Bigger Battery Upgrade
Discussion in '5th Gen 4Runners (2010-2024)' started by Ringer1022, Feb 7, 2022.
  1. Feb 7, 2022 at 1:14 PM
    Ringer1022
    Ringer1022 [OP] New Member
    Christy
    5th Gen 4Runner Pro
    I’ve done a Westcott lift, AlphaRex headlights, Drone remote start, UpTop roof rack, Extreme Lightbar
    I have a 2018 5Th Gen Pro. My battery is the original and is barely holding on. I ordered a new NorthStar Group 31 (ODY-ODX-AGM31).
    The battery is larger than factory and also larger than the battery tray and open area for the battery.
    Best I can tell I need to move/change the a/c line that runs in by the battery.
    What else has everyone else done for their upgrades?
  2. Feb 7, 2022 at 1:19 PM
    Guess first question is why do you need a bigger battery?
    People have add a second.
  3. Feb 7, 2022 at 1:22 PM
    Ringer1022
    Christy
    5th Gen 4Runner Pro
    I’ve added a light bar, multiple rock lights, the alpharex headlights, and raptor lights. There are additional electronic things that will be added in time.
    I also live at 9,000ft and the temps here are generally colder. The CCA for the new battery is amazing and beneficial in colder temps.
  4. Feb 7, 2022 at 1:26 PM
    I’ve got a 18’ with original battery and it’s fine.
  5. Feb 7, 2022 at 1:48 PM
    I'm still voting for the second battery.
  6. Feb 7, 2022 at 1:58 PM
    I replaced mine with a stock size Diehard AGM. I believe it has significantly higher CCA than OEM.
    I have ditch lights, a light bar, and winch. The original in my '19 was starting to get a little wimpy with around 70K miles.
    I have not seen or read about what it takes to fit a physically larger battery, so I can't help there.
    Ringer1022[OP] and GrantA like this.
  7. Feb 7, 2022 at 2:00 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    Yeah I understand what your saying but someone like me doesn’t have room for a second battery. I have seen people use bigger batteries to accommodate. I have a switch pro for my accessories to prevent killing my starter battery. Would rather still have a dual battery setup and may do that in the future. There are some options out there for 2 smaller batteries that fit inside the same space of the starter battery but I don’t recommend that option.
    I can’t give a review of the OP battery as I still have my stock battery. I run a winch, a bunch of accessories (rock lights, ditch lights, ARB dual compressor, and few more lights). Still running well.
    Ringer1022[OP] and Thatbassguy like this.
  8. Feb 7, 2022 at 2:22 PM
    Crank_Mancastle likes this.
  9. Feb 7, 2022 at 2:39 PM
    Ringer1022
    Christy
    5th Gen 4Runner Pro
    The OEM is 10.25” 6.5”. The new one is 13.5”x6.5”. There’s an HVAC line in the same area preventing the wider battery. I’m hoping someone else has done the same and has some pointers on their changes.
    My OEM battery, definitely dying. My drone app tells me battery charge and on average it’s 12.7v-12.9v. I’m waiting anyway for it to just stop turning over. I imagine the temps up at outer altitude aren’t helping (which I modified to the correct 9,000ft).
  10. Feb 7, 2022 at 7:42 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
  11. Feb 8, 2022 at 8:18 AM
    Crossfit4Runner
    Crossfit4Runner New Member
    Saint Louis
    2018 TRD Off Road Permium
    To many to list
    This is the set up I have. I went with the Taco size battery and Taco factory tray.
  12. Feb 8, 2022 at 8:20 AM
    I'd do 2nd over larger because the inner fenders are weak. Also nothing you have added is a significant draw...even the craptor lights.
    LandCruiser likes this.
  13. Feb 8, 2022 at 8:39 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Finding a battery with higher CCA is not that hard, just depends on your budget you dont have to go physically bigger. If youre actually worried about supplying power to your accessories you might consider an alternator upgrade along with the big 3 power connections. Food for thought
  14. Feb 8, 2022 at 8:46 AM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Some really weird justifications in this thread.
    For the record, I left my truck outdoors all the time and I’ve never had difficulty cranking the engine at cold temperatures or high elevations with the stock battery.
    Some Christmas tree lights in the hood aren’t going to make a big draw either.
  15. Feb 8, 2022 at 9:07 AM
    Ringer1022
    Christy
    5th Gen 4Runner Pro
    THANKS!! You didn’t have to relocate that HVAC line? It just looked too snug when I visually was sighting it.
  16. Feb 8, 2022 at 11:05 AM
    Shadow_T4R
    Shadow_T4R New Member
    Josh
    2019 MGM TRD OR 4Runner
    Bilstein 6112 + 5160S | JBA UCA | Icon 2" Rear Springs | Cooper Evo MT 285/70/17 | Spider Trax Spacers | ToyTech Diff Drop | ARB Diff Breather | C4 Low Pro Bumper | X2Power AGM Group 31 Battery | Voltage Booster | Diode Dynamics SS3 Sports | ARB 50qt Fridge | Custom Built Gear Plate
    He's using a group 27F, the same route I went only I used the 27M. With the group 27 there's no need to mod anything, other than buying a larger battery tray. Specs are slightly lower than the group 31, might be worth looking to getting a 27 over the 30 you are looking at. I was able to run my ARB fridge off of the 27 for 4 days with out starting the runner.
  17. Sep 5, 2022 at 3:39 AM
    POWERPLANTHOMER
    POWERPLANTHOMER New Member
    JAMES
    2020 TRD OR PREMIUM, 2021 TRD OR PREMIUM KDSS
    I wanted to thank the original posts! I did exactly the same, bought the Tundra tray, and the 27F X2. Now $445 a battery. I upgraded both 4Runners and charged them up with a new NOCO 2AMP. They definitely spin the starter faster. I’m not modifying the alternator charge voltage however, I’ll keep an eye out and throw the charger on as I go. I have two 4R’s to test with.
