Bottomed out on front timbren bump stops
Discussion in '5th Gen 4Runners (2010-2024)' started by Thacrow, Aug 17, 2022.
  1. Aug 17, 2022 at 11:38 PM
    Thacrow
    Thacrow [OP] New Member
    2021 ORP
    Speed holes
    Bottomed out in the front on tmbtens. Tire scraped the wheel well pretty good. Granted I was doing about 50 mph on a dirt power line road which took a sudden, unexpected hard dip but I'd prefer that don't happen.
    Any extended options or anyone put a spacer between the bump stop and the truck?
  2. Aug 18, 2022 at 2:37 AM
    Agent_Outside
    Built 2011 T4R Limited
    Durobumps
    Thacrow[OP] and SlvrSlug like this.
  3. Aug 18, 2022 at 11:13 AM
    Thacrow
    2021 ORP
    Speed holes
    Sweet thanks! - saw those before starting this thread. Look less expensive than the Timbren. Wish maybe I did more research than I did ad saved some money and time.
    Ordered
  4. Aug 18, 2022 at 11:26 AM
    What’s wrong with the OEM bump stops?
  5. Aug 18, 2022 at 11:41 AM
    Thacrow
    2021 ORP
    Speed holes
    Bigger tires hit the wheel well so need taller bump stops.
    If you're using ready lift spacers as i see in your profile you may have less of an issue with this than if you did a suspension lift. - unless I'm mistaken on my understanding of suspension.
  6. Aug 18, 2022 at 12:36 PM
    I see, yes extended bumps may be necessary.
    Regarding my Readylift, I had it removed a couple of weeks ago and put 265’s back on. It was a mistake on my part.
    I should probably update my profile. Thanks for the reminder. ;)
    Updated profile to remove Readylift and 285’s. :)
  7. Aug 18, 2022 at 1:05 PM
    Thacrow
    2021 ORP
    Speed holes
    Sorry to hear about the Readylift. Hopefully the durobumps work well. Lot of people seem to have them and like them. Probably wont be in a position to test them for a while.
  8. Aug 18, 2022 at 5:34 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    FYI… below is from durostop. idk what model you got but this is the only one that I found for our trim in the front:
    The DBF212 will not limit your wheel-up travel.
  9. Aug 18, 2022 at 7:09 PM
    Thacrow
    2021 ORP
    Speed holes
    i guess if the wheel travels too far up after the duro's maybe i can remove the wheel
    n8th8n likes this.
  10. Aug 18, 2022 at 7:22 PM
    GrantA
    North Carolina
    :rofl:
    Thacrow[QUOTED][OP] likes this.
  11. Feb 9, 2024 at 9:35 PM
    n8th8n
    n8th8n New Member
    5th Gen 4Runner
    Mid Travel with King Shocks and Dirt King Uppers
    Hello! I am having the same exact issue as you on my 5th gen 4runner and am currently looking for extended front bump stops. Did you go with the durobumps on your 4runner? Were you able to fix limiting the up travel? Thank you!
  12. Feb 9, 2024 at 10:07 PM
    Thacrow
    2021 ORP
    Speed holes
    Ya know I never got around to swapping those out. Still in a box somewhere.
    But I also haven't done 55-60 mph down a dirt road with a sudden significant dip to test it anyhow.
