BF Goodrich KO2 Tires
Discussion in 'Wheels & Tires' started by Jimbo6711, Sep 30, 2019.
  1. Sep 30, 2019 at 2:00 PM
    Jimbo6711
    Jimbo6711 [OP] New Member
    TRD Off Road Premium
    3" REVTEK Lift
    Hello All,
    I recently purchased a 2019 TRD Off Road Premium and had a 3" RevTeK lift installed. The dealer wouldn't recommended a larger tire size than 275x70x17 on stock rims. Although it looks nice, it appears that I could have went with a larger tire size without making any modifications but I'm not sure... Will 285's fit without needing to make any body modifications and no rubbing?
  2. Sep 30, 2019 at 2:35 PM
    Huzer21
    Huzer21 New Member
    CO
    2011 GX 460
    Maybe, maybe not. My 275s rubbed in full lock in reverse on the driver's side. I had to move the fender liner. If you move the caster enough so you're not rubbing on the body mount, you'll most likely rub on the front bumper/fender liner. There were enough comments about BMCs being needed, that I went with 275s and I'm happy. When they wear out, I'll probably change things up.
  3. Oct 18, 2019 at 6:40 PM
    Hwnrunner
    Hwnrunner New Member
    Hawaii
    2019 4Runner SRS Prem 2wd
    TRD Pro Struts/ Coils, Toytec 1" spacer, Dobinsons C59-505 Springs,TRD Pro Sema Wheels, TRD Pro Lower Valances, Ceramic Tint
    I 2nd that!
  4. Oct 18, 2019 at 6:54 PM
    As stated, there's no guarantee either way. It depends on offset, alignment, etc.
    In general, it seems like MOST people running 285's have had to do a BMC, or some other modifications.
    I'm hoping to find out for myself in the next year or so:)
    SlvrSlug likes this.
