Antifreeze in oil (new moter)
Discussion in '1st Gen 4Runners (1984-1989)' started by Coloradobrown911, Aug 26, 2021.
  1. Aug 26, 2021 at 10:51 AM
    Coloradobrown911
    Coloradobrown911 [OP] New Member
    1988 Toyota 4-Runner
    I just got everything together,started it up to put antifreeze in and filled it up then it started coming out the exhaust pipe,I have to have a hose backwards but can't find it,anyone knows what I can try? 1988 4Runner 22re
  2. Oct 8, 2021 at 10:53 PM
    thedingo5
    thedingo5 New Member
    austin
    Did you just get done doing a head gasket?
  3. Oct 9, 2021 at 11:48 AM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Sounds like a head gasket to me.
    I have feeling that you need to pull the head off. Either the head isn't torqued on sufficiently, it was torqued out of order, the head or the block had a piece of something still on when the gasket was placed, the head or block are warped, or the gasket was damaged while installing it. Or the head is cracked. I got a new head for my 87 4Runner, when a friend of mine blew the factory head, that was cracked to start out. Brand new, fresh for the manufacturer, it had a visible crack halfway across it.
    Any of those would do it. I am going to presume you used a new gasket, so that isn't a consideration. Did you use new head bolts? Not necessarily essential, but I've read it's a good idea on GP. Are you certain the gasket is on right side up? Did you check the head and block, both, with a known-good straight edge to ensure they are within spec as far as flatness goes? "New" is no promise of "Good", as I showed above.
    To my knowledge, there is no hose you can put into the wrong place to do what you're seeing. The cooling system is pretty isolated from the cylinders, oil system, and exhaust, other than at the head/block interface. I would start looking there. Or, the oil/coolant can mix if there's an oil cooler feed into the radiator that has broken inside the radiator. I don't believe it would come out the exhaust, though. Usually, it's the automatic transmission that has a feed through the radiator, though. I just saying that it might have an odd mod on it that runs oil through the radiator. Unlikely, but possible.
    Anywho, let us know what you find!
    Pat☺
    negusm likes this.
  4. Oct 9, 2021 at 3:20 PM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    been there..done that....and had to correctly install another 'new' gasket. it's a party, I hated to attend....lol
    PhantomTweak likes this.
