Audio System Issues
Discussion in 'Audio & Video' started by 2ndGenScarerunner, Jul 31, 2019.
  1. Jul 31, 2019 at 7:16 PM
    2ndGenScarerunner
    2ndGenScarerunner [OP] New Member
    1991 White Toyota 4Runner 3.0L
    Hello, I bought an amp and 2 subs second hand. They were working when I bought them I know this cause I witnessed them working. I have a 1991 4Runner and I’ve just tried installing the amp and 2 subs. I have the wiring correct. The stock speakers play sound but the new subs do not. The amp is powering on and has sufficient power to it. When testing the speaker outputs on the amp with a multimeter, they’re only putting out 0.02 volts What is my issue and how do I resolve it ?
  2. Jul 31, 2019 at 7:43 PM
    Do you have them wired up mono. If so the amp might not be capable of running 2ohms stable?
  3. Jul 31, 2019 at 8:21 PM
    What are you using as an input? Make sure you put a fuse around a foot off the battery, unless you want to do a little arc-welding?
  4. Jul 31, 2019 at 9:28 PM
    2ndGenScarerunner
    My stereo is aftermarket so I am using rca cables from the stereo to the amp. And yes I have a fuse there.
    I don’t really want to have to install a line output converter if I don’t have to. I bought the system all together second hand working.
  5. Aug 1, 2019 at 5:24 AM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    Have you checked settings on your deck? I would also check the ground for your amp. Make sure it's metal to metal no paint. Are your RCA's plugged into the output and not input on the back of your deck? If you have pre outs on your deck you shouldnt need an output converter. What amp an subs are you running?
  6. Aug 2, 2019 at 1:06 PM
    2ndGenScarerunner
    MAJOR SET BACK: I was moving my 4Runner out of the sun and the stereo wasn’t secure and one of the wires grounded itself and turned off the whole vehicle. It starts but the stereo isn’t turning on at all. What did I fuck up ?
  7. Aug 2, 2019 at 1:41 PM
    O’ ya I forgot to mention. Make sure you have a fuse, a few inches from the head unit. Buy a Denon, best stereo on the planet!!!
  8. Aug 2, 2019 at 2:49 PM
    2ndGenScarerunner
    Did I kill my stereo ?
  9. Aug 2, 2019 at 2:54 PM
    4scooter19
    Oregon
    98 and 86 4Runners
    Did you check the fuse on the back of the deck and the fuse for the radio in your fuse block?
