Best way to bleed brakes, solo?
Discussion in '5th Gen 4Runners (2010-2024)' started by Charlievee, Jun 12, 2024.
  1. Mar 3, 2026 at 8:00 PM
    2019 TRDP w/Kangs brah!
    I bought a Motive bleeder and adapter from Power Probe plus speed bleeders but haven’t used any of it. There’s a product out there that actually pumps the pedal for you but it needs air. https://www.fenderlizard.com/
  2. Mar 3, 2026 at 10:05 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I got one of these from HF. I have not yet used it for the calipers. I did use it for refreshing PS fluid by suction out PS fluid from reservoir-then add fluid -start and drive up/down driveway-repeat a couple times.
    Brakes are due in a few months.
  3. Mar 5, 2026 at 3:39 PM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    I have a Motive. I would strongly recommend not buying one. I have the aluminum billet reservoir cap for perfect fitment to. Doesnt leak, but cant bleed the back lines with it. I tried many times as it wasnt cheap. Its a good bleeder, but not for these trucks
    Use the stock pump for the rears and the usual pump and dump for the fronts this is far far simpler and easier.
    Did I mention not to buy the Motive? Thank me later.
    jgalt likes this.
  4. Mar 5, 2026 at 3:40 PM
    Grug556
    Grug556 New Member
    I typically for the rears put a bottle through per side. Its alittle over but gets it clean and well out of the old junk. Fronts 3/4s of a bottle is great. Yes you can use less, but its not to pricey to really clean the crap out so why not.
    Rocko9999[QUOTED] likes this.
  5. Mar 6, 2026 at 10:59 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Thanks.
    Grug556[QUOTED] likes this.
  6. Mar 6, 2026 at 11:22 AM
    Charlievee
    Charlievee [OP] Not new member.
    Back in a past life, i would run a german brake fluid that came in two colors. Made it easy to confirm new from old when replacing. Wouldn't even know where to buy it anymore.
  7. Mar 6, 2026 at 11:27 AM
    Grug556
    Grug556 New Member
    Yeah the blue stuff. Apparently they have changed the formula and the Blue label is now back to yellow and also the quality isnt what it use to be years ago.
