Antenna Mounting
Discussion in '5th Gen 4Runners (2010-2024)' started by 1SilverRunner, Apr 2, 2024.
  1. Apr 2, 2024 at 8:54 AM
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    After quite a bit of searching and no luck I figured I'd ask the group!
    Where do you guys mount your antennas? I ordered an MXT275VP4 with a ghost antenna. I want to mount it on the hood to minimize how much wiring I have to mess with. (I realize this is not a perfect location... but from my understanding it should still work well enough)
    I pulled this image from midland's website. Does the Ghost antenna come with this mount or will I need to buy it separately?
    I do not have ditch lights or I'd buy the ditch light/ antenna mount combo mounts.
    https://midlandusa.com/products/micromobile-mxta25-3db-gain-ghost-antenna
    BantamEddy likes this.
  2. Apr 2, 2024 at 9:42 AM
    If I could I would 100% fix it at the highest point of my vehicle. Sadly it doesn't clear the garage, so I install it on the lower bar.
    Me personally parking in public places here in Denver CO I would never mount it near the hood as I'm pretty sure someone will steal it as it require no tools to remove.
    My previous antenna had a fixed wire and unlikely be stolen.
    jdm-v35 likes this.
  3. Apr 2, 2024 at 10:28 AM
    Forgot to answer this.
    Ghost antenna don't come with anything. It's just the antenna. This is what I had to buy.
    Antenna - https://amzn.to/4cFOcwi
    Wire - https://amzn.to/4cUpfxB
    Mount - https://amzn.to/3TYHBWD
    If you want the universal lip mount then all you need is lip mount + antenna.
    Lipmount (with wire) - https://amzn.to/4cDXl8K
    kolter45 likes this.
  4. Apr 2, 2024 at 10:41 AM
    1SilverRunner
    Tejas
    Thanks @kmeeg those are great points!
    The VP4 bundle comes with those items. Although I don't think I'll be using the mount as it doesn't fit my roof rack. (LFD Cross Bars)
    I am trying to avoid running wires to the roof and using wire hiders but I will if I need to.
    I wish Midland would cite the mounts they show on their website. The one I pictured above is proving difficult to find. :facepalm:
  5. Apr 2, 2024 at 10:46 AM
    A common solution is to use a ditch light bracket.
  6. Apr 2, 2024 at 10:51 AM
    You can try the regular kit that comes with everything needed and see how it goes.
    https://amzn.to/3PKWzwO
    When you buy VP4 it adds more parts in addition to regular kit. All this time I had the regular kit. Both my install video and range test in city video is with the regular kit comes with MXT275.
  7. Apr 2, 2024 at 11:06 AM
    1SilverRunner
    Tejas
    @kmeeg Nice thanks!
    How do you like it?
    I'll just be using it to communicate with other vehicles in a convoy without burning through my handheld's batteries. Figured it'll be a simple solution for that.
    I couldn't justify the cost of the 575 as I'm not using this system for emergencies and didn't need the extra power. Plus I've read it has higher voltage requirements to work at the full 50 Watts.
  8. Apr 2, 2024 at 11:29 AM
    IMO MXT275 have way power power than whats needed to communicate with other vehicles in a convoy. My 4Runner and my friend's jeep has MXT275s and rest of the gang has handhelds charging via USB.
    I love the MXT275 as the package has everything needed. Just plug in to cigarette lighter, mount the included antenna on roof out through the rear hatch, you are ready to rock n' roll. You can even have the main unit under seat and just have the handheld piece visible. I'm very happy with MXT275.
    Here's the install video from my TRD ORP. As said the basic kit have everything needed. Later I moved the main unit under driver seat.
    https://youtu.be/YDXOgqfC_Ws?feature=shared
  9. Apr 8, 2024 at 1:35 PM
    1SilverRunner
    Tejas
    @kmeeg
    Just wanted to follow up and say thanks for the information and the install video!
    I decided to go with the MXT575 after watching your video.
