PM
    Charlievee
    Charlievee Not new member.
    But Toyota's don't break!
    java likes this.
  5. Jun 10, 2019 at 10:18 AM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    2017 T4R Pro 040
    Is plasti-dip a mod?!
    Sounds like a failing master cylinder. Get that sucker to the dealer immediately!! Brakes are a huge safety issue!!
  6. Feb 4, 2022 at 2:46 PM
    Crumpledbumper
    Crumpledbumper New Member
    Crushed the bumper real nice
    Had that happen in my 2014 limited earlier this week. It was -9f on a dry road that had been salted earlier that morning. Went to stop in a 25mph and the brakes did literally nothing. I had ample stopping distance and plenty of traction but when I pressed the brake pedal down it didn’t slow the car, no ABS kicked in, no dash lights flashed or came on after and the brakes started working again after the collision. The shop I usually take our vehicles to said they inspected it and couldn’t find anything wrong with it. It also seemed like they spent less than an hour checking it out (including the test drive). So idk how valuable their input is. I’m going to have it inspected by our local Toyota dealership when they have availability but the whole ordeal is very unsettling. Like DGP1961 said, don’t want that happening at cross walks.
  7. Feb 4, 2022 at 3:55 PM
    Says who?
  8. Feb 4, 2022 at 4:14 PM
    DogoPilot
    DogoPilot New Member
    St. Paul, MN
    2022 Black ORP w/KDSS
    I think you mean brake.
  9. Feb 6, 2022 at 4:14 AM
    ecoterragaia
    ecoterragaia New Member
    Central Virginia
    2021 SR5 4WD
    :eek:
    That sucks man, hope everyone was okay.
  10. Feb 6, 2022 at 8:19 AM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    There are so many variables to any braking system. Add ABS and its even bigger. If your pedal went to the floor, you have air in your system and more than likely is rapped in the ABS module, which means a brake lines, seal in the MC, or seal in one of the calipers has failed. You may not see fluid on the wheel or ground because it is only happening when you you let off the pedal, as it has no pressure, but it is allowing air to enter the system via the faulty seal.
    How many miles on your rig?
    Have you had the brake pads, rotors replaced or pads replaced but rotors turned?
    Here is a video showing how a vacuum brake bleed is performed to ensure no air is in your braking system.
    https://www.youtube.com/watch?v=kFQHy2WCDC8
  11. Apr 16, 2024 at 6:25 PM
    TheMrs_S
    TheMrs_S New Member
    Reshell
    2015 4Runner Limited
    I just got my 2015 Limited back from the Toyota dealer. I had it towed there after Les Schwab left it undrivable. Toyota dealership said that the cause of the problem was a bad bleed job that left the actuator without fluid. Problem is, I feel like they are too soft still. The guys at the dealership said that it drives as it's supposed to.
  12. Apr 16, 2024 at 6:53 PM
    If they feel softer than they did before the problem, take it back and tell them they didn’t bleed them enough.
    However, a while back I heard of a weird but possible reason for losing brakes or soft brakes. Which was loose wheel lug nuts. The loose wheel allowed the rotors to move slightly, which probably pushed the caliper piston into the caliper. That extra distance the piston had to travel on the next application can possibly lead to soft or no response. Worth checking that they tightened it.
    2Toys likes this.
