Balljoint UCAs or Uniballs with King Coilovers?
Discussion in 'Suspension' started by stefzo, Feb 10, 2021.
  1. Feb 10, 2021 at 6:50 PM
    stefzo
    stefzo [OP] New Member
    Stefanie
    I'm having the hardest time deciding!
    I originally bought Camburg balljoints but now I'm debating on swapping them out for Camburg Uniball with the cap. Mild off-roading but mostly daily driver. I'm more worried about them squeaking eventually and if anything the upkeep. A friend wants me to get Mazzulla billets. But there really aren't many people running those. Price isn't really an issue..I just want a good ride. I live in LA the weather isn't a problem. What do y'all think?
  2. Feb 10, 2021 at 8:09 PM
    I'd go balljoints for low maintenance.
    If you're putting stock travel King coilovers on, you're not gaining anything from using a uniball.
    If you were going long travel with longer UCAs and LCA's, that's when you'd start seeing a benefit from uniballs.
    Toy4X4 likes this.
  3. Feb 11, 2021 at 9:24 AM
    kbp810
    kbp810 rebmem wen
    Unless you plan on bombing through whoops, the potential benefits of uniballs is not likely to outweigh the low maintenance of ball joints.
  4. Feb 14, 2021 at 2:56 PM
    Ebadai98
    Ebadai98 New Member
    18 TRD Off Road
    Balljoints, especially if your rig is your daily.
    DrewMan likes this.
  5. Feb 14, 2021 at 3:06 PM
    stefzo
    Stefanie
    Do you know anything about the mazzullas? A friend can get me them.
  6. Feb 14, 2021 at 3:11 PM
    If they are the billet UCA's, those are very high end and not needed unless you're going with a higher travel suspension set-up.
    I guess the question is how much can you get them for and what suspension set-up will you be adding to your truck? Extended travel?
  7. Feb 14, 2021 at 3:19 PM
    stefzo
    Stefanie
    I have the king coil overs going on! Yea I don’t know what to do at this point. I’m so lost. Price isn’t really an issue. Need to figure it out by next week. I just see so many people running uniballs with kings!
  8. Feb 14, 2021 at 3:35 PM
    stefzo
    Stefanie
    It’s between...
    camburg balljoint
    Camburg uniballs with cap
    Mazzulla billet UCA
    Total chaos
  9. Feb 14, 2021 at 3:39 PM
    stefzo
    Stefanie
    My friend sold me on the Mazzullas when he said I’d prob have to get a new car before I replace them. Maintenance is low. Not gonna mob the shit out of it. They look clean too.
  10. Feb 14, 2021 at 3:40 PM
    My vote is for Camburg balljoint based on what you say you're looking for in your first post.
    Toy4X4 and stefzo[OP] like this.
  11. Feb 14, 2021 at 4:31 PM
    stunner_4runner
    stunner_4runner New Member
    Raymond
    2020 4Runner SR5 4WD
    Radflo Stage 3 Lift Kit- 2.5 Extended Front & Rear RR Adjustable Coilovers Total Chaos Upper Arms ARB rear medium springs 3” Aiden James Switchback Fog Bezel Lights 4Runner Lifestyle Amber Raptor Grill Lights Trail Standard Offroad Satin/Matte Black TSO Pro Grille with 4Runner Letters Baja Designs WC Amber Fog Lights Baja Designs XL Sport Amber Ditch Lights with Cali Raised Ditch Light Brackets 2 Baja Designs LP6 Amber Behind the grille lights 2 SNS Designs 5" Amber Behind the grille lights N-FAB behind the grill lighting mount Pedal commander Jet Performance Mass Flo Air Sensor 315/70/17 Cooper STT Pro Fuel Rims Custom Magnaflow exhaust with Series 50 Flowmaster Muffler Alpharex Nova Midnight Black Headlights AFE Momentum GT Dry Filter CAI BantamX Touchscreen for Universal with sPOD Alpharex PRO-Series LED Tail Lights Jet Black Mid-Atlantic Off-Roading Full Length Roof Rack Outgear Solutions Low Key Front Bumper 4WDKING 30’ LED Light Bar for the Bumper RSG Front Skid Plate
    Ball Joint, you will definitely have less maintenance. I have the Total Chaos UCAs and love them. Haven’t had any issues with them. I was actually torn between Total Chaos and the Newer Camburg Uniballs with the caps. Decided to go Total Chaos, due to many of my friends run them on their vehicles and speak highly of them. If money is not a issue, you can’t go wrong with any of these choices. Even check out the Icon Billet UCAs.
    Like nimby stated, based on your first post description of “Mild off-roading”, the Camburg Ball Joints might be the better option.
    Toy4X4 and nimby like this.
  12. Mar 5, 2021 at 10:30 AM
    Tuco S.
    Tuco S. New Member
    Also give the Ironman UCA a look. 4 degrees caster built-in, and they use oem rubber bushings and ball joints, so replacements can be sourced through any Toyota dealer.
  13. Apr 5, 2021 at 8:19 AM
    JR7
    JR7 New Member
    2021 TRD ORP
    While I am new to 4Runners, I have had an 04' Taco as a daily driver for 17 years. The last 8 (and over 100k miles) have been with Camburg Uniball UCA's. I don't know what additional maintenance is required because I certainly have had none. I have replaced the uniballs once and will be looking at my second replacement soon. They have been quiet, and easy. I have replaced bushings once as well. I can replace the uniballs in about 30 minutes a side with a uniball press from All German Motorsports (Similar to Icon's tool). I see no reason not to get them if you want them. I will say that there is nothing wrong with ball joints other than it looked to me at the time of purchase, that uniballs were a faster, cheap, easy, on vehicle replacement. Now, with the addition of the Delta Joint from Icon, and further development of UCA's that replacement on ball joints are now easier I wouldn't shy away from those either. But my experience with uniballs will have me sticking to to them for my wife's 4Runner. :) I still will look at the ball joints just to see where things are at with them for this application but, uniballs are a proven upgrade for me. Don't shy away.
  14. Apr 5, 2021 at 8:42 AM
    kbp810
    kbp810 rebmem wen
    It depends on where you live and the environments you traverse. If you see a lot of rain, mud, snow, and worst of all, winter road salt; uniballs do not hold up great in those conditions. I'm not saying it can't be done, I've even ran uniballs myself in the past... but ball joints are certainly ideal.
    If you live somewhere relatively dry, uniballs are indeed low maintenance, and a great choice.
    JR7[QUOTED] likes this.
  15. Apr 5, 2021 at 9:02 AM
    JR7
    JR7 New Member
    2021 TRD ORP
    Touché. I’m in TX. Mainly travel West. He has a point I overlooked.
    kbp810 likes this.
  16. Jan 25, 2023 at 7:57 AM
    tdicarlo
    tdicarlo New Member
    Tyler Dicarlo
    2022 4Runner Pro
    Man, glad I found this thread before making any purchase. After seeing all the up keep on the uniball style UPC definitely going with the normal balljoint. Can anyone give any advice on either Total Chaos vs Camburg balljoint UPC and which one I should go with? Going to get some King 2.5 Extended Travel Coilovers & King 2.5 Remote Reservoir Rear Shocks (both front and rear with adjusters)
  17. Jan 26, 2023 at 3:33 PM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    2.5" Fox Suspension
    Well Total Chaos would be out of the options if you wanted to stick to a ball joint UCA. If you are open to different brands and want to stuff some 285/70/17 tires on there, we've got a full package to offer: https://accutuneoffroad.com/product...7-2010/10-4runner-mid-travel-suspension-kits/
    SlvrSlug likes this.
