Bilstein 6112/5100 B12 Lift - Rubbing Tires - Falken Wildpeak 275/70-17s
Discussion in 'Suspension' started by dao, Feb 15, 2022.
  1. Feb 15, 2022 at 10:08 PM
    dao
    dao [OP] New Member
    '22 TRD Offroad
    Murphy's Law.....I guess.
    I read tons and tons of forum threads prior to purchasing a lift, rims and new tires. NOT ONCE did I see anyone mentioning 275/70-17s rubbing with the Bilstein 6112/5100 B12 2 inch/1 inch 6/4 lift.
    As a matter of fact, I read the opposite. There were tons of folks mentioning how 275s will definitely NOT rub with a 2"/1" lift. Well, I'm here to tell you I had the rims, tires and lift installed properly and everything measures out correctly and my tires rub. I haven't had the chance to see how bad and where it is happening, but it seems to only happen in reverse even prior to full turn.
    Here are all the mods:
    TRD 17" Gloss Gray Rims
    Falken Wildpeak A/T3W LT275 /70 R17 114S C1 BSW tires
    Bilstein 6112/5100 with B12 rear coils mounted in the 6/4 slots
    I had Shock Surplus mount the new coils on the 6112s.
    I measured the height of the fender well at each corner prior to any mods and then after everything was installed....same size rims, larger tires and the lift. All the mods raised the front about 2 1/2 inches and the rear about 1 1/2 inches...give or take.
    The lift is pretty much what I was expecting....about a 1/2 inch from the tires and 2 inches from the 6112 6/4 lift.... 2 1/2 inches total.
    Anyway, just wanted to put this out there so folks see it. I'll add more info later.
    travelinscout likes this.
  2. Feb 15, 2022 at 10:12 PM
    Mtbpsych
    Mtbpsych New Member
    What are your alignment specs? I would say that has a bigger role than anything else at this point. Stock UCA’s? If your caster is at stock setting, then I wouldn’t be surprised your experiencing rubbing in reverse. I would guess it’s rubbing on your mud flaps if you have them still and/or the rocker panel.
    Wyzguy2001 likes this.
  3. Feb 15, 2022 at 10:17 PM
    dao
    dao [OP] New Member
    '22 TRD Offroad
    My alignment specs? I have no idea...whatever Toyota dialed in. It tracks perfect. Yes, stock UCAs. The 6/4 6112/5100 B12 lift doesn't require changing out the UCAs. I'm not here to find out why because it rides wonderfully. The Falken Wildpeaks are quiet, have less rollover than the crappy stock Dunlops and 6112/5100 improved the ride. I'm just here to state what no other person stated...that 275s can rub even with a significant lift.
    When I find out where, I'll post a follow-up with pictures.
  4. Feb 16, 2022 at 7:26 AM
    afret
    North Idaho
    You probably won't rub with the stock wheels which have more positive offset pulling the tires inboard about 0.43". Also not all tires of the same size have the same dimensions. The Wildpeaks have a very wide tread for a given size and can increase the chance for rubbing.
  5. Feb 16, 2022 at 7:38 AM
    dao
    dao [OP] New Member
    '22 TRD Offroad
    Yep, the Wildpeaks are wider in the tread area than some other 275s or so I've heard. I believe the TRD Pro rims have a slightly different offset as well. I'll post pics later showing the rub areas. I just wanted to let everyone know this exact combo rubs.
  6. Feb 16, 2022 at 7:59 AM
    Mtbpsych
    Mtbpsych New Member
    Your alignment plays a huge role post lift. If your caster isn’t set close to 4 degrees, your tire will be positioned closer to the rear. Stock UCA’s don’t have much adjustability. Anything more than 2” of lift up front you may need to UCA’s to get a good alignment. Wheel specs and alignment are what matters most when it comes to eliminating tires rubbing, not so much how the amount of lift.
  7. Feb 16, 2022 at 9:07 AM
    Mtbpsych
    Mtbpsych New Member
    Looks like you’re rubbing on the front fender liner. Super easy fix, and rubbing would be expected at full wheel lock.
