Auto Dim sensor for 2023 OPR
Discussion in '5th Gen 4Runners (2010-2024)' started by Texas4Runner, Jul 20, 2023.
  1. Jul 20, 2023 at 7:41 AM
    Texas4Runner
    Texas4Runner [OP] New Member
    Dallas/Fort Worth Texas
    2023 4Runner ORP+ CSM and Ice Cap
  2. Jul 21, 2023 at 8:52 AM
    packetcollision
    packetcollision New Member
    MN
    '20 4Runner TRD-ORP
    Yes, I have done this on my 2020. Works, easy enough install just don't let the wiring fall into the dash when removing the factor blank plug. One solution is to slide a zip tie below the connector and between the wiring to prevent it from falling into the dash.
    kmeeg likes this.
  3. Jul 21, 2023 at 9:26 AM
    colbydog
    colbydog New Member
    Massachusetts
    2023 Magnetic Gray ORP
    I did this on my 2023 ORP. When headlights on during day, panel and display stay bright. As packetcollision says, just make sure to have a firm grasp on wiring harness.
    should be $50-$60
  4. Jul 21, 2023 at 11:02 AM
    Texas4Runner
    Great to know. Where did you get yours?
  5. Jul 21, 2023 at 11:52 AM
    colbydog
    colbydog New Member
    Massachusetts
    On Amazon, seller I used doesn’t have in stock. Plenty on ebay. Just make sure you look at pics in addition to part number. Should be 4 pins. Double check your connector for correct #pins. Better safe then sorry. Just plug and play. Turn on lights throw a hat over sensor to verify. You probably know this but it will not make your headlights auto.
  6. Jul 21, 2023 at 12:08 PM
    packetcollision
    MN
    '20 4Runner TRD-ORP
  7. Jul 21, 2023 at 1:04 PM
    Texas4Runner
    Make my headlight Auto....I don't believe it :eek: makes the headlight auto just the instrument cluster and Infotainment center auto dim.
  8. Jul 21, 2023 at 1:12 PM
    Texas4Runner
  9. Aug 3, 2023 at 12:11 PM
    Texas4Runner
