Arm rest squeak!
Discussion in '5th Gen 4Runners (2010-2024)' started by Stevenas, Jan 9, 2026.
  1. Jan 9, 2026 at 5:45 PM
    Stevenas
    Stevenas [OP] New Member
    2024 4Runner
    Issue: driver's side arm rest pad/cushion squeaks whenever I put my arm on it, apply any pressure. Very annoying.
    Any possible solution besides tearing down the entire interior door assembly?
    Thanks in advance.
    ualfltdispatch likes this.
  2. Jan 9, 2026 at 6:03 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Remove 3 door screws, remove A pillar plastic trim piece. Pop the door pad from the bottom of the door so the trim pieces from the bottom and side come out. Careful of the door light plug. No need to remove the entire door card.
    Once lose, reach to the bottom of the arm pad from inside and wedge a thin foam piece to cover any gaps. That should take care of the squeak. I had one long time ago.
  3. Jan 9, 2026 at 9:32 PM
    Both my driver and passenger arm rests do that. I think it’s an accumulation of dust. I just spray a light coat of lubricant down the seam and cleaning and that helps.
    5thToy likes this.
  4. Jan 10, 2026 at 12:05 AM
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    Spray silicone with a wand at different materials contact points
    5thToy and Toy4X4 like this.
  5. Jan 10, 2026 at 3:42 AM
    Welcome from Wisconsin! Like Greg D said, silicone, silicone is the ticket for squeaky plastics, poly bushings in suspension pieces etc. Good luck
