Bilstien 5100 set at 1 inch front what tire will fit?
Discussion in '4th Gen 4Runners (2003-2009)' started by Dawg7113, Oct 23, 2020.
  1. Oct 23, 2020 at 11:35 AM
    Dawg7113
    Dawg7113 [OP] New Member
    Ryan
    2004 4RUNNER sport edition v8
    Looking to level and install larger tires
    I have a 2004 4Runner 4x4 sport... I’m looking to level it with 5100 Bilstien shocks and struts. Plan on going to the first notch in the front struts. Should raise 1 inch. I was planning on going with Fuel Cleaver 17x9 and was going with 285-70-17 Nitto Ridge Grapplers. Anyone have this setup or something similar?
  2. Oct 23, 2020 at 1:27 PM
    Welcome to the forum Ryan.
  3. Oct 24, 2020 at 9:15 PM
    BottomDwellingT4rLife
    BottomDwellingT4rLife Has an attractive member
    Anthony
    SE Tennessee
    2005 limited V8
    Lift isn’t as much the issue as the tire itself. You will rub. Any thread on 285s will tell you you will definitely have to remove the mud flaps, trim plastics, and possibly a body mount chop. Good luck. If you look at my build thread you will see 285s on a 2 inch lift with 17x8 inch wheels
    Dawg7113[OP] likes this.
  4. Oct 25, 2020 at 9:33 AM
    Dawg7113
    Ryan
    BottomDwellingT4rLife likes this.
  5. Oct 25, 2020 at 1:45 PM
    Anthony
    SE Tennessee
    2005 limited V8
    The only other thing I might add is if you can get those same wheels in 8” wide would be a better bet for you. Unless you prefer the pulled in tire look. If you off-road at all as well it’s more likely to lose a bead on a wider wheel
  6. Oct 25, 2020 at 6:07 PM
    Dawg7113
    Ryan
    That’s a good point but I’ve already ordered the wheels. We will see how they fit and do I guess
  7. Oct 26, 2020 at 5:49 PM
    Anthony
    SE Tennessee
    2005 limited V8
    All good man, hope it works out good. Just trying to be as informative as possible :thumbsup:
    Dawg7113[QUOTED][OP] likes this.
