Anyone know how to reset the fuel mileage info on the control panel?
Discussion in '4th Gen 4Runners (2003-2009)' started by Oyot089, Feb 1, 2016.
  1. Feb 1, 2016 at 2:08 PM
    Oyot089
    Oyot089 [OP] New Member
    Michael
    2005 $ Runner
    None
    I recently replaced bulbs in the climate control panel and had to disconnect the main connector. Now I find that the fuel mileage information is incorrect when it resets after filling up. It used to read around 440mpg or so now it only reads 360mpg. Any ideas would be appreciated.
  2. Feb 1, 2016 at 6:10 PM
    drunner
    drunner New Member
    Danny
    Anaheim
    07 SR5
    5100s, 885s, Toytec 2" rear, Camburg UCAs, 255/75/17 Duratracs
    Thing never reads accurately, but just hold down the reset button on each view and reset them all back to 0
    Bob likes this.
  3. Feb 1, 2016 at 8:19 PM
    Kelvin
    Kelvin New Member
    I think he's talking about the range. At least I hope so... What 4runner can get 440 mpg? Anyway, if it's the range. That thing changes with every fill up. Soon enough it'll go back to normal.
  4. Feb 2, 2016 at 12:53 PM
    drunner
    drunner New Member
    Danny
    Anaheim
    07 SR5
    Yeah, but generally when you reset everything it helps reset the range reading as well. Mine used to read 380 after a full tank, think it's down to 320 now after all the mods, haha.
  5. Feb 2, 2016 at 12:59 PM
    Kelvin
    Kelvin New Member
    Gotcha. I haven't bothered with it for awhile now. My range won't even read anything above 300 now. I think my last fill up was something like 270.
  6. Feb 8, 2016 at 10:28 AM
    joeyz
    joeyz New Member
    joe
    2005 SR5 4WD Auto 4Runr
    How do you take the climate control panel apart to replace the bulbs? I have a 2005 SR5 4 runr
  7. Feb 9, 2016 at 4:19 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Check Youtube,
    First open the compartment below climate control and lift out the compartment, it should pop out.
    There are two screws holding the climate control panel just under it, remove those and pull out gently, it should pop out.
    Remove the connector, there are two different bulbs that are used and you'll need a really good pocket screwdriver to twist and remove them.
    Good Luck....
  8. Feb 9, 2016 at 10:38 AM
    joeyz
    joeyz New Member
    joe
    Thanks for the help!
  9. Feb 9, 2016 at 10:49 AM
    joeyz
    joeyz New Member
    joe
    The Youtube video shows only 1 screw taken out (in the middle)...Thanks for your help pointing me in the right direction though!
  10. Feb 9, 2016 at 12:32 PM
    T-Rex266
    T-Rex266 Moderator Staff Member
    The range will vary based off ur driving style too.
    drunner[QUOTED] likes this.
  11. Feb 10, 2016 at 11:22 AM
    drunner
    drunner New Member
    Danny
    Anaheim
    07 SR5
    Yep, it's all relative to your driving habits but at the same time it uses your average mpg and average speed over time to calculate the range. I think mine reads like 16.3 mpg @ 30mph average speed and the range on my tank showed 340 the other day. If I reset them both back to 0, it jumps up to 380 on the range until I've gotten a week of driving out of it then it's back down.
  12. Feb 15, 2016 at 8:58 AM
    joeyz
    joeyz New Member
    joe
    Ya this part of the info available to the driver is retarded with the exception of the Mileage indicator. I fill up the tank and know how many miles I can drive-OK. Then it indicates my Average Speed is like 14 MPH??? Even after resetting it a bunch of times "Useless and Inaccurate" info. MPG...I guess works OK.
  13. Feb 15, 2016 at 1:49 PM
    Chris
    Chris New Member
    Chris
    '05 4Runner Ltd
    This and that
    I amuse myself with the readout by filling up in the CO high country and coasting downhill getting 99.9mpg's. From then on the mpg's read high for a long time. A good way to show my wife that I get good mileage. :)
    drunner likes this.
  14. Feb 16, 2016 at 10:37 AM
    drunner
    drunner New Member
    Danny
    Anaheim
    07 SR5
    After I put the 255s on, my mpg is actually pretty close to my hand calculations. Stock it's never been close. I only pay attention to the range because right before it hits 0 my gas light comes on and I usually have about 2.5-3 gals left.
    I've done that a couple times.
