Backfires when giving it gas
Discussion in '3rd Gen 4Runners (1996-2002)' started by Whaley9412, Dec 25, 2020.
  1. Dec 25, 2020 at 8:01 PM
    Whaley9412
    Whaley9412 [OP] New Member
    4runner 2wd 1998
    When I start my 1998 4runner it starts and runs just fine. When you push the gas it will rev all the way out. After about 2 mins running it stays idling just fine but WHEN I GIVE IT GAS it won't rev past 2000rpm. Starts bogging down and back firing what do you guys think the issue is??
    I've tried fuel treatment and let's it run 1/4 the fuel it then refilled it. So far
  2. Dec 26, 2020 at 12:33 AM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    Welcome. What engine does it have?
  3. Dec 26, 2020 at 6:18 AM
    Ahdofu
    Ahdofu New Member
    Matt
    My first reaction is to attach an OBD scanner and lookup the diagnostic messages. Have you tried it yet?
  4. Dec 28, 2020 at 7:48 AM
    Yeah, check for codes.
    With those kind of symptoms maybe the TPS has gone bad?...the ECU doesn't know where the throttle is? Is there a motor in the Throttle body like on the 2001-2002 that could go bad?
    Fuel cleaner isn't going to anything. Something is definitely broken. Cleaning the throttle body might help it, but I think you have to remove that to do a thorough job.
    I would also try the carb cleaner trick to find leaking vacuum hoses. Vacuum hose leaks usually cause bad idle and you say that's not the case. I don't know if a vacuum leak could cause the revving out.
    Please post back with what you find.
  5. Jan 16, 2021 at 1:14 AM
    Ambush
    Ambush New Member
    AJ
    99 Black Limited (Kitt) 99 Tan limited (Desert Storm) 2001 Silver SR5 (Silver Surfer)
    MAF - Mass Air Flow sensor. Get some MAF cleaner (yes do not use any other cleaner). Let it dry for a few hours then reinstall. The ECU is not keeping up with idle/throttle while it is running. Yup TPS should be checked as well. :)
  6. Jan 29, 2021 at 3:05 PM
    RoxToy00
    RoxToy00 New Member
    rocky
    3rd owner of 2000 2whldr 4runner
    none
    my bet is a clogged cat converter.
  7. Feb 1, 2021 at 1:10 PM
    treyus30
    treyus30 New Member
    Trey
    '99 Limited & '99 Tacoma PreRunner
