Auto Start?
Discussion in '5th Gen 4Runners (2010-2024)' started by skip2a, Oct 11, 2022.
  1. Oct 11, 2022 at 5:06 AM
    skip2a
    skip2a [OP] New Member
    Pat
    Hell all:
    Cold weather is starting to show its ugly head and my old body needs a warm truck to crawl into.
    I have looked at a lot of posts and I am not sure what is the best conversion to use?
    I have a '22 with push button start. The one from https://accessorides.com/ says it will fit but I am not sure about the installation. I watched the video but I am not sure about removing the entire glove box; the video isn't very clear at that point.
    Are there other options, better options?
    Whatever I install I would like it to work off of my factory fob.
    Thanks,
    Skip
  2. Oct 11, 2022 at 5:40 AM
    mac1usa
    mac1usa New Member
    Yeah I would gladly give up some of the safety nonsense to have a remote start from the factory. It seems most of my friends with after markets have issues sooner or later (not on 4Rs but in general). A cheap Accord has remote start from factory but not a 4R?
  3. Oct 11, 2022 at 5:50 AM
    saltlife1966
    saltlife1966 New Member
    Dave
    2018 4runner TRd
    I have the accessorides in my 2018 and have zero issues with it, been in for about 3 years . takes about 30 minutes to install. plenty of videos on you tube. pretty much plug and play.
  4. Oct 11, 2022 at 8:17 AM
    4runningMan
    4runningMan New Member
    New Mexico
    Don’t the 2022’s have remote start via satellite or something like that? As part of the safety sense?
  5. Oct 11, 2022 at 9:27 AM
    skip2a
    Pat
    I thought they did when I bought mine but I can't find any info on it. Maybe the higher models? Mine is an SR5 Premium.
  6. Oct 11, 2022 at 10:14 AM
    Personally I used https://www.12volt.solutions/ without issues. It was a super easy install. Note that all push button start models will turn off when you open the door.
  7. Oct 11, 2022 at 10:20 AM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    Do you have the app? I can start it with the app without being close to the 4R.
    I can also press the lock button 3 times on the key fob to remote start but I have to be somewhat close to the truck. (I’ve got a TRD pro, I don’t know if that matters)
  8. Oct 11, 2022 at 10:39 AM
    skip2a
    Pat
    I have the app but I do not have the lock/unlock feature or the auto start feature on it. I am not sure why?
  9. Oct 11, 2022 at 2:22 PM
    scanny
    scanny New Member
    Ontario, Canada
    My 2022 TRD-Offroad manual says the following:
    Using the key fob to remote start a Remote Connect equipped Toyota:
    Press the LOCK button on the remote.
    Press the LOCK button a second time within 1 second.
    Press the LOCK button again, this time holding it for 3 seconds. The vehicle will start.
  10. Oct 12, 2022 at 1:37 AM
    I've had Accessorides only my last 4 trucks. Works great. But I have a key, not push button.
    My 2018 SR5P didn't have remote start either.
  11. Oct 12, 2022 at 6:20 AM
    Wolff_4Runner
    Wolff_4Runner New Member
    2020 TRD ORP
    What is that app? I have a 2020, curious if it will sync
  12. Oct 12, 2022 at 6:29 AM
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    I have one from Compustar. It works well. The factory keyfob kinda sucks for range. The best part about the Compustar is you can set it for longer than the 10 minutes from factory. MINe will go for 35 minutes and I think 40 minutes is max. That will really warm up your truck if needed.
  13. Oct 14, 2022 at 3:14 AM
    Whiptastichandling
    Whiptastichandling NCrunner
    NC
    15 Trail Premium
    3in Ironman 4x4 nitro stage 2 suspension lift 285s
    Which one do you have?
  14. Oct 14, 2022 at 5:26 AM
    The remote start unit will be the same, but the choices are range length and adds external antenna and new remotes, I had the 1000 ft on my Titan and worked great. My current 4r only has the base and uses the factory key fobs. Kinda wish i upgraded again, range on the Toyota fobs are something left to be desired range wise.
  15. Oct 16, 2022 at 5:55 PM
    semprenissart
    semprenissart Mèfi
    It’s from Toyota on the iPhone
  16. Oct 16, 2022 at 5:57 PM
    semprenissart
    semprenissart Mèfi
    With carista you can also change the length for the OEM auto start
  17. Oct 16, 2022 at 6:06 PM
    bulldog
    bulldog New Member
    Prepping to buy New
    N2 Designs. The guy is on Tacoma World all the time and has stellar reviews. I'm going to get one for the 4R & Taco.
  18. Oct 16, 2022 at 6:20 PM
    Braumeister
    Braumeister Kampai, bitch!
    Bentley
    Northern MI
    2021 TRD Off-Road Premium
    After much research I went with the Start-X solution. Easy installation, works great, affordable. I can’t believe this isn’t standard kit on a $50K vehicle.
    Installation took me a little less than an hour following their detailed instructional video. Note that you will be prying a number of plastic trim pieces off your dash in order to pull the glove box and access the wiring harness. I purposely did this during the summer months so not to break off any precious plastic tabs that could be more brittle in colder weather. YMMV.
    if you are satisfied with the range your fob unlocks your doors you will be satisfied with it starting your truck. Start-X (and others) offers two other long-range options using a replacement fob or a smartphone app if that blows your hair back.
    Last winter sucked with no remote start here in Northern Michigan (#firstworldproblems) but this year will be different. I’m starting to regularly use it now and am very pleased so far.