    Main reason being I didn't want to occupy the front 12v plug and contend with wire tucking there. (Although you did this very cleanly)
    I was under the impression there was another twelve volt port in the glovebox, but there is not. And I don't really want to add one.
    I'd rather just hard wire the radio to the battery and keep the entire system hidden under the dash. Minus the mic of course.
    Returning my MXT275VP4 and exchanging it the the MXT575, +ghost antenna with the midland hood mount.
    A little bit more cost and littler more involved of an install.. but I like the fact that it's wideband and will also transmit at a higher power.
    ChessGuy and kmeeg like this.
  10. Apr 8, 2024 at 1:47 PM
    That is super cool. It would have crazy power. AWESOME....!!!!!:101010:
    Install ideas -
    I don't have an updated video.
    • But right now the main box is under driver seat.
    • Mouth piece is near transmission shifter mounted horizontally. Last time it was vertical but the mouth piece is too heavy and when 3M tape gets weaken it falls off.
    • Power is coming from behind the cigarette lighter, I used a wire tap to power wire and body ground.
    If you decide to power directly from 12V battery, I highly suggest to add a fuse and this low battery cut-off unit. Yes I personally have this unit for my full time power line.
    https://amzn.to/3xAMFHO
  11. Apr 8, 2024 at 2:07 PM
    I'm about to buy the same MXT575 with the ghost antenna as well. Please share pics of the install if you can. I am a bit unsure whether I can do this job or get some help.
  12. Apr 8, 2024 at 2:20 PM
    1SilverRunner
    Tejas
    Thanks!
    I'll likely have to mount the main box under the seat as well. Seems like many people can't find enough space under the dash for this unit.
    Good tip on the mic. I may go ahead and utilize the two screws it comes with instead of relying on the tape alone.
    The 575 comes with power cables with inline fuses. But no low battery cut off... I'll consider adding this as well in case I leave the radio on when the vehicle is off.
    The biggest pain here will be routing the cables and keeping everything as clean as possible. Should be fun
    kmeeg[QUOTED] likes this.
  13. Apr 8, 2024 at 3:21 PM
    1SilverRunner
    Tejas
    So the 575 essentially has an auto shut off if you wire it as described in the manual. Interesting.
    kmeeg likes this.
  14. Apr 8, 2024 at 3:26 PM
    1SilverRunner
    Tejas
    @kmeeg
    Can you send over a picture how you mounted the radio under the seat?
    Curious about that
  15. Apr 8, 2024 at 3:46 PM
    Here's a pic before I installed the ghost antenna. Nothing different other than the antenna cable. I'm just using velcro.
  16. Apr 8, 2024 at 3:53 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    OP it seems like you already figured out how you want to do this, but the mount you need is a basic NMO mount. If you already know you want it on the hood then the absolute most simple and probably the cheapest mount is a NMO trunk lid slip on / lip mount which mounts very well on the lip of the hood and tightens with two set screws. I have used these for years on various 4Rs and they are low profile and simple.
    There's enough room at the main harness grommet through the firewall to get not only the coax through, but an entire PL-259 or similar connector.
    1SilverRunner[OP] likes this.
  17. Apr 9, 2024 at 6:42 AM
    1SilverRunner
    Tejas
    @MeefZah Thanks!
    That's perfect.
    For clarity, which firewall grommet are you referring to here?
    Can you provide a picture or describe which harness grommet works best; and will I need to cut/drill an additional hole in this grommet?
  18. Apr 9, 2024 at 7:03 AM
    photo8 New Member
    TRD Off-Road
    Those "ghost antennas" aren't very good performers, so you'd want to get them up as high as possible (on the roof). Mounting this, or any antenna below the roofline will give you distorted radiation patterns.
    Ghost antennas are very narrow banded and have no gain. You'd have better performance with a 1/4 wave UHF "spike" antenna or one like this with a little more gain: EMFLX-M10003: MOBILE, 3 dB Gain - UHF 420-470 MHz - W/ Poly Spring & B – Arcadian - ArcAntenna.com.
    Also, use a quality NMO mount. Midland mounts aren't that great. Buy the EMWave mount or one from Pulse Larsen.
