Best aftermarket skid with oil filter access?
Discussion in '5th Gen 4Runners (2010-2024)' started by Sparkkky, Feb 27, 2019.
  1. Feb 27, 2019 at 7:48 AM
    Sparkkky
    Sparkkky [OP] New Member
    2018 4 Runner TRD Off-road
    Eiback Pro lift, ARB Summit bumper, Smitty Bilt wench, Summit flood LED
    Whats the best skid with a access hole for oil changes? Needs to work with my Summit bumper.
  2. Feb 27, 2019 at 7:50 AM
    Agent_Outside
    Built 2011 T4R Limited
  3. Feb 27, 2019 at 8:58 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Another for RCI
    WallyT4R likes this.
  4. Feb 27, 2019 at 12:46 PM
    Sparkkky
    Thanks, I would rather relocate the oil filter to a more convenient location!
  5. Feb 27, 2019 at 1:20 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    Could always buy a 4th gen :notsure:
    :spy:
  6. Feb 27, 2019 at 2:09 PM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Ive been looking for 1/4" skids but so far have been unsuccessful. I have worked with buddies on a lot of rigs and we are starting my '53 Willys and we always use 1/4" plate vs. 3/16". Granted, we do things with those rigs that we wont do with our 5th Gen but I still would prefer the extra protection. That all being said, so far, it looks like the 3/16" is the only option I have found. I am looking at the RCI as well unless anyone knows of or I am able to find a full 1/4" skid system. The RCI system looks to lock together pretty nicely and people seem to be happy with it.
  7. Feb 27, 2019 at 2:45 PM
    SnowroxKT
    SnowroxKT New Member
    Alaska
    2018 T4R TRD Offroad
    2018 T4R Offroad SAS 1995 Tacoma
    1/4" skids on a non-abused vehicle seems pretty excessive to me. Weight would really add up too if you did full 1/4" skids.
  8. Feb 27, 2019 at 4:22 PM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    I agree, however, that one rock that ruins a weekend is out there! haha. One thing I have noticed is that people worry a lot about the weight. I dont consider the runner anemic on power or getting to heavy for "wheeling" where it is "that" much of a concern. I am willing to throw more weight around for the protection. I am thinking of making my own front skid (1/4") and then tying into the rest of the RCI's at this point. I am fully aware that I am going a little overkill but I REALLY don't like getting broken down due to something preventable haha! We will see. I am not running the 3/16" diff skid at all. That will be 1/4" FOR SURE.
  9. Feb 27, 2019 at 7:41 PM
    WallyT4R
    WallyT4R New Member
    Budbuilt makes some pretty hefty skids. Check him out. http://budbuilt.com/2010-2018-5th-Gen-4Runner-Skid-Plate--Front_p_539.html
    He doesn't make 1/4" steel but does in aluminum. His steel skids are either regular steel or stainless.
    I have aluminum RCI skids.
  10. Mar 5, 2019 at 12:05 AM
    DesertCanyons
    DesertCanyons Professional Engineer, Civil/Structural
    Dave
    Pasadena, CA
    2015 MGM Trail Edition w/ KDSS, no sunroof
    ICON tubular Stage 7 lift (+2"), ICON Rebound wheels w/ Falken AT3W LT285/70R17 tires, Baja Rack flat utility rack and ladder, RCI skid plates, Domello rock sliders, Diff breather relocated, Baxter Performance remote oil filter, Weathertech floor mats, side exit exhaust, 2nd rear recovery point
    RCI makes a good set of skid plates. If it were any thicker it would be very hard to lift them into place and bolt them on. For the two heaviest plates I use a floor jack and a wood block centered below the skid to hold it in place up close while I lift it by hand to set the bolts. This works well.
    As for the remote oil filter, look at Baxter Performance for a system that works well. I installed one with my KDSS (it makes a difference where you can mount the remote filter if you have KDSS).
    I suggest using the spin-on filter adapter placed under the engine where the OEM canister filter is. You can reach it through the opening in the RCI skid plate. The remote filter depends on AN-10 hoses and fittings. If any one point leaks you're dead in the water. You can't fix it in the field unless you carry spare hoses and big open end wrenches - 1&1/16". You have to drain the oil to work on the lower fittings or change a hose. The hoses are around $70 each for ready made. Around $40 if you make them yourself. I made two hoses with 4 end fittings and one of the end fittings leaked due a mistake I made. So I bought ready made hoses.
    WallyT4R and Backslider like this.
  11. Mar 6, 2019 at 11:06 AM
    victoryrunner
    victoryrunner New Member
    Cam
    2017 SR5 Magnetic Gray Metallic 4Runner
    Falken Wildpeak A/T3 285/70R17 | Mamba Offroad Wheels M23 | 3" BDS Suspension | Victory 4x4 Blitz Front Winch Bumper | Victory 4x4 Strike Sliders
    We make a full skid system here at Victory 4x4 for the 5th Gen. Front, mid, and transfer case skid. (gas tank skid coming soon). We offer them in 3/16" steel and 1/4" aluminum. The front skid makes changing your oil much easier than the stock setup. I changed mine a few weeks ago.
    https://www.victory4x4.com/category/4RUNNER.html
    3/16" steel will be plenty strong to protect your vehicle. If you have any questions about that, check out some of our Tacoma rock crawling videos (similar skid design)
    Let me know if you have any questions!
    tonycaputo and WallyT4R like this.
  12. Mar 6, 2019 at 12:06 PM
    Firefly21
    Firefly21 New Member
    Duane Frazier
    18 off road premium trd
    Hid lows 3500 drl / high Led interior Led reverse Led oem fogs Sequential blinker Trd intake Unifilter pump mod Apex recover points BF Goodrich KO2 (matching trd spare) Kicker front tweeters Tvd overlays S2 yellow wide fogs Apex black sequential rear tails Cartrim home blue convex mirriors
    Does your system fit the factory TRD plate?
    Bought a baja hoop off jcr in 2006 for a wrangler my father still has it on his and looks great
    victoryrunner likes this.
  13. Mar 6, 2019 at 12:17 PM
    victoryrunner
    Cam
    It looks to me like it would work with our mid and transfer case skids but you would have a gap between your front control arms because the TRD skid only goes to the front of the control arms.
  14. Mar 6, 2019 at 1:25 PM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    do your skids work with KDSS?
  15. Mar 7, 2019 at 7:04 AM
    victoryrunner
    Cam
    The KDSS sway bar is the only issue, it looks like our front skid will clear that but we are getting a KDSS truck in soon to verify.
  16. Mar 7, 2019 at 7:42 AM
    Sparkkky
    Since you’re here.
    Does the front work with a ARB Summit bumper?
  17. Mar 7, 2019 at 8:05 AM
    victoryrunner
    Cam
    As long as it doesn't interfere with this crossmember where our skid mounts. If you had a picture like this under your bumper I could give you a better answer.
  18. Mar 13, 2019 at 6:24 AM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    Please post up and let us know.
    Thanks
  19. Mar 21, 2019 at 3:15 PM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    I ended up with a full set of Bud Built skids and sliders. Now I just have to settle on the lift. I will mount everything up and take some detailed pics when they get here.
    WallyT4R and HoBoDanny like this.
  20. May 29, 2019 at 12:33 PM
    victoryrunner
    Cam
    It's been a while, but the front skid will work with KDSS.