  18. Nov 26, 2023 at 4:16 PM
    scottiezilla
    scottiezilla New Member
    Bringing up an old one…again it feels like
    But my apologies none the less
    So as always, terrified to…
    A. Pull the trigger after the mass amounts of research n time put into considering too many “what ifs?”
    B. Start a new thread…even though I’ve seen 194728 of them for other repetitive subjects….
    However, long story short…ish
    ‘16 stock battery is finally getting changed…has died n come back to life many times but I’m finally putting on my bumper/winch/lights/radio etc. to my already existing dual compressor etc…(this has been brought up on all forums before but I assured myself it’s happening NOW)
    no fridge yet
    no dual battery yet
    was talking with my guys at mainline overland over here on the east coast n they calmed my overthinking down to the point of just getting a new starter battery
    (I didn’t want to install something I didn’t need n I didn’t wanna install something that needed to be changed immediately or for a few more $ been THAT much better or convenient)
    I have my aux fuse block stuff, breaker, etc., all ready n set basically
    Supposedly need an ACR…?
    its just the battery I’m STILL stuck on n I know I just need to pick one
    I’ve been reading for years it seems n the last couple days(Black Friday stuff) all bout batteries
    I can’t decide between basically a regular old starter lead acid(which I can’t really find less I’m blind)
    or AGM
    With the AGM…voltage booster, ctek setup, no new alternator
    it comes down to the whole stock size VS 27f(least seems to be safer n better in some regards)
    scared of group31 damage n weight
    N unnecessary at this point
    I’ve seen on Napa they have a 24f odyssey
    n then the x2 power 27f
    how hard is it to monitor the AGMs? Do they all need the extra this n that?
    n then all the regular name brands out there which I think are the good old lead acids…
    So again my apologies
    N I’m bout a solid B kinda dude…pretty good at most things but not perfect
    N I hate terminology as it scares me to death
    I REALLY need some help
    My goals are to be able to have a safe reliable truck
    My winch n compressor solely when engine is actually on
    everything else I want to be able to use without being scared of battery dying out
    have a noco boost dude that has saved my ass for the past couple years but I’m tired of it all
    I know I’ll need or should get new terminals for my accessories
    Maybe even a terminal fuse
    Different tray/cage for different battery
    if it wasn’t for being the battery
    N just something I could throw together n mcgeiver that suits my needs(I know you can personalize the electrical system but my made outta junk truck bed/storage system won’t explode for example)
    again
    Sorry
    Help
    Happy holidays
    Stay warm
    edit…
    I’m just lost n overwhelmed
    Apologies
  19. Dec 17, 2023 at 12:55 PM
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: Hefty and Bud Built. Tires: KM3. Switchpro.
    I've been running an Engel fridge with a lithium portable battery for a couple years. The problem is the slow recharge rate, especially when they are being used to passthrough power to the fridge. Larger capacity portables just delay the recharge issue a few days later into the trip.
    This led to endless research into expensive BCDC setups. Complete overkill.
    I'm now preparing to replace the stock 24F with an AGM 27F in a Tundra tray. Add a voltage booster, and fuse wires through the firewall back to the fridge.
    The 92 aH should give me 40+ without dropping below 50%, providing 500WH of available power - plenty for 24 hours in camp, with a quick recharge as soon as I get back on the trail.
    My GMRS radio and my SwitchPro app both give me a voltage reading, but I'll likely add a gauge along the way.
  20. Dec 18, 2023 at 9:07 AM
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    When running added accessories (that are not in use when the truck is off), isn’t it more logical to upgrading the alternator for Amps? I think our stock one is 130A, and I’ve only come across one high output alternator at 270A. For accessories running while vehicle is off, 2nd battery makes sense, or a power station if only running for adventures vs daily. I guess if running security dashcams in parking mode, makes sense for 2nd battery that are focussed on storage vs CCA.
  21. Dec 18, 2023 at 9:33 AM
    Old Tanker
    Keith
    "Matilda" 2019 ORP
    A good 12 volt fridge will use about 2 amps. A day in camp is too much for a stock starter battery. Replace that with a 93aH AGM and you can spend a day or more before needing to recharge the battery. A second battery makes sense but is not required for the use case. A power station is fine for a weekend trip, but they recharge so slow off an accessory plug that a full day of driving won't get them back to 100%.
  22. Dec 27, 2023 at 10:15 AM
    my runner
    my runner New Member
    dave
    2018 4runner 2018 4.0v 6 5 speed auto
    I had bad luck with the AGM, Battery years ago, and with a regular charging truck/4Runner . I killed them in a few yrs. And the cheaper battery lasted longer. Back then I was running a 1800 watt AC inverter , with my computer printer and kinda my office in my truck. I used a Battery charger every nite on my regular up sized lead acid battery and it was great. I now have an installed float charger on both my 4Runner and my Tacoma. My only issue is my wife will do things like leave the door open all nite or leave the ignition on both have happened over night when she forgot to plug the 4Runner in... The Utube add I saw for a diode thing to plug into the fuse socket of the alternator , is $85 but all it will do is increase the voltage output to 14 plus and I think if you have the money to experiment it may be a good idea . I can't afford to keep replacing Batteries and not sure if that will keep the Battery at the higher voltage , With the lead acid? I think I would like to find a way for the car to alarm me when it goes down to 11 volts. So I can catch it and quit buying Batteries .