  19. Apr 9, 2024 at 7:06 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    This is a disjointed explanation but...
    If you sit in the driver's seat and then draw an imaginary line straight down your left femur and into the dash and then the firewall, the grommet is right there. It supports a wire bundle that is like 1.5" diameter and there is a fair amount of room to the outside of that bundle to notch a hole and then poke the coax through.
  20. Apr 9, 2024 at 7:15 AM
    1SilverRunner
    Tejas
    Thanks I'll keep that in mind. I'll just be using this mainly for vehicle convoys on the trail so it I'm hoping it will work well enough. If I have trouble with midlands NMO mount, antenna, or interference I will move the antenna to the roof. Possibly upgrade the antenna as well.
    For now I will keep this system as low profile as possible as it should still work well enough for my use case.
    Beautiful thanks again!
    MeefZah[QUOTED] likes this.
  21. Apr 9, 2024 at 9:37 AM
    doublewide
    doublewide ShittCo
    TRD OR PREM
    I went that route.
  22. Apr 13, 2024 at 2:34 PM
    @OP, &
    1SilverRunner,
    and others....thanks for this thread and the comments. I got some courage finally and decided to do it. I really appreciate all the comments and reviews which helped me greatly doing this job.
    Ripper238 and kmeeg like this.
  23. Apr 13, 2024 at 7:16 PM
    LetsTacoboutit
    Adobe
    Don't take that thing through any car washes without removing the antenna. You should keep a twist on dust cap on there and only deploy the antenna while needed.
  24. Apr 13, 2024 at 7:33 PM
    I'm pretty sure people who love their vehicles do not take them to car washes with brushes or those cloth strip things ones. I go to touch less car washes and didn't even remove the weaker stock antenna came with my MXT275.
  25. Apr 14, 2024 at 8:38 AM
    LetsTacoboutit
    Adobe
    Sorry but that sounds effete as hell after taking it to the monte and thrashing it through brush, huisache, etc. Yeah I love my 4runner but I am not going to marry it. Cloth strips are the least of your worries unless you plan on showing it at the Concourse d' Never Used in 70 years.
    MeefZah and kmeeg like this.
  26. Apr 14, 2024 at 8:52 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Nice! Almost exactly what i did.
    Got a little creative with my sons erector set parts for the mic mount. lol
    ChessGuy[QUOTED] likes this.
  27. Apr 17, 2024 at 12:34 PM
    Hi everyone. I have the Midland Ghost antenna and the low-profile NMO cable and have some questions about mounting. I intend to mount it to a CaliRaised ditch light bracket. Like this:
    The hole in the ditch light bracket is perfect for the center post of the NMO fitting.
    Here’s the snag. The cable also comes with this little plastic piece. Are we calling it a spacer? Or an insulator?
    If the plastic piece is a spacer, can I omit it entirely? If it’s an insulator does that mean I have to drill out the hole in the ditch light bracket to accommodate it? And if the latter is the case, do I mount it with the flange on top or on bottom?
    Thanks for your help
  28. Apr 17, 2024 at 1:07 PM
    It is an spacer IMO. I removed it out of mine. For as long as the antenna is properly screwed in, I don't think you will have any issues. Maybe others might have a different opinion.
  29. Apr 17, 2024 at 2:17 PM
    Kudos to Midland —
    Immediately after submitting my post above, I copied it into an email to Midland Support. I posted here first because one can usually get an answer to a question pretty quickly, while vendor customer support can take days or even weeks to get a reply. My question got a response from @ChessGuy in 33 minutes. (Thank you sir.) I received an automated message from Midland right away, but the actual response containing the answer to my question came just 46 minutes after I sent my email. I found that to be impressive.
    The answer: It’s a spacer and can be omitted.
    Midland even included this nice, well labeled and totally unambiguous drawing.
  30. Apr 18, 2024 at 9:07 AM
    jake long15
    jake long15 Cali Raised LED
    If you still need help please reach out to our customer service team at info@caliraisedled.com and they can assist you :)
