Anyone know what pod lights these are???
Discussion in '5th Gen 4Runners (2010-2024)' started by dS7R, Feb 16, 2024.
  1. Feb 16, 2024 at 1:00 PM
    dS7R
    dS7R [OP] New Member
    2014 Blue 4Runner SR5 4WD
    Prinsu rack 285 BFGs ORP wheels Diode ditch lights
    Hey 4R family!
    Does anyone out there know which pod lights/ ditch lights this 4R is running? Been trying to figure it out forever! Lol thanks everyone!!!
  2. Feb 16, 2024 at 1:21 PM
    The brand/manufacturer doesn't really matter. All pod lights/ditch lights are the same.
    catbrown357 likes this.
  3. Feb 16, 2024 at 2:13 PM
    dS7R
    Well I’m currently running Lasfits, they’re ok. I just personal like the styling of these much more and wanted to switch them out. But Ty
  4. Feb 16, 2024 at 2:25 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    I'm not sure I would be putting some stupid expensive Rigid lights up there. Seems an easy target for thievery. I would probably opt for some less expensive ScAmazon Chineseiums. But, that's just me. They might all be Chineseium anyway?
  5. Feb 16, 2024 at 2:45 PM
    Up, down and all around!
    Rigids were my first thought based upon the size (and possible lettering count) of the logo.
    I’m wondering if these aren’t actually ‘ditch’ lights but repurposed fogs ?
    dS7R[OP] likes this.
  6. Feb 16, 2024 at 2:46 PM
    dS7R
    Yea I’m thinking the same I’m trying to compare the number of bolts etc lol
  7. Feb 16, 2024 at 2:51 PM
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP, 2019 Audi RS5
    Magnuson Supercharger etc.
    looks like diode dynamics ss5
    raimieb likes this.
  8. Feb 16, 2024 at 3:03 PM
    dS7R
    Ss5 are very close but I couldn’t find any to match those bottom letters with, maybe an older gen of those light?
  9. Feb 16, 2024 at 3:24 PM
    These are definitely not SS5s. I have the combo edition which are the dual (Driving and Flood) light pattern. There's no center 'dead' spot as in the OP's photo. None of the light pattern bezels for the SS5 line has this 'dark' center spot.
  10. Feb 16, 2024 at 3:28 PM
    dS7R
    Ah very true, did the ss5 ever come any other way? Like older generations?
  11. Feb 16, 2024 at 3:36 PM
    Diode Dynamics first introduced the SS5 around 2021 and I'm not certain they ever produced any other bezel type other than the 'optics' designs that you see in my pic. The vertical (center row) element is the 'Driving' (long distance) lens element while the diamond pattern is the flood (diffused) pattern, the spot pattern is virtually a clear bezel.
  12. Feb 16, 2024 at 3:46 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Found them.
    Ebay i guess. 5" Laser pods.
    But i wouldn't touch them with a 10ft pole.
  13. Feb 16, 2024 at 4:13 PM
    dS7R
    Wow that’s an amazing find, have no idea how you ever found them, thanks! But definitely think I’ll stick with my lasfits if they’re eBay
    2Toys, Ripper238 and djwantke like this.
  14. Feb 16, 2024 at 6:54 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Winner of the internet today for this
    Thats funny
    2Toys and catbrown357[QUOTED] like this.
  15. Feb 16, 2024 at 6:56 PM
    Lasfits are nice yeah
    I wouldn't turn your nose up at eBay though
    Half my offroad lights are eBay :p
    50,000 hour 12v LEDs are virtually the same regardless, like buddy said
    dS7R[QUOTED][OP] likes this.
  16. Feb 16, 2024 at 6:57 PM
    I assume you're joking?
    There are major differences.
    2Toys, Ripper238, PVT Pablo and 2 others like this.
  17. Feb 16, 2024 at 6:59 PM
    I guess that depends if you're looking for functionality, or just want some jewelry on your hood.
    djwantke likes this.
  18. Feb 16, 2024 at 7:01 PM
    kojak
    kojak New Member
    21 SR5P 4x4
    Yeah they cost a lot less
  19. Feb 16, 2024 at 7:04 PM
    What are you referring to?
  20. Feb 16, 2024 at 7:15 PM
    Performance, output, and housing quality; yes much better with company's like made in America Lasfit.
    But I don't believe eBay, and North American manufacturers with Chinese chipsets and or packaging are necessarily unreliable.
  21. Feb 16, 2024 at 7:17 PM
    Man's gotta point, it's one of the reason I don't run exterior Diode Dynamics or KCs or Baja Designs or what have you. Don't see too many "locks" for them.
    And their pricing is bonkers imo
  22. Feb 16, 2024 at 7:39 PM
    Who said that cheapies were unreliable?
    I thought Rigid's prices were ridiculous until I started comparing specs.
  23. Feb 16, 2024 at 7:41 PM
  24. Feb 16, 2024 at 7:52 PM
    I was hesitant to spend the money, but they were recommended by a trusted member of Tacomaworld. After 4 years and ~80,000 miles, I'd buy them again in a heartbeat.
    djwantke[QUOTED] likes this.
  25. Feb 16, 2024 at 8:50 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Diode Dynamics SS3 Pro fogs are fantastic. Plug and play. People also like the SS3 Max’s.
    FRE1809 likes this.
  26. Feb 17, 2024 at 6:26 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Seems a lot of things these days are about appearance.
  27. Feb 17, 2024 at 7:01 AM
    You're not wrong. But, I bought mine for function. I wasn't even considering ditch lights until I found myself hitting trails all day and into dark. I don't use them all the time, but I love having them on the occasions I do.
  28. Feb 17, 2024 at 7:10 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Back when we started "overlanding" in the 70s, in our 73 Bronco, my brother and I were the ditch lights. My dad would make us get out and walk with flashlights to make sure he wasn't going to bend something. Good times.
  29. Feb 17, 2024 at 7:52 AM
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Can we ease up on the racist terms? There are Asian people on this forum too.
    alittleoff likes this.
  30. Feb 17, 2024 at 8:12 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Haha. This guy.:oldglory:
