Anyone running Nitto Terra-Grappler G3 tires
Discussion in '5th Gen 4Runners (2010-2024)' started by Hossdawson, May 4, 2025.
  1. May 4, 2025 at 12:51 PM
    Hossdawson
    Hossdawson [OP] New Member
    Hoss
    Harrisburg PA
    2023 4runner SR5
    I have been running these in the OEM size for a little over a month. I seem to be loosing 1.5 to 2 miles per gallon when compared to the Bridgestone Duelers that came from the factory. Not sure exactly why. But I may just go back to a more efficient tire like maybe Michelin as I don’t do hardly any off road stuff. They are more aggressive than the Duelers. Don’t know about the weight. Anyone else running these and having the same results? The tires ride ok and aren’t noisy.
    PS. I may have a nice set of tires for sale in the Central PA area soon!!!
  2. May 4, 2025 at 1:26 PM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    I lost about the same amount of MPG when I pulled my OEM Duelers and put on KO2’s. The tread patterns of off road tires is just a little less efficient apparently. Probably more grippy. But to me it’s worth it aesthetically and for trails. Duelers looked out of place on the Venture IMHO.
  3. May 4, 2025 at 3:17 PM
    Imdav2u
    23 TRD PRO
    I have the factory Terra Grapplers on my 23 Pro, went on a 3 1/2 hour road trip last weekend, hypermilled coming home, wish-o-meter showed 21.7, actual hand calculated mileage was 21.5. I drive pretty conservatively and average 18-20, 50/50 in town and highway.
  4. May 5, 2025 at 12:30 PM
    Hossdawson
    Hoss
    Harrisburg PA
    2023 4runner SR5
    I’ve been mainly driving around town and haven’t driven many highway miles and it says 14.1 average mpg. Before tire change, 15.9 average. Did a reset after installing the new tires.
  5. May 5, 2025 at 12:35 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Something something buy a prius
    Captain Spalding, _JT_ and Nick B like this.
  6. May 5, 2025 at 1:01 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    The weight of the Tire will kill mpg. I'm not sure of the weight of the terra at3, but there's a couple of all terrains 265 70 17 that weigh under 40lbs. Maxxis razor a/t are 39lbs.
  7. May 10, 2025 at 8:20 AM
    Hossdawson
    Hoss
    Harrisburg PA
    2023 4runner SR5
    If I decide to go back to a less aggressive highway tire, is there anyone near Harrisburg that would possibly be interested in these tires?
    Hoss
  8. May 10, 2025 at 6:11 PM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Just an honest question . Is money that tight that you worry about loosing less than 2 mpg ?
  9. May 10, 2025 at 6:44 PM
    Hossdawson
    Hoss
    Harrisburg PA
    2023 4runner SR5
    No…money is not that tight. I just don’t like wasting it. It is a 12% decrease in mpg that wasn’t the greatest to begin with. If the tires last the 70 k miles that they are warranted for, that adds up to a lot of money that I’d rather spend it on other things. I don’t do hardly any off road driving anyway. If I would have known that I would loose the mpg I would’ve went a different direction. It would be nice if the manufacturers tested their tires for fuel efficiency so one could make a more informed decision.
  10. May 10, 2025 at 7:06 PM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Fair enough. But you’re going to loose money when you switch them out . Nobody is going to give you nowhere near what you paid for them . My stock tires on my 2024 ORP went into a tire recycling dumpster with 940 street miles on them . I couldn’t even give them away .
    Play around with the air pressure and maybe you’ll gain it back .
  11. Jul 14, 2025 at 11:38 AM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Hoss, How many miles you have on them? Also what were you asking if you still have them.
  12. Jul 14, 2025 at 12:26 PM
    The tires that come on our T4R’s have the least rolling resistance so the gas mileage is at its highest level. Upon changing to a non P rated tire, you inserted a factor that will work against you MPG.
    Scientific answer, no.
    Real answer, yes.
    Captain Spalding and RusPro17 like this.
  13. Jul 17, 2025 at 4:38 PM
    RSD
    RSD New Member
    2017 TRD PRO
    Terra Grappler G3 in stock 265/17/r17 are xl rated tires, not sl. Besides mileage, a good question is how well does this tire perform on moderate and rougher off-roading; can it handle anything more than a fire road? Anybody get sidewall tears with this tire, other flats? Does this heavier xl tire drive like an sl on pavement?
