Bilstein 5100 with spacer
Discussion in 'Suspension' started by milo88, Aug 14, 2020.
  1. Aug 14, 2020 at 12:22 PM
    milo88
    milo88 [OP] New Member
    Hey,
    I have a 2005 4runner limited with a 2.5 inch spacer in the front, and it is about leveled. I need to replace my factory shocks since they are leaking and was looking at buying the bilstein 5100 shocks with the 0-2.3 inch lift.
    If I adjusted the shocks to have a 1 inch lift, and I kept my 2.5 inch spacer, will it be lifted another inch from the way it is now? And if I put the shocks on the max ride height, will I be lifted 4.3 inches in the front?
    I'm not sure how the suspension works so thats why I'm asking y'all, sorry if its a dumb question!
    Thanks.
  2. Aug 14, 2020 at 2:09 PM
    If you buy 5100's, you're going to want to ditch the spacers in the front.
    The 5100's will allow you to raise the front of the vehicle up to 2.5" when using your stock springs.
    I don't think there's any advantage to putting your stock coil on the 0" setting of the 5100 and using spacers to lift your truck instead. Just seems pointless, IMO.
    If you did decide to do what you describe above and put the 5100 on the 0.85" setting and add your 2.5" spacer, you would be at 3.35" of lift in the front......which you don't want. Your truck will ride better at the 2.5" lift mark.
  3. Aug 14, 2020 at 9:24 PM
    MountainMan
    MountainMan New Member
    Pacific Northwest
    Yes, it will be lifted exactly 1" higher than what it is now. However, I believe the first setting is .85" rather than 1". I was thinking the same thing since I just installed the 2.5" Daystar spacers and was blessed with a great ride and the alignment was able to be put back within spec, but barely. By going for that extra .85" of lift, I'm pretty sure that I would then have to go with new aftermarket upper control arms in order to to get the alignment back within spec.
    I would go ahead and get the 5100s just because they are a great shock for the price, and you will always have the option of using them for lift in the future if you decide to remove the spacers.
    You can see how the spacer affects lift in this photo of my suspension...
    The Bilsteins have an adjustable mount where the bottom of the coil spring rests on the shock, and that can be set at three different heights in order to affect lift.
  4. Aug 15, 2020 at 6:09 AM
    Motorjock721
    Motorjock721 New Member
    a
    2020 Gray SR5 4runner
    My truck is a 2020, I have Bilstein 5100's all around with the front set at 1.75" on stock coils with a one inch rear Cornfed spacer. Looks great, rides even better than stock. Just wanted to show you another option for you.lift 1 (1).jpg
  5. Aug 15, 2020 at 4:38 PM
    milo88
    Thanks guys, I appreciate all the responses. I think I'm going to buy them and ditch the spacer like you all said. Thanks!
    nimby likes this.
  6. Aug 26, 2020 at 8:58 AM
    mx4_gonzo
    mx4_gonzo New Member
    nice!! what tire size are you running?
  7. Aug 27, 2020 at 3:05 AM
    Motorjock721
    a
    Factory Goodyear Duratracs 265/70/17. They came with the SR5 Blackout package. They are very beefy tires.
    mx4_gonzo likes this.
  8. Aug 27, 2020 at 3:19 AM
    mx4_gonzo
    did you have to realign after you installed the blistein shocks?
  9. Aug 27, 2020 at 4:12 AM
    Motorjock721
    a
    Yes
  10. Aug 27, 2020 at 5:47 AM
    jason2006
    jason2006 New Member
    C090EFC8-D9C3-47AD-9185-4D5B69EFA0BD.jpgHere is mine with 5100’s all around with front set at 2.5” with 2” corn fed spacer in rear. Rides great!!
  11. Aug 27, 2020 at 11:39 AM
    mx4_gonzo
    Did you need to get new UPAs? What tire size you got there? Is it leveled or raked a little forward? Looks nice!!
  12. Aug 27, 2020 at 12:50 PM
    jason2006
    No and stock wheel size with 1.25" Spidertrax wheel spacers. The rear does sit higher so yes I have forward rake so when I load the back there isn't any sag.
    mx4_gonzo[QUOTED] likes this.
