Backup camera issue
Discussion in '5th Gen 4Runners (2010-2024)' started by Toffees, Apr 24, 2019.
  1. Apr 24, 2019 at 8:25 AM
    Toffees
    Toffees [OP] Stuff and things
    Micah
    LA
    16 LE
    Apologies if this has been discussed elsewhere, spent about 20 seconds searching and didn't see it...
    Have a '16 LE with about 67k miles and recently the head unit goes dark (sometimes) when I'm in R. Other times the backup camera transmits perfectly to the HU. I don't see any other issues with the HU that make me worry that it's the piece conking out, and the camera seems fine when it does work (and I can't yet tell if there are specific instances that cause failure, like rainy Tuesdays between 8am and 11am). I'm guessing the connection is bad, but of course instead of checking it myself (or adding to the dealership owner's $$) I'm here crowdsourcing to see if any of you have similar experiences/solutions/better ideas.
    -M
  2. Dec 26, 2020 at 8:37 AM
    4RunnerFan
    4RunnerFan New Member
    Matt
    2014 4Runner Limited
    I know this post is a little old, but I have the same problem with a 2014 4Runner Limited. Did you happen to find a solution? Thanks!
  3. Apr 13, 2024 at 9:36 PM
    Texas-Gorilla
    Texas-Gorilla New Member
    2015 Toyota 4Runner SR5
    I know this is an old thread but I’m having intermittent issues with the backup camera on my 2015. Anyone else had this issue and resolved it?
  4. Apr 14, 2024 at 8:34 AM
    As listed above, it's probably not the camera, it's the head unit. Does it go out intermittently? If so, that's the head unit and/or the connector on the head unit.
    Texas-Gorilla[QUOTED] likes this.
  5. Apr 14, 2024 at 8:59 AM
    It could possibly be the connection to the camera in the rear hatch.
    If nothing is found at the head unit, I would check inside the hatch.
