Brake Failure in Reverse
Discussion in 'Wheels & Tires' started by 4Runnerforever, Sep 6, 2025 at 5:16 PM.
  1. Sep 6, 2025 at 5:16 PM
    4Runnerforever
    4Runnerforever [OP] New Member
    Saturday
    2018 4Runner Premium
    Railings for roof rack
    Anyone experienced brake failure. In reverse immediately after starting? 5th generation -2018 Premium
  2. Sep 6, 2025 at 6:27 PM
    not me on 2011 or 2022
  3. Sep 6, 2025 at 6:31 PM
    Check for leaks, you may have a vacuum leak.
  4. Sep 6, 2025 at 6:48 PM
    Need more details on the failure:
    Pedal goes to the floor?
    Pedal solid but no stopping action?
    Brakes locked up?
  5. Sep 6, 2025 at 6:50 PM
    Did you consult ChatGPT again? :p AI doesn't know all 5th gens have an electronic booster.
    AuSeeker likes this.
  6. Sep 6, 2025 at 6:56 PM
    Nah, not this time! I'm old school and my mind went to cars designed in the 80's. Plus I had just finished vacuuming my house when I read this, so it was fresh on my brain.
  7. Sep 8, 2025 at 9:31 AM
    4Runnerforever
    Saturday
    The brake pedal did not go all the way to the floor but certainly went farther than normal without proper stopping action.
  8. Sep 8, 2025 at 10:33 AM
    ^Is the behavior repeatable? Does it happen driving forward?
  9. Sep 8, 2025 at 5:12 PM
    4Runnerforever
    Saturday
    The behavior did repeat when I placed it in drive. Going up a slight hill to my garage I had to shift to park to stop it. After shutting it down and waiting for a little while I slowly moved it back in the garage and felt the brake engage. I have not attempted to drive on the street since and will probably not until I get it checked out. The master cylinder has adequate fluid.
  10. Sep 8, 2025 at 6:20 PM
    ^Yeah will probably need a tow. Could be gross amount of air in the system or failed master cylinder seals. The latter has not been reported systemically on 5th gen 4Runners, but has been the subject of TSBs and recalls on other Toyota models. When was the last time your brake fluid was replaced?