  13. Aug 27, 2020 at 3:37 PM
    mx4_gonzo
    that looks bad ass. I was thinking on going with 285s but looking at yours convinced on going with 275s to avoid chopping anything
  14. Aug 27, 2020 at 3:50 PM
    jason2006
    My tires are 265's
  15. Aug 27, 2020 at 6:10 PM
    mx4_gonzo
    yeah I know, and still looks good so with the 275s will still look good, its what I'm saying, sorry lol I was just afraid it would look dumb with stock tire size and a lift.
    jason2006[QUOTED] likes this.
  16. Sep 23, 2020 at 5:38 PM
    mx4_gonzo
    Have you had any issues with the spidertrax? Shake?
  17. Sep 23, 2020 at 5:56 PM
    jason2006
    No shake at all. Very smooth ride. Steering wheel doesn’t move/shake either. I had a Toyota dealership install them for me
  18. Apr 17, 2021 at 7:36 AM
    Led4x4
    Led4x4 New Member
    2017 white 4Runner
    Did you need UCA’s
  19. Apr 17, 2021 at 10:47 AM
    jason2006
    No
  20. Dec 7, 2021 at 5:40 AM
    Plug McHackerson
    Plug McHackerson New Member
    Paul
    Sorry, I know this is an old post, but was wondering if you had any rubbing with 2.5/2 and 1.25 Spidertrax on Sema wheels? Rig looks awesome, btw!
  21. Dec 7, 2021 at 8:53 AM
    4runnerTRDoffroad
    4runnerTRDoffroad New Member
    2020 White TRD ORP
    Trd Pro wheels with Falken Wildpeak AT3 tires. Ceramic window tint. LED lights. Frontrunner 3/4 roof rack. Alpharex Luxx Headlights. Morimoto XB amber fog lights. Bilstein 5100 shocks front set at 1.75 and rear with a 1" cornfed spacer.
    I know this is an old post but this is exactly what I have if anyone is interested, I recommend going with this setup if you are using 5100DSC01213.jpg
  22. Dec 7, 2021 at 11:31 AM
    Plug McHackerson
    Paul
    Looks really good. Actually, I already had my dealer order 5100s front and rear with a B12 rear spring. Just wondering if that’s enough, considering I might go with Sema wheels and 1.25 Spidertrax with 265s. My current setup on my 15 Trail has -12 SCS wheels. Not gonna lie, I’m addicted to the “poke”. I just can’t imagine my wheels inside my fender line. Lol
  23. Nov 13, 2022 at 7:41 AM
    1HotTRD
    1HotTRD New Member
    5th gen 4R
    None yet
    What tires are you running on there? Looks great.
  24. Nov 27, 2022 at 5:57 PM
    NBridenbaugh10
    NBridenbaugh10 New Member
    2017 4Runner TRD Off-Road
    Baja designs fogs, 4Runner Lifestyle Blackout Emblem Kit and Window Deflectors
    This is mint, exactly the setup I’m going for. Have all the parts ready to go just need to get the install done. Out of curiosity, any issues with rubbing? Any trimming? Doesn’t look like it but I can’t blow the picture up very large. Thanks for the info!
  25. Dec 31, 2022 at 6:33 PM
    22gamdg
    22gamdg New Member
    Shawn
    Bilstein 5100's, Falken Wildpeak AT3W 275/70R17, TRD Pro Wheels
    Just installed Bilstein 5100's set at 1.75" in the front with a 1 inch Cornfed spacer in the rear. I put on 275s and have a slight rub at the lower front valence. Mine is a RWD however, so not sure if the 4WD will have the same issue.
  26. Dec 31, 2022 at 8:56 PM
    kmeeg LionRunner
    I installed 275/70R17 on my stock TRD Offroad (4wd) and no rubbing.
    I guess its the TRD Pro wheels causing the rubbing. If you were stock we could think since 2wd have less ground clearance could cause. But since you have 1.75" lift you should still be over about 1in taller than 4wd models. So I guess TRD Pro wheels are the problem.
  27. Jan 1, 2023 at 8:19 AM
    You need to do the fender liner mod.
    It's really easy.
  28. Jan 9, 2023 at 3:14 AM
    22gamdg
    22gamdg New Member
    Shawn
    Update: I did the fender liner mod and also removed the front mud flaps and all is good now. Thanks.
    nimby[QUOTED] likes this.
  29. Jan 9, 2023 at 6:15 AM
    Good to hear!
