ATF leak repair
Discussion in '2nd Gen 4Runners (1990-1995)' started by Briarthicket, Mar 31, 2022.
  1. Mar 31, 2022 at 11:06 AM
    Briarthicket
    Briarthicket [OP] New Member
    1994 Toyota 4runner SR5 V6 3L V-Shaped 3VZ-E
    I got this vehicle recently, the guy who had it said there was a power steering fluid leak but when I open the hood the cap says it takes dexron ATF, I'm wondering if i should drain the fluid that's in there in case he put steering fluid in. Also got some bar's leaks power steering repair, sources online say it's fine to use in an ATF vehicle but wanted to know if anyone with experience could weigh in before i go ahead.
  2. Apr 1, 2022 at 9:21 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Your power steering does take ATF Dex II but that is no longer made. I use Valvoline Maxlife which is a suitable substitute. If you are unsure what is in there then yes drain it and refill. Also know that these systems commonly leak. Mine leaks and I have been unable to find the cause so I check monthly and refill if necessary.
