Anyone have issues with 4Runnerlifestyle.com?
Discussion in 'General 4Runner Talk' started by Ikooters, Apr 6, 2023.
  1. Apr 6, 2023 at 3:04 PM
    Ikooters
    Ikooters [OP] New Member
    2023 Lunar Rock 4Runner TRD Off-Road Premium
    Hey all. New to the forum and to the 4Runner community having just bought a 2023 ORP. I bought an "in stock ready to ship" full length Prinsu rack from 4Runnerlifestyle.com back on 3/18, they made a shipping label on 3/20 but they never actually shipped it. I emailed them on 3/27 and they said it would ship on 4/3. Again, it didn't ship. Emailed them Monday to see what happened and was told that it is supposed to ship today 4/6. Seeing that the day is coming to an end and there has been no update on the tracking number, I'm thinking it isn't going to ship today.
    Just curious if anyone else has run into this with them.
  2. Apr 6, 2023 at 3:09 PM
    PC836
    PC836 New Member
    Fresno, Ca
    2022 White 4Runner PRO
    Im having same issues with shipping on other stores. Freakin sick of it. Just cancel and leave nasty reviews. Buyers shouldnt have to work so hard tracking their already purchased items.
    michow87, LCJ77, Thatbassguy and 4 others like this.
  3. Apr 6, 2023 at 3:15 PM
    Ikooters
    They’ve already processed the order and have my money. Their customer service sucks. It takes two days to get a response.
    I completely agree. It shouldn’t be this difficult.
    michow87 and Thatbassguy like this.
  4. Apr 6, 2023 at 3:18 PM
    I'm going to guess its wasn't at stock in their warehouse but at Prinsu.
    If you go to Prinsu's page it says in stock. Should of just ordered direct.
    TacoGeeloor and Thatbassguy like this.
  5. Apr 6, 2023 at 3:44 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    I have bought from them several times and what I've gathered is they create a shipping label and enter in to the carrier's system well before they are actually able to ship.
    I had one order on the carrier's website showing "shipping label created, awaiting package" for almost three weeks. Good news is, I have always received what I ordered... eventually.
    With a big ticket item like that, I certainly understand your concern and frustration.
    Thatbassguy and Ikooters[OP] like this.
  6. Apr 6, 2023 at 4:13 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Same here I've ordered from them a number of times, all the way to Canada. Relax, this is normal. Especially ever since Dumb and Dumber are running North America and pooched the supply chain
  7. Apr 6, 2023 at 5:36 PM
    steelevo
    Utah
    This is what happens when a company drop ships from the vendor. You would have been better off buying direct from Prinsu. But, since you bought from this other company, just be patient and it will arrive before you know it. The supply chain is so screwed up right now.
  8. Apr 6, 2023 at 6:31 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I'm having issues with them being out of stock of everything I want to buy. :)
    If I knew where else to get it I would but they are the only ones who have a matte black rear bumper valance that I've found. Never ordered anything from them before so this is good info so I'm not surprised if/when I do order
    Ikooters[OP] likes this.
  9. Apr 6, 2023 at 8:14 PM
    Ikooters
    I get it that it’s possible they drop ship from the manufacturer but to tell me it’s going to ship two different times and it doesn’t is kinda screwed up. I’d be out of business if I did that.
    Thatbassguy and djwantke like this.
  10. Apr 6, 2023 at 8:18 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    You're good, just wait. My stuff has always been delivered
    Thatbassguy and raimieb like this.
  11. Apr 6, 2023 at 8:38 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    @steelevo is correct. This is just how the state of drop-ship commerce works these days. No small company buys gear, stores it in a warehouse and waits for orders. They all accept your order and forward it to the manufacturer who actually ships it direct to you. Inventory status is often hours or days old when listed on the website and is rarely correct.
    I recently ran into the same issue. Website said “in stock”, I placed an order, the email confirmation said 3 week delivery. I was disturbed but I actually received it in one week.
    You just have to be patient.
    steelevo[QUOTED] likes this.
  12. Apr 6, 2023 at 8:41 PM
    HazOpRed
    HazOpRed 22' TRDOR
    Never had a problem. Roof racks are always on backorder. You shouldn't be surprised
    kolter45 likes this.
  13. Apr 6, 2023 at 9:28 PM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    I had this happen with another vendor last week. Needed a Jerry can holder for my roof rack by this weekend, so I called them before I bought to make sure it would be here in time. He promised it would. A week later, I called the manufacturer directly to ask about the order’s status, and they still didn’t have record of it. They had to call a regional rep to find that they were still waiting to receive my money from the vendor. Anyway, I canceled the order upon hearing it wouldn’t be here in time even if I ordered directly. But I learned a valuable lesson. Just buy direct in the first place, if a price looks too good to be true, it likely is.
  14. Apr 6, 2023 at 9:55 PM
    Ikooters
    Holy shit! I cannot believe how complacent you guys are with bad service.
