BLUETOOTH VOLUME
Discussion in 'Audio & Video' started by JBauern, Jun 23, 2024.
  1. Jun 23, 2024 at 5:42 PM
    JBauern
    JBauern [OP] New Member
    Good Day. I have a question about BLUETOOTH VOLUME in general. To have my volume louder in my 4Runner, I must almost max out the volume control on my phone. When I connect via USB, I do not have to use the phone volume. Can someone please explain why this is? Thank you.
  2. Jun 26, 2024 at 11:41 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I think the idea behind this is you can control everything without using your phone so you're less likely to cause an accident using your phone. It's less to control. Easier.
    When you use blue tooth the phone doesn't know it's connected to a car. Could be head phones or sonething so you would be controlling from your phone in a safe environment. Also it might be connected to something without a volume control or one that's less convenient to use than your phone.
    djwantke and Bagman like this.
  3. Jun 27, 2024 at 3:36 AM
    In my iphone, under settings > sounds and haptics>headphones safety. You can turn that off
  4. Jun 27, 2024 at 3:37 AM
    I'm sure android has a setting somewhere too
  5. Jun 27, 2024 at 8:03 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    yeah my android phone has asked me if I want to turn off or on driving mode, so I'm sure it's aware
  6. Jul 10, 2024 at 1:09 PM
    J31Bodie
    J31Bodie New Member
    NW Indiana and far NE Wisconsin
    2023 Silver 4Runner SR5
    Ya know, I was goofing around with Carista recently on my new (to me) T4R, and one of the options under "Instruments: Displays & Nav" is "Speaker Volume", with settings from 1-14. Having just sold my Tundra before buying this T4R, I was very surprised to hear how loud the stereo would play in the new vehicle. Not sure if perhaps raising that number in your configurable settings might help your situation? Just a thought.
  7. Jul 10, 2024 at 2:56 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    So some good answers here from the 4R folks, but besides Bluetooth and USB being digital audio - Bluetooth is more compressed in order to transmit wirelessly, and typically provides the lowest volume gain. As for the volume control of these two sources, the answer may be a fixed versus variable situation. But I can’t seem to find that answer on “Lougle”
    J31Bodie likes this.
