Appliances to plug in to 4R
Discussion in 'Off-Roading & Trails' started by Maleskii4, Jul 5, 2021.
  1. Jul 5, 2021 at 11:42 AM
    Maleskii4
    Maleskii4 [OP] New Member
    Theresa
    4 runner, 2021
    We have a new 2021 4R and want to take advantage of the electrical plugs. Any tips on what works and how to's?
  2. Jul 5, 2021 at 11:44 AM
    AdmiralNoodle
    AdmiralNoodle New Member
    Quin
    2021 sr5 premium 4x4
    Laptop/battery charger. Not the most exciting but very useful
    Maleskii4[OP] likes this.
  3. Jul 5, 2021 at 11:48 AM
    Antman
    Antman New Member
    Anthony
    Chop saw. Skilled saw. Full size kitchen range.
    Ironguy and Toy4X4 like this.
  4. Jul 5, 2021 at 11:53 AM
    Maleskii4
    Theresa
    4 runner, 2021
  5. Jul 5, 2021 at 11:55 AM
    Maleskii4
    Theresa
    4 runner, 2021
    Thats an excellent Idea. Thank you
  6. Jul 5, 2021 at 11:57 AM
    Maleskii4
    Theresa
    4 runner, 2021
    I'm wondering about small appliances or microwave.
  7. Jul 5, 2021 at 12:18 PM
    AdmiralNoodle
    Quin
    Remember you're limited to 400 watts, with the engine running. If you can find a microwave with low enough wattage you could run it, but it would be pretty small.
    I've used a drill, but only drilling plastic so no huge load. Even small appliances often pull more power than you'd think, just check manufacturer spec
    Toy4X4 likes this.
  8. Jul 5, 2021 at 12:27 PM
    Antman
    Antman New Member
    Anthony
    totally kidding on this. Lol
    Toy4X4 likes this.
  9. Jul 5, 2021 at 12:51 PM
    MeefZah
    MeefZah ---
    Lexington, Ohio
    Look at the UL label on whatever you want to run. If it is under 400W then most likely the invertor can handle it, although some devices draw more power at startup and then "settle down" to under 400W; in which case you can't run it. Things like coffee makers, hair dryers, etc... won't work. Microwave; negative. Generally I would consider the outlet to be for extremely low wattage devices like chargers, a very small air pump (for a mattress, not a tire), that sort of thing. On the plus side, you aren't out anything if you try to run a device and it draws too much power. The invertor will just shut down; you'd then need to turn the truck off and back on to reset it. You won't damage anything by trying.
    Ricphoto, Toy4X4, SlvrSlug and 2 others like this.
  10. Jul 5, 2021 at 2:29 PM
    Maleskii4
    Theresa
    4 runner, 2021
  11. Jul 5, 2021 at 2:30 PM
    Maleskii4
    Theresa
    4 runner, 2021
    Yes, Antman...I knew you were joshing me.;)
    Toy4X4 likes this.
  12. Jul 5, 2021 at 2:34 PM
    Maleskii4
    Theresa
    4 runner, 2021
    good info MeefZah. I was really hoping for the blow dryer but I still might just go for it. :bananadead:
  13. Jul 13, 2023 at 6:27 PM
    Ricphoto
    Ricphoto New Member
    Ric
    PacNW
    ‘19 Oyster pearl / Limited Nightshade
    They sell a cool device called a “kill-a-watt” that’ll quickly and easily measure the actual draw of appliances...I’ve taken to putting the 600-800 watt devices I’ve found (Coffee pot, microwave, slow cooker etc) into the goal zero with that plugged into the rear outlet where I did the 400 anytime mod...works well
  14. Jul 13, 2023 at 7:02 PM
    Schlappesepple
    Schlappesepple New Member
    North Carolina
    2020 ORP, 2021 Rav4 Hybrid
    This is probably the most practical way to use the outlet; battery pack does the heavy lifting, then the truck tops it off.
  15. Jul 13, 2023 at 8:51 PM
    Henry J
    Sacramento Ca
    Margarita machine
  16. Jul 25, 2023 at 12:12 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    You cant really power anything from the AC outlet since it's 400w when in park and 100w while moving. You can mod it to do 400w while moving.
    When camping I use a 1,000 watt battery station to power an electric kettle for coffee in the morning and then charge anything else. Sometimes a Starlink.
    I charge the battery station with the DC cigarrette outlet in the back when "overlanding". The battery does not like the AC outlet. In short. I don't use the AC outlet.
  17. Aug 10, 2023 at 5:48 AM
    satoshi
    satoshi Mοderatοr
    2023 TRD ORP LUNAR ROCK
