Any useful maintenance thread? With common torque specs, fluids, etc.
Discussion in '5th Gen 4Runners (2010-2024)' started by Trail Addict, Nov 25, 2021.
  1. Nov 25, 2021 at 6:02 PM
    Trail Addict
    Trail Addict [OP] Professional Driver on a Closed Course
    2022 4Runner TRD Pro
    Just picked up a 2022 4Runner TRD Pro. I know I can read the old boring manual, but I would rather there be a thread I can find here like for forums of my other vehicles with all the common maintenance info like common torque specs, fluids, etc. I am coming up short on my search.
    Han4Run likes this.
  2. Nov 26, 2021 at 3:57 AM
    Han4Run
    Han4Run New Member
    2019 4Runner Pro
  3. Nov 26, 2021 at 9:24 AM
    OneWhoWonders
    OneWhoWonders New Member
    Rotors/Calipers/ Breaks-
    12mm
    17mm
    19mm
    Front brakes - every 5k or 6 mo for visual; every 30k or 36 mo for measurements
    Torque specs:
    Brake caliper mounting bolts - 91 lb-ft (19mm)
    Tips:
    1) Measure runout 10 mm from outer edge of rotor; rotor should be installed with all 6 lug nuts torqued to 82 lb-ft when checking
    2) If runout > max, check bearing play and axle hub runout normal before replacing rotors
    3) If rotor stuck on hub, use an M8-1.25 bolt in holes on rotors to break it free
    4) Install new rotors in position with least amount of runout
    Rear brakes - every 5k or 6 mo for visual; every 30k or 36 mo for measurements
    Torque specs:
    Brake caliper mounting bolts: 74 lb-ft (17mm)
    Brake caliper slide pins: 65 lb-ft (17mm)
    Tips:
    2) If runout > max, check rear axle shaft before adusting/replacing rotors
    Breaklines
    10mm
    Torque specs:
    Bleeder valve - 11 N-m/8 lb-ft (Front - 10mm deep; Rear - 10mm short)
    Tools:
    I like this bottle, but don't rely on the magnet, set it on something
    Tips:
    1) Make note of initial brake fluid level
    2) Don't let reservoir get low which would let air in system
    3) Sequence is FR, FL, RR, RL
    4) Ignition switch has to be in ON for both front and rear
    5) Fronts require cycling the brakes repeatedly to flush fluid (depress/loosen/tighten/release/repeat)
    6) Press and hold brake on rears and allow pump to push fluid continuously
    7) If bleeding air (and not just replacing), the FSM states that Techstream is required
    8) Leave brake fluid level same as initial level
    9) Will want a 10mm open-end wrench or 10mm offset wrench for the fronts due to the angle
  4. Aug 23, 2022 at 6:34 PM
    You are fine. I still know guys using impacts to tighten that shit.
    No thread lock.
    Also I use anti seize on the back of the pads and the grooves they slide in to prevent squeaking. Not sure if it does but thats how I was taught so I keep doing it.
    RingSteel likes this.
  5. Aug 24, 2022 at 4:20 PM
    xyzzy
    xyzzy New Member
    At the lake
    2019 Barc. Red TRD ORP
  6. Aug 24, 2022 at 4:54 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    my 2016 runner in july 2016 ..in nov 2016 I changed the eng oil ...then inspect the drive train fluids ..
    the rear diff is a gray color and the oil is some particles in it ..so changed it ...well the drive trains fluids 40K miles the fluid did very clear good ....
    when in NOV 2018 I changed the engine oil sn plus ... MPG previously 17 MPG .. changed SN PLUS 20 MPG......
  7. Jul 27, 2023 at 9:07 AM
    jrbevis
    jrbevis New Member
    2018 Off Road premium
    Hi guys,
    Can I safely assume these numbers would apply to a 2018 Off-Road Premium?
    Thx
