Bilstein 6112/5160 Question
Discussion in 'Suspension' started by Toofine44, Jun 3, 2021.
  1. Jun 3, 2021 at 6:02 PM
    Toofine44
    Toofine44 [OP] New Member
    After waiting 4 months, my Bilstein 6112/5160 came in and I'm thinking of going with 2.5" in the front and 1.5" in the rear.
    I would like to ask if anyone on here has some pictures of their 4Runner with this set up to see how level it is and pros and cons to this set up.
    Thanks in advance.
  2. Jun 3, 2021 at 10:12 PM
    Mtbpsych
    Mtbpsych New Member
    It comes down to your preferences. At 2.5” you might need upper control arms, you might not.
  3. Jun 3, 2021 at 10:17 PM
    Toofine44
    I want to see how level 2.5" front with 1.5" in the rear with this lift looks like, thats why I asked.
  4. Jun 3, 2021 at 10:18 PM
    Mtbpsych
    Mtbpsych New Member
    You asked for pro and con of lift height..lol.
    You’ll be pretty level. Rear is about 1” higher from factory. Mine is lifted 3/2 and it’s pretty much spot on level.
    21TOR, Reldn, Toy4X4 and 1 other person like this.
  5. Jun 7, 2021 at 5:15 AM
    Reldn
    Reldn New Member
    Missouri
    '24 Ice Cap TRD ORP
    While I'm not running Bilsteins on my 4Runner, I do have mine lifted 2.5 in the front and 1-1.5 in the rear (I've heard both figures for the rear Eibach coils). It sits pretty level, and I did put aftermarket UCAs in mine. I had them installed along with the lift, so, I can't really compare if I truly needed them or if I'd have been fine on the stock ones.
    I've got a couple of photos:
  6. Jun 7, 2021 at 5:26 AM
    2.5"/1.5" is the perfect lift for these, IMO. I might be biased, though. :)
    With 265/70/17 KO2's:
    With 285/70/17 Toyo AT3's:
    With 295/70/17 Yokohama Geolander MT's:
    And with some dirt after a day of shenanigans:
  7. Oct 26, 2021 at 1:10 PM
    ESCT4R
    ESCT4R New Member
    2022 TRD ORP
    Did you need to add aftermarket UCA's?
    I have a local shop telling me I need them...
  8. Oct 26, 2021 at 3:29 PM
    I did replace UCA's, but I'm not certain that I needed to. Usually, somewhere between 2.5 - 3" is when they become necessary.
