Body mount clearance
Discussion in '5th Gen 4Runners (2010-2024)' started by Goose Goose, Oct 30, 2024.
  1. Oct 30, 2024 at 3:23 PM
    Goose Goose
    Goose Goose [OP] New Member
    2024 Toyota 4Runner TRD ORP
    Dobinsons IMS, RRW
    Hello all, can anyone tell me if a finger width space is enough for clearance from fully locked tire to body mount? Or am I playing with fire? Here are some pics of my clearance, driver side and passenger side. Thanks
  2. Oct 30, 2024 at 5:08 PM
    Looks good to me. What size tires?
  3. Oct 30, 2024 at 5:51 PM
    Goose Goose
    Dobinsons IMS, RRW
    @TrailSpecial22 I'm runnin 285/70/17 with approximately 2” front lift and dobinsons UCA’s.
    raimieb and TrailSpecial22 like this.
  4. Oct 30, 2024 at 6:04 PM
    i’m running 285s as well, but with stock upper control arms and a 2 inch lift from Bilstein and my clearance is like yours and no issues. I’ll try to get a picture of mine in the morning
  5. Oct 30, 2024 at 6:18 PM
    White TuRD
    White TuRD New Member
    SC
    2021 TRD ORP
    How much caster angle are you getting with that setup?
  6. Oct 30, 2024 at 6:21 PM
    Just remember you are on flat ground.
    Any suspension flex it will be different.
    TrueTexas, Kezin, djwantke and 2 others like this.
  7. Oct 30, 2024 at 6:33 PM
    Goose Goose
    Dobinsons IMS, RRW
    @TrailSpecial22 thanks that would be cool. Like I said, I have about a finger width of clearance or approximately half inch clearance.
    @Dillusion about how much flex and how much play? I don’t rock crawl or don’t do anything hardcore, just moderate trails.
  8. Oct 30, 2024 at 6:45 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    You'd get even more with SPC UCAs, if you start having trouble I'd try them before a bmc
  9. Oct 30, 2024 at 6:52 PM
    Dont know I've never hit the trail (whatever sad ones we got) and got out and looked at my clearance.
    If it rubs then you will know.
  10. Oct 30, 2024 at 7:04 PM
    i want to say 3.6, but I’ll have to dig up my last aligment sheet
    djwantke likes this.
  11. Oct 30, 2024 at 7:42 PM
    I don’t know about fire, but i am running 285/75/17 Toyo R/Ts with 2.5 front 2” springs rear and have a very good experience on and off road.
  12. Oct 30, 2024 at 7:47 PM
    Goose Goose
    Dobinsons IMS, RRW
    @SlvrSlug I’m assuming you have a bmc?
  13. Oct 30, 2024 at 7:57 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    @Goose Goose
    hey OP, lots of good info for ya.
    Although I dunno that you’re safe from rubbing with one finger clearance. Stuffing the suspension will be the test.
    I’ve seen many dudes post flexing positions, @Yotaholic may be able to ease your mind on the question of 1/2” clearance while on ground being sufficient once stuffed
    Yotaholic likes this.
  14. Oct 30, 2024 at 10:22 PM
    Ctreg
    Ctreg New Member
    I have 3/2.5" lift and had to chop the crap out of my body mounts for flexing clearance on 285/75/17 nitto ridge grapplers. 20241016_103334_HDR.jpg
  15. Oct 30, 2024 at 10:43 PM
    lol nice
    sounds like me, after, I said for 5 years I’d never start chopping and welding my new truck.
    factory UCA’s?
  16. Oct 30, 2024 at 11:17 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    OP needs a Viper cut. I also gained 20 more horsepower with the Viper cut ;)
    IMG-20240112-WA0005.jpg IMG-20240114-WA0006(1).jpg IMG-20240114-WA0005(1).jpg
  17. Oct 30, 2024 at 11:23 PM
    Yotaholic
    Olympia, WA
    I am running 285/75/17s, you will be fine. Go and hit the trails
  18. Oct 31, 2024 at 3:39 PM
  19. Oct 31, 2024 at 3:57 PM
    Justkelvin
    Justkelvin New Member
    2023 TRD off road premium
    Same lift here with 8.5 wheels and 0 offset 285 70 17 KO3s and Icon UCA , I have a mile of clearance
  20. Oct 31, 2024 at 3:59 PM
    No "fire" danger here. If the tire rubs on the trail, it'll just rub some paint off the cab mount.
