Blower motor noise at low settings -2023 SR5 Premium
Discussion in '5th Gen 4Runners (2010-2024)' started by ericmozeta, Nov 20, 2023.
  1. Nov 20, 2023 at 12:29 PM
    ericmozeta
    ericmozeta [OP] New Member
    Very noticeable whine/noise from blower motor at low speeds. Vehicle has less than 3000 miles.
    Blower motor and filter are clear of any debris. Listen with
    headphones!
    https://www.youtube.com/shorts/_Alc0vzaMps
  2. Nov 20, 2023 at 12:59 PM
    4RWVOH
    4RWVOH New Member
    sounds like mine. Most likely the bearing on the blower motor. Since mine was still "working" but noisy I greased the rod with a little PB blaster until it comes back. You're under warranty so they should replace it no problem. its an easy fix but one of those annoying things that happens more often than I realized.
    https://www.youtube.com/watch?v=d5qBWsZEYnw&t=145s
  3. Nov 20, 2023 at 1:02 PM
    ericmozeta
    The PB blaster fixed your noise- if so for how long. I have read this is common for blower motor, but I want my Yoda to be perfect. My 14' corolla is quiet so I would expect the 4Runner to be as well.
  4. Nov 20, 2023 at 1:05 PM
    4RWVOH
    4RWVOH New Member
    I agree... mine wasn't near as bad as your video... but any creak or noise in the cabin drives me nuts. If the noise comes back relatively soon then I'll just replace it. However, I don't have a lot of confidence going back with the OEM one since its a common issue and yours is failing on a 2023 model and therefore it should be replaced under warranty - again that shouldn't be an issue at all.
  5. Dec 12, 2023 at 10:17 AM
    My 2021’s started making a soft but quite annoying white-noise-y buzz that matches the fan speed in pitch. I’m planning to warranty it.
  6. Dec 12, 2023 at 10:21 AM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    Take it to your dealer. Your warranty will cover fixing it.
  7. Jan 12, 2024 at 7:29 AM
    Update: I took it in, the tech believed it normal blower motor noise (so they thought warranty was unlikely) but they replaced the blower motor and cabin air filter for the cost of the latter solely. (that was their deal since my cabin filter had a tear on the edge)
    We didn’t sit in another 4Runner on the lot to compare like they originally suggested but the new motor is still making the same noise. Whether it’s any better is probably placebo effect.
    Darn! Guess for now I’ll have to drown it out.
    I’m disappointed since it could very well be “normal” for the model but I haven’t experienced it in any other vehicle I’ve driven, including Toyota’s.
  8. Jan 12, 2024 at 9:18 AM
    laxman09
    laxman09 Gassy Member
    Mahoning Valley, OHIO
    My 2020 makes the same noise and it drives me insane. It's a CPO, so I plan on taking it in before that warranty is up.
  9. Jan 13, 2024 at 11:13 AM
    Matt83
    Matt83 New Member
    Northeast
    My 2019 makes the same noise, asked the dealer and they said it was the cabin air filter I had installed....yea.
    The other 4Runners I have been in make the same noise, my Tacoma is quiet though. I don't even notice the 4Runner noise anymore.
  10. Dec 18, 2024 at 3:15 PM
    caresto
    caresto New Member
    2023 Toyota 4 Runner TRD Offroad
    My 2023 TRD ORP does the same. It started about 1k ago and barely has 9k now. I removed the filter and the noise is still there. I suspect the bearing is the problem. I'm sorry to hear the noise continue after they replace the motor in yours. Reading this, discouraged me of taking it to the dealer.
  11. Dec 18, 2024 at 5:49 PM
    caresto
    caresto New Member
    Please let me know how it goes. I'm trying to ignore it but I don't think I can. LOL
  12. Dec 19, 2024 at 8:54 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    These motors have bushings-not bearings. Without taking the motor apart, they are not serviceable. A new OEM motor may be quiet for a short time, but they all get noisy on low at some point.
  13. Feb 18, 2025 at 4:28 PM
    donotdisturb
    donotdisturb New Member
    Today I got a new blower motor. OEM, made in Japan and the noise is gone. My SR5P has 7,000 miles on it.
  14. Feb 19, 2025 at 7:21 AM
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
    It's a common issue with Tacomas. My '23 SR5P is still silent at 30k
  15. Feb 19, 2025 at 7:31 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Give it some time, the noise will come back. It's the nature of these OEM blower motors. They are just noisy.
    I got a brand new OEM motor, 6 months and the slight whine was back.
  16. Feb 19, 2025 at 9:15 AM
    Rocko9999
    2011 Limited
    Yep, the motor and bushings are prone to noise. You learn to live with it. It's no indication of it's longevity. They can go for decades making a little noise.
  17. Feb 19, 2025 at 9:37 AM
    donotdisturb
    What about the Lexus GX? I doubt that they make the same noise.
  18. Feb 19, 2025 at 11:28 AM
    Rocko9999
    2011 Limited
    Dunno. Not sure it's compatible.
