Body Mount Chop And 285/70/17 Tires
Discussion in '5th Gen 4Runners (2010-2024)' started by Mojave, Apr 21, 2024.
  1. Apr 21, 2024 at 9:17 AM
    Mojave
    Mojave [OP] New Member
    zeak
    az
    5Th Gen 4Runner trd off Road
    Hey guys, Do I need A body chop to fit 285/70/17. I know I would have to trim front lower fender but dont want to cut body mount because im still under warranty . also structural integrity . do you think it would lower resale value ?
  2. Apr 21, 2024 at 9:24 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    You only need a body mount chop if the tires are rubbing the body mount. You'll only know once you mount your wheels, tires, lift (if applicable) and alignment if you're rubbing. The alignment is crucial as that will determine your final tire position in the wheel well.
    If you end up needing a body mount chop, get a reputable shop to do the work. This will ensure it looks good (resale) and is structurally sound (warranty).
    hossler1788 and SlvrSlug like this.
  3. Apr 21, 2024 at 9:26 AM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    I have 285/75s and the chopping was needed. I did a Viper Cut and it still rubs when I turn at full flex. You see that, now turn and it rubs.
  4. Apr 21, 2024 at 10:35 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I did the body mount chop, only because I'm using -12 offset wheels and 1.25" wheels spacers. Others will say with certain wheels you can get away without a body mount chop(285s).
    If you(or shop) does a good job with a body mount chop the dealer will never know. And if they weld a bmc plate it'll make it more rigid.
    A viper cut is unnecessary to clear 285s but will help with approach angle.
  5. Apr 21, 2024 at 7:30 PM
    I say no. I run that same size and didn't have to. I would stay away from any shop that is telling you need the BMC to fit 33's. BMC needed only for 34's and higher, IMO.
    Valtor and Mojave[QUOTED][OP] like this.
  6. Apr 21, 2024 at 8:59 PM
    Depends on the wheel offset you chose. You can probably avoid a CMC with 0mm offset wheels. Many people like -10mm offset wheels because the wider stance looks better, but with those wheels a CMC will likely be needed.
  7. Apr 22, 2024 at 12:54 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Funny I'm considering adding 1.25" wheel spacers behind my 17x8.5 -12 wheels. Can you provide a picture of the poke you're getting with that setup?
  8. Apr 23, 2024 at 4:49 PM
    maximum
    maximum New Member
    Bilstein 5100 F/R (front clip is on the lowest setting), Bilstein rear springs 1.5, OME 2887 front springs and trim packer to compensate for the lean. SCS 17X8.5 -10 w 285/70r17 K02. No rubbing. I just trimmed the front bumper (inner lip) and mud guard.
  9. Apr 23, 2024 at 9:28 PM
    Mojave
    zeak
    az
    I think im gonig Bilstein 6112 , BFG K03 Tires and maybe some UCA
  10. Apr 24, 2024 at 3:36 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Here's some I just took. I'm only running wheel spacers in the front( I only have a pair) I was going to order ones rears but I kinda like it.
    One thing is with such a negative offset they will rub pretty aggressively. I just tossed on some .25" top hat spacers, and I want to get it aligned before I trim anymore. Other thing is your 4runner will never be clean as the fling everything.
    But I do enjoy how it looks.
  11. Apr 24, 2024 at 4:10 PM
    Higgbra73
    Higgbra73 Nitrous Fixes Everything
    Brad
    Chicago
    16' SR5 Premium 4WD
    Voxx "PRO's" Bronze (17x8.5) wrapped in 285/70-17 Mickey Thompson Baja Boss A/T's, 5100's with Dobinsons C59-302 2.5" front coils and Ironman 1.5" Light Load rear coils. RCI Engine Skid plate. CAT Shield SS. Freedom Offroad UCA's. 14" Borla Pro XS Muffler (40358)
    When I first installed my lift, I didn’t need a bmc, but…. After I installed UCA’s & got it aligned, it rubs and need a bmc. :annoyed:
    My wheels are 8.5” 0 offset too
  12. Apr 25, 2024 at 4:53 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Same happen when I installed jba uca. They actually push the wheel backwards(closer to the body mount)
  13. Apr 25, 2024 at 6:11 AM
    1SilverRunner
    Tejas
    Thanks! I decided to throw some spacers on while the rig was getting 34s and IMS long travel suspension installed. Hard to get a photo to do it justice, but in person the thing looks awesome.
    Front IMS is installed in this photo. (Fronts springs need to settle) Rear long travel going in tomorrow.
    Bonus photo of Tread Depot's BMC and pinch weld mod. Every time I go there these guys impress me.
    A previous shop butchered my body mount. Should have went to Tread Depot the first time.
    2021venture likes this.
  14. Apr 25, 2024 at 6:14 AM
    1SilverRunner
    Tejas
    They even through on some aftermarket 3D printed end caps for a very clean install.
  15. Apr 25, 2024 at 6:27 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Looks great! I love the added width the wheel spacers add.
    Off topic, but you add the diff drop dobinson recommends with their long travel setups?
  16. Apr 25, 2024 at 6:36 AM
    1SilverRunner
    Tejas
    Funny I bought one and the shop told me it wasn't needed. They've done a ton of these so I tend to trust them.
    I did request that we let the fronts droop and check for CV bind. Especially since the driver side has a 1/4" lean correction top hat spacer. This effectively lowers the coil and adds additional droop. If we see CV bind we will add the diff drop before it leaves the shop.
    Edit: Sorry didn't mean to jack your thread OP! I was just curious about Hosslers rig.
    :threadjacked:
    My two cents: Unless you're running very negative offset wheels or spacers most 4Runners seem to be able to run 285/70/17 tires with minimal trimming to the the mud flap and fender liner. Removing the mud flap entirely is also an option.
    If after an alignment you find you do need a body mount chop, go to a reputable shop to do it. It will be plenty strong.
    99% of people don't know what a BMC is anyways. The people that do will likely be happy to see that its already done and looks like it was done well.
    Go for it!
    Mojave[OP] likes this.
