Audio / Nav system rebooting
Discussion in '5th Gen 4Runners (2010-2024)' started by Texan 4 ever, Mar 14, 2025.
  1. Mar 14, 2025 at 5:57 PM
    Texan 4 ever
    Texan 4 ever [OP] New Member
    Rob
    2017 Limited
    Lifted
    The audio / nav system started to reboot every few minutes. Took it to the dealer. They did a firmware update. Same issue persisted. Dealer said it was the system itself. Bought a used one on eBay and installed it. I then installed the Nav SD card from the old unit cuz it was several years newer. Same issue with the second unit! Rebooting! Then it dawned on me, it’s the SD card. I pulled it out and no reboot!
    It was the aftermarket SD Nav card the entire time! So if you are getting the reboot problem, it’s that cheap SD card you bought. Got the OEM SD card, no issues!
  2. Mar 14, 2025 at 6:01 PM
    It's usually the smallest thing that makes the biggest problem! Glad you figured it out.
  3. Mar 14, 2025 at 6:05 PM
    welcome
    Texan 4 ever[OP] likes this.
  4. Mar 14, 2025 at 6:09 PM
