Best Angle for 4Runner Picture?
Discussion in 'General 4Runner Talk' started by Awales74, Jan 31, 2024.
  1. Jan 31, 2024 at 2:25 PM
    Awales74
    Awales74 [OP] New Member
    Howdy, picked up a new 4Runner this weekend; 2024 SR5 Premium in red. I get a kick out of taking pictures of my new cars but new to 4Runners I'm a bit stumped. Advice on the best setup? Maybe front corner, slightly above with a wheel on a curb. I don't know. What looks good in your opinion if you could only have 1 picture of your truck?
  2. Jan 31, 2024 at 2:30 PM
    Do what the fat chicks do, take an above the head odd-angle picture while making the duck lips face.
  3. Jan 31, 2024 at 2:34 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    I am also guilty of taking pictures :D
  4. Jan 31, 2024 at 2:38 PM
    Steve Berman
    Steve Berman New Member
    any angle with the rear hatch open to disguise the hideous spoiler. I need to research options on removing it
  5. Jan 31, 2024 at 2:41 PM
    Steve Berman
    adding a random image
    Thatbassguy and Awales74[OP] like this.
  6. Jan 31, 2024 at 2:55 PM
    steelevo
    Utah
    Welcome. Just find some good lighting to show of the sparkle of the Barcelona Red.
  7. Jan 31, 2024 at 2:57 PM
    Ctreg
    Ctreg New Member
  8. Jan 31, 2024 at 3:04 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey OP
    Funny thread topic, but a good one.
    I spend countless minutes I'll never get back standing, staring, motionless at my 4R. And taking photos like a weirdo.
    Don't believe me, keep reading lol
    5th Gen Runners can look a little awkward and ugly through the lens on a number on angles. Like if you take a pic straight on, it can look buggy, looks better if you snap photos from down low.
    Apart from that, side profile always looks good.
    Same with this angle below
  9. Jan 31, 2024 at 3:04 PM
    Yotaholic
    Olympia, WA
    That's how a 4Runner is used :bowdown:
    Thatbassguy and djwantke like this.
  10. Jan 31, 2024 at 3:06 PM
    Deep ass hole !
  11. Jan 31, 2024 at 3:06 PM
    Yotaholic
    Olympia, WA
    If you keep rolling like that, soon this is going to happen to you too ;)
  12. Jan 31, 2024 at 3:35 PM
    Up, down and all around!
    Photos are memories so whatever pic of my T4R that brings a smile is all that matters.
    DesertSurfer and Yotaholic like this.
  13. Jan 31, 2024 at 4:02 PM
    There are plenty of good angles! Front/side posed on a rock is always good.
  14. Jan 31, 2024 at 4:09 PM
    The rear wiper is contained in that "hideous spoiler." Also, I'm pretty sure that spoiler is designed to help with fuel economy. Think how bad it will suck gas without it! :eek:
    That said, I have a bunch of good pictures with the hatch open. ;)
    Example:
  15. Jan 31, 2024 at 4:16 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Not to be confused with the less popular deep asshole
  16. Jan 31, 2024 at 4:20 PM
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    :101010:
    Dude, I'm practically crying over here! You have won the thread!
  17. Jan 31, 2024 at 4:24 PM
    Yotaholic
    Olympia, WA
    Going down the front driver tucked in so hard and quick, I thought I broke something lol.
    Awales74[OP] and Thatbassguy like this.
  18. Jan 31, 2024 at 4:29 PM
    Yotaholic
    Olympia, WA
    I always turn around to have a look at this
  19. Jan 31, 2024 at 4:31 PM
    Hah!
    Very good distinction.
    Unless ur into that kinda thing ;)
  20. Jan 31, 2024 at 4:34 PM
    4R Gas station pics, go!! :laugh:
  21. Jan 31, 2024 at 4:35 PM
    Yotaholic
    Olympia, WA
    Arco for the win
  22. Jan 31, 2024 at 5:23 PM
    You and your fancy steel bumpers also for the win
    Yotaholic[QUOTED] likes this.
  23. Jan 31, 2024 at 5:26 PM
    Yotaholic
    Olympia, WA
    Fancy lol. They are the cheapest crap available out there. C4s someday :amen:
  24. Jan 31, 2024 at 5:30 PM
    Gotcha!
  25. Jan 31, 2024 at 5:34 PM
    Yotaholic
    Olympia, WA
    I removed that bar after it blocked the radar sensor.
  26. Jan 31, 2024 at 5:35 PM
    Should have gotten a '19@ no TSS! :bananadance:
  27. Jan 31, 2024 at 5:36 PM
    Yotaholic
    Olympia, WA
    And a real key
  28. Jan 31, 2024 at 5:39 PM
    :D yup
    Keyless is cool. But, there's something satisfying about putting the key in and turning it to start the vehicle.
  29. Jan 31, 2024 at 5:39 PM
    Especially when it starts right up! :D
  30. Jan 31, 2024 at 5:44 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    The best angle is the one without your finger in the pic ;)
