Best portable bottle jack?
Discussion in 'General 4Runner Talk' started by xmt037, Aug 19, 2023.
  1. Aug 19, 2023 at 8:31 PM
    xmt037
    xmt037 [OP] New Member
    2021 ORP
    ARB Skid Plates, FrontRunner SlimLine2 rack, 31" KO2s
    Recently had to change my tire and the jack provided is terrible. It was a huge pain in the butt to change. Can anyone recommend an easier aftermarket bottle jack?
  2. Aug 19, 2023 at 8:34 PM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
  3. Aug 20, 2023 at 4:12 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    I have the Safe Jack and am very happy with it. Pricey but works well and is packaged in a soft side bag that fits well in my off-road packing scheme…
    Cheers,
    Bob
    Captain Spalding likes this.
  4. Aug 20, 2023 at 11:33 AM
    xmt037
    2021 ORP
    Curious what you like about it and why it's had so much value compared to a simple bottle jack? I'm looking into getting one.
  5. Aug 20, 2023 at 12:19 PM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    the safejack when purchased in a bundle comes with some incredibly useful accessories like extension, flat and U platform. These add ons make it easy to use for lifted vehicles with rock sliders, etc. it’s also in my experience a quality jack
  6. Aug 20, 2023 at 12:29 PM
    xmt037
    2021 ORP
    Thank you. Just picked on one up!
  7. Aug 20, 2023 at 1:30 PM
    BobbyB
    Bob
    Marietta, GA
    Same response as Mr Snuffleupagus…
    Cheers,
    Bob
  8. Aug 20, 2023 at 9:02 PM
    Han4Run
    Han4Run New Member
    NY
    2019 4Runner Pro
    Went with a safejack/accessories and it’s been great.
  9. Aug 20, 2023 at 9:15 PM
    Using stock jack on my lifted 4runners. Never a trouble on pavement. Never had to jack up off pavement.
  10. Aug 21, 2023 at 12:09 PM
    Hey could one of you guys with a Safe Jack please take a picture of it next to the stock jack and post it? Any chance the Safe Jack will fit where the stock jack is stored in the fender compartment?
  11. Aug 21, 2023 at 2:25 PM
    BobbyB
    Bob
    Marietta, GA
    I pulled out my stock jack and took a few pics compared to the Safe Jack. I tried to fit the Safe Jack into the OEM location without success - it’s just a little too tall.
    Hope the pics help.
    Cheers,
    Bob
  12. Aug 21, 2023 at 2:43 PM
    Maybe another good thing to check. Does the SafeJack fit in the hi-lift jack base?
    The stock jack fits in the hi-lift jack base in case you want to use in a trail / rough ground.
    (Ignore the wrong jack point. This was a different test. But I was still able to lift the tire.:))
  13. Aug 21, 2023 at 2:47 PM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    To me, it seems like the different heads are the biggest advantage of the Safejack over the OEM jack.
    Does anyone know if we can attach different heads to the OEM one? The open C option would be great; the OEM jack is pretty slippery.
    PJSnow and Captain Spalding like this.
  14. Aug 21, 2023 at 3:26 PM
    Thanks!
  15. Aug 22, 2023 at 5:59 AM
    BobbyB
    Bob
    Marietta, GA
    Yes, the Safe Jack fits on a high lift jack base.
    Cheers,
    Bob
  16. Aug 22, 2023 at 10:02 AM
    I feel like the ideal off-road jack has yet to be invented. Or maybe some breakthrough will be made with airless tires and the jack will be unnecessary.
  17. Aug 22, 2023 at 10:18 AM
    I was able to play with the ARB hydraulic jack for a little. I liked it alot. I really do. Its not too big either. But the price was 800 bucks or something like that if I'm not mistaken. Since its also a type of hi-lift jack I can only use on my sliders. I guess those who have aftermarket front and rear bumpers with hi-lift jack points can use it with more options.
    Also had a chance to look at the inflatable thing that use exhaust has. Didn't had a chance to try it. I was only able to look and feel. Not sure how good it would be.
  18. Aug 22, 2023 at 10:36 AM
    I like the idea of the ARB jack. The expense is holding me back.
    Is there a drawback other than that? I mean, if you have sliders isn’t it ideal? Safer than a Hi-Lift. Don’t have to get under the vehicle, as with a bottle or scissors jack. Can you think of a situation where you couldn’t use it and you’d want another kind of jack?
  19. Aug 22, 2023 at 10:40 AM
    A jack needs to be short enough to fit under the axle with a flat tire, yet be able to extend long enough to jack up the frame and get a front tire off the ground. Most hydraulic bottle jacks sold in local stores don't have that kind of travel range. I see two-stage bottle jacks sold online which may work well: https://www.amazon.com/Torin-ATH80402XB-Double-Welded-Capacity/dp/B09Z37N3BS/
    Before you order, I suggest fully deflating a rear tire and measuring the clearance under the axle, to make sure a 6.7" tall jack would fit.
    The Safe Jack needs those accessories or it actually won't work on the 4Runner, due to the limited stroke.
    The 6-ton Safe Jack heads have 1.25" ID, too small for the OEM jack. I think the 12-ton or 20-ton heads may fit.
  20. Aug 22, 2023 at 10:56 AM
    I don't want to get in trouble just checking it one time and giving recommendation. But I felt much safer than a hi lift jack since the handle it very smooth.
    I don't remember ARB has an option to use as a manual winch like hi-lift jack. (since I don't have a winch my hand puller and my hi-lift jack are my last resort winch options and so far I have only pulled a tree. LoL)
  21. Aug 22, 2023 at 11:06 AM
    Yoda_Mike
    Yoda_Mike New Member
    Michael
    South Glens Falls, NY
    2019 Toyota Tacoma TRD Sport
    I keep one from Harbor Freight in my pop-up camper. Works well. Gets the job done. No bells or whistles, but it lifts the camper easily and allows me to change a tire. Now....if only I didn't have to do so EVERY freakin' time I take the thing somewhere! LOL
  22. Aug 22, 2023 at 3:22 PM
    In racing it's common to use a screw jack like this: https://agm-products.com/en-ca/collections/jacks/products/manual-jack It weighs only 11lbs, but the 3000lb capacity is marginal for 5th gens. (IIRC the factory jack is 3700lb rated.) Works pretty quickly with a cordless impact on the drive nut.
  23. Aug 22, 2023 at 4:07 PM
  24. Aug 23, 2023 at 1:20 AM
    mtnslyr
    mtnslyr New Member
    Safejack has warning that their saddles are not to be used with Toyota OEM jacks. But check this out: https://sites.google.com/site/landcruiserproducts/jack-adapters?pli=1
    backpacker and PJSnow like this.
  25. Aug 23, 2023 at 6:39 AM
    Schlappesepple
    2020 ORP
  26. Aug 24, 2023 at 11:37 AM
    like2lean
    like2lean New Member
    I went with on of the Mercedes Sprinter Jack of Ebay. German made, curved top, and WAY cheaper than safe jack, those seem way overpriced to me. This thing is heavy, well made, has a double ram that extends very high for recoverys
    https://www.ebay.com/itm/175847674189
    kojak and PJSnow like this.