    A supplier giving you a ship date and not meeting it twice is unacceptable. I don’t care if it’s 3rd or 4th party. Drop ship or in stock. Your complacency and the fact that you support these people is the problem. Maybe this isn’t the forum for me.
  15. Apr 6, 2023 at 9:58 PM
    Naw you're in the right place man it's an understandable reaction. I get pretty heated over nothing myself, I've just learned it is what it is with shipping in 2023
  16. Apr 6, 2023 at 10:04 PM
    I bought Dr. KDSS switch kit direct from California in March, British Columbia Canada mind you, got blasted with a bill of $110 CAD (UPS specific) bullshit border fees at my front door to release package. Now Dom - Dr. KDSS added that disclaimer on his website for us good ol Canadian folks. If it ain't one thing, it's another.
  17. Apr 6, 2023 at 10:05 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    The pandemic, worldwide shipping delays, and material shortages made it a new reality in today's world. Would be nice to have accurate info but the fact is, a lot of people don't know unless they manufacture 100% in house (which doesn't happen much anymore, everyone built a business being a middle man with markup). Even then, a raw material resource provider that doesn't hit their date causes a chain reaction
    asanner likes this.
  18. Apr 6, 2023 at 10:09 PM
    Ikooters
    Look I get the whole shipping thing. In my industry lead times have doubled. When I give an ETA I add two weeks just because I know what the situation is.
    I guess that’s just me.
    Fuck honesty right.
    Let’s just lie. They’re consumers and they’ll accept it because we tell them there’s supply issues. We’ll say we have it in stock but fuck them. They’ll buy it any way.
    erfer1, DadOperator and Thatbassguy like this.
  19. Apr 6, 2023 at 10:12 PM
    @Ikooters dude your exactly right, I've said that same kinda stuff! Their just like "fuck em", blame it on Covid and supply chain, make the sale.
  20. Apr 6, 2023 at 10:27 PM
    Ikooters
    All I’m saying is, be honest. Like I said, we’ve been hit with major supply chain issues my industry . I am up front with my customers. If my supplier tell me 24 weeks, I tell the end user 26-28 weeks. That way if there’s a delay, they’re prepared. I don't tell them an item is in stock and ready to ship. That’s why I have repeat customers. If that’s how 4runnerlifestyle wants to play the game, they’ve lost a customer.
    Obviously there’s plenty of fools to take my place.
    Justkelvin likes this.
  21. Apr 6, 2023 at 10:36 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Europification of the USA. New normal. Very unfortunate. It was a good run.
  22. Apr 7, 2023 at 9:31 AM
    Thats kinda how drop shipping works. They not in control of when Prinsu sends it out. Prinsu prolly behind.
    We get this shit all the time at work. Factory gives us a ship date and they miss it a lot.
  23. Apr 8, 2023 at 4:12 PM
    Their shirts r sick
  24. Apr 9, 2023 at 3:58 AM
    LadeDruck
    LadeDruck New Member
    2022 Pearl Effect White Ltd.
    This is common in most any manufacturing currently, up until Friday I was involved in the U.S. based oil/gas/steel manufacturing sectors. The promises are big and follow through terrible.
    Rago refused to honor a coupon, and rushed a label while ignore my cancel email.
    cali raised is known for quoting lead times they cannot deliver on (I am coming up on my 4th week for a Molle rack). With them I understand a bit more, but it’s deceptive nonetheless.
    the future of aftermarket support will favor those who can provide simple customer service.
  25. Apr 9, 2023 at 4:08 AM
    I get OP's frustration, if it's on back order....cool let me make my deciding to buy based on that. Because of this, i rarely use these 3rd party resellers. Most are more expensive anyways with extra mark ups from directly on manufacturer site.
    I know the lack of my piddly-ass sales won't hurt any business and make them go under. But we all work hard for our money and should expect a certain level of transparency and professionalism.
  26. Apr 13, 2023 at 9:48 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Bump
  27. Apr 14, 2023 at 12:50 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Whats there to bump in a thread like this?
    OK fine. Ordered several things. Mostlt no issue. Only issue was the blackout letters for the hatch had 1 wrong letter. Has to take them off or I would have had 1 silver letter. Could be mistaken but I thought I emailed them about it and got no response.
  28. Apr 14, 2023 at 10:40 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Just bought the rear black valence from them 2 minutes ago. Last week got a black shift knob. I think they're a pretty good outfit for the most part. Things ship fast and I get text alerts. Pretty sweet.
    Fishn43 likes this.
  29. Apr 14, 2023 at 4:32 PM
    Fishn43
    Fishn43 New Member
    2022 Barcelona ORP
    I just bought the front/rear black valance set. Hope it gets here within the next 4 1/2 weeks because I’m moving! :D
    Daddykool likes this.
  30. Apr 14, 2023 at 5:03 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Just got an email today that they are back in stock so I would assume it shoukd be shipping.
    Fishn43[QUOTED] likes this.
