Blackstone Oil Analysis
Discussion in '5th Gen 4Runners (2010-2024)' started by HazOpRed, Nov 28, 2023.
  1. Oct 13, 2025 at 9:34 AM
    OR VietVet
    OR VietVet Multnomah Falls
    Ron
    Oregon
    1996 Tacoma LX Ext Cab RWD
    You contact Lake Speed Jr. company at Speediagnostix.com and they have kits that can be purchased depending on whether you want to get the sample from removing the oil pan drain plug or by using a hand pump and a line that reaches down in your oil dipstick tube. The kit supplies you with the sample cup and a prepaid Fed Ex shipping box and you send it in and then you watch for your results to be sent to you via email. They do the testing and results very quick. All of this is explained at Speediagnostix.com.
    I have hooked up other forum members at other forums I am on and they all agree that Speediagnostix.com is quicker and much more thorough.
    Lc200[QUOTED] and nimby like this.
  2. Oct 13, 2025 at 10:31 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Thanks! Will check their website . At 200k, I am sure it would be nice to see the results.
    So much more thorough compared to the other Blackstone Lab that I have also heard about?
    OR VietVet[QUOTED] likes this.
  3. Oct 13, 2025 at 10:36 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Loved his video on gas and it's lubrication properties. Most never consider that that.
    OR VietVet and nimby[QUOTED] like this.
  4. Oct 13, 2025 at 10:56 AM
    Definitely.
    It changed the way I regularly maintain my vehicle.
    Before, I thought "fuel system cleaner" was mostly hogwash unless you neglect your vehicle and continuously buy shitty gas.
    However, the few companies that actually make a good fuel system cleaner show tangible benefits......not just from "cleaning" but also in the form of increased lubrication of the cylinder walls....... and I'm starting to see those benefits now in my own use case.
    OR VietVet and Rocko9999[QUOTED] like this.
  5. Oct 13, 2025 at 11:03 AM
    Rocko9999
    2011 Limited
    Exactly. It impacts my fuel brand choice as well, when possible of course.
    nimby[QUOTED] and OR VietVet like this.
  6. Oct 13, 2025 at 11:15 AM
    OR VietVet
    Ron
    Oregon
    Lake Speed Jr. is a very knowledgeable guy and willing to share. @Lc200, when you go to the Speediagnostix.com site, compare what they test/inspect for to the Blackstone Labs examples here. Plus, Blackstone does not share the knowledge of fuel additive and other info. Lake Speed Jr. videos at you tube, are very informative.
    nimby and Lc200 like this.
  7. Oct 13, 2025 at 12:53 PM
    MidniteTRD
    MidniteTRD New Member
    Augusta GA
    looks great, ~1ppm iron per 1k miles is excellent stuff. i'd have a hard time wanting to change anything.
    i've been running 0W-40 in mine since something like 2,500 miles old, it runs great, burns nothing, and returns very low wear metals on the few analysis i've done. doesn't hurt that my other vehicle uses that grade as well, so i only have to stock 1 kind of oil.
    Rocko9999 and OR VietVet like this.
  8. Nov 2, 2025 at 4:20 PM
    HazOpRed
    HazOpRed [OP] 22' TRDOR
    You are close. It is not a Euro formulation
    nimby[QUOTED] likes this.
  9. Nov 3, 2025 at 12:43 PM
    Are you using the Diesel oil formulation?
  10. Nov 5, 2025 at 7:03 PM
    HazOpRed
    Yessir. T6 Rotella. I was curious if this engine would like it. Appears it does. Might change it to something else soon. I like experimenting
  11. Nov 6, 2025 at 10:52 AM
    Sounds like long term use is not good for your cat.
