Body lift
Discussion in 'New Member Introductions' started by 4Runneron38s, Aug 8, 2025.
  1. Aug 8, 2025 at 4:33 PM
    4Runneron38s
    4Runneron38s [OP] New Member
    Steve
    5th gen on 38’s
    6” suspension lift 1” body 38’s
    Hey guys,
    My girlfriend has a 5th gen and wants to do a 3” body lift. I have not been able to find one for a 5th gen and I’m gonna guess there’s a reason. Has anyone attempted this on a 5th gen that can offer a little knowledge? Thanks in advance!
  2. Aug 8, 2025 at 4:34 PM
  3. Aug 8, 2025 at 4:38 PM
    2019 TRDP w/Kangs brah!
    I don’t know of any 3inch body lifts for 5th gen Runners.
    RumHamRunner73 likes this.
  4. Aug 8, 2025 at 5:42 PM
    Here's some advice: Don't do it.
    Get a 3 inch suspension lift with a 1 inch body lift.
  5. Aug 8, 2025 at 6:23 PM
    4Runneron38s
    Steve
    5th gen on 38’s
    It has 6” suspension lift. She wants 42’s.
    ChessGuy likes this.
  6. Aug 8, 2025 at 6:26 PM
    Cool story....Post up come pics of this whip..
    Captain Spalding likes this.
  7. Aug 8, 2025 at 6:51 PM
  8. Aug 8, 2025 at 6:57 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro
    I gotta see this 5th gen 4Runner on 38's.
    Toy4X4 likes this.
  9. Aug 8, 2025 at 7:01 PM
    where is the pix of the goods yo
    we like pix
    also, no 3" body lift available you would have to make your own
    we dont recommend trying to make your own
    if its on 38s now, i suspect its likely REALLY close to rubbing even on a 6" with 1" body
    Your best bet is by far, work on what you have, get custom rear springs, sway bar drop brackets, panhard bar drop bracket or a Z'd panhard bar, longer brake lines, and stack your lift shocks with old man emu springs, crank the shocks, and live with 40s.
    i dont see you cramming 42s unless you decide to go portals
    the wheel wells on the 5th gen wont accept a tire that big, so you gotta lift the vehicle WAY UP over the top of the tire to be able to turn, this is why a 42 is going to be tough. You pretty much need the vehicle over the top of the tire and its going to take a lot of lift to make that 4R clear 42s.
    TLDR: start saving for portals. They give you 4" lift.
    also
    where is the pix yo
    Ironguy and Toy4X4 like this.
  10. Aug 8, 2025 at 10:21 PM
    welcome
  11. Aug 9, 2025 at 3:05 AM
  12. Aug 9, 2025 at 4:20 AM
    Welcome from Wisconsin! Where are the pics?
  13. Aug 9, 2025 at 5:36 AM
    2020 Venture / 2017 Tacoma
    :popcorn:
    Ironguy likes this.
  14. Aug 9, 2025 at 7:26 AM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    djwantke likes this.
  15. Aug 9, 2025 at 8:19 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    that is really funny ^
    It’s possible a girlfriend who is doing and wants to do these things does not exist.
  16. Aug 9, 2025 at 12:21 PM
    DesertSurfer
    My goodness, a 6” lift and 3” body lift, “help Mr. Wizard”! Good luck and welcome aboard!
  17. Aug 9, 2025 at 4:24 PM
    Gator
    Gator New Member
    Did you say she has a 6" body lift?
  18. Aug 9, 2025 at 4:56 PM
    SYTY
    SYTY New Member
    THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