  8. Feb 16, 2022 at 9:11 AM
    dao
    dao [OP] New Member
    '22 TRD Offroad
    Yeah. I'll get the blow torch out later and round off the tires.
  9. Feb 16, 2022 at 9:11 AM
    dao
    dao [OP] New Member
    '22 TRD Offroad
    That's a joke by the way.
  10. Feb 16, 2022 at 9:22 AM
    Mtbpsych
    Mtbpsych New Member
    Lol, you can just push the fender liner forward.
  11. Feb 16, 2022 at 9:38 AM
    Wyzguy2001
    Wyzguy2001 New Member
    2021 4runner trd or
    None yet but coming
    I have a 1.7 lift in front with falken 275.70.17. Only rub backing at full lock. Minor but loud when it happens. How are you all moving the liner? Heat or refastening liner ?
  12. Jul 26, 2022 at 8:02 PM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    PPF, Tint, Black out badges/Valances. Bilstein 6112's & 5100's
    Could it be the oem TRD wheels as they don't have a negative offset.
  13. Jul 27, 2022 at 7:10 AM
    Your lift has nothing to do with rubbing (or preventing rubbing).
    It's the combination of your TRD wheels (more specifically the lower offset), your larger tires, and your alignment.
    Pro's get the fender liner mod at the port because of the lower offset wheels added.......and they still come with 265s.
    Get the fender liner mod and have your caster pushed as far forward as it can go. I'm guessing it will be somewhere around +3.2 degrees with a 2" lift up front. That should get rid of the rub.
    ChessGuy, 7385, Nevin and 3 others like this.
  14. Jul 27, 2022 at 8:12 AM
    GaoKS
    GaoKS New Member
    Midwest
    2023 TRDORP
    Its the almost 285 size wildpeaks and your caster.
  15. Jul 27, 2022 at 9:36 AM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    OP has 275s
  16. Jul 27, 2022 at 9:46 AM
    kmeeg LionRunner
    I did used a blow torch when I was using 285s on TRD Offroad wheels..
    I didn't like the look so later I cut that part for a cleaner look.
  17. Jul 27, 2022 at 9:50 AM
    GaoKS
    GaoKS New Member
    Midwest
    2023 TRDORP
    I know what size tires OP has. I said almost. Wildpeaks run larger than your "normal" 275 AT.
  18. Jul 27, 2022 at 1:04 PM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    :smack:
  19. Jul 27, 2022 at 6:47 PM
    GaoKS
    GaoKS New Member
    Midwest
    2023 TRDORP
    I'm not sure the intent of this or if you genuinely have no idea what you're talking about or what I'm referring to. Wildpeaks generally run slightly larger (wider and taller) than the same size AT alternatives, namely K02's and others.
    Pavo and SlvrSlug like this.
  20. Aug 30, 2022 at 2:15 PM
    TrailSpecial22 New Member
    PA
    285/70/17 Falken WP on stock rims, 2” lift front, 1.5 lift rear and no rub. Yes I know, I have more offset. But the simple fix to TRD rim rubbers is a fender trim and slight push fwd of wheel well liner. Alignment should be 3.6+ on caster.
    KCN896130 likes this.
  21. Feb 2, 2023 at 10:47 AM
    Behold28
    Behold28 New Member
    ‘23 TRD Off Road
    Hey man, I'm about to get the same setup with 6112s and 5100s in the rear. I am also adding SPC UCAs to the front to help with post-lift alignment. Getting B12 springs in rear (2" standard which apparently gives 1.5" in rear on 4R 4x4s). I have a 2023 TRD ORP with TRD Pro 17" wheels. I'm still waiting on the SPC UCAs to arrive, and the suspension work will begin at that point. I am changing out the 265 Nitto Terra Grapplers for 285 KO2s. I am a little nervous about what Circlip location to use on the 6112s because I have not come to a consensus on that with my shop - I just told them I wanted to do whatever is best to fit the 285s and end up with a small amount of forward rake (maye 1/4" - 1/2" forward rake) and that I am okay with some some minor trimming and fender liner push. I took pre-lift measurements from center of hubs to fender and basically have about a 2 1/8" forward rake. Anyway, I will post the photos after work is done, but let me know if you have any suggestions before I dive into this.
