Antenna mast??
Discussion in '3rd Gen 4Runners (1996-2002)' started by SR5 Limited, Nov 22, 2019.
  1. Nov 22, 2019 at 1:48 PM
    SR5 Limited [OP] New Member
    Here’s my dilemma. Clipped a roadside sign. Don’t ask how. I slowed down, car was coming the other way, and “smack”, bent antenna. It was out in the road too far, guys picking up trash. So anyway, easy fix right? I pulled the old one out after removing the nut and jewel. Easy peasy, well I put the new one in it went down two inches and locked up? Then I couldn’t get it out. So I figured I would loosen the housing screws. And it retracted all the way. But there was a grinding sound, for a few seconds, before the relay kicked off. So I figure I can live with that. Then today it wouldnt go up, I thought great. So pulled it apart and sure enough the ribbon was broke, again. Gear looks good. I lubed it and will try again. 17 bucks a pop, I will give it one more try.....
  2. Nov 22, 2019 at 2:14 PM
    Found a replacement for ten bucks, but I think I’m gonna ditch the power antenna and get a 6 1/2 incher that is compatable and I don’t have to mess with the motor housing..
  3. Nov 22, 2019 at 3:13 PM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    That's what I did on mine. Got a "TRD" one off eBay. It took a little to get it to fit but I think it's because it's kind of a piece of shit. Looks cool though haha
    4Runner fun likes this.
  4. Nov 22, 2019 at 3:24 PM
    Well turns out the eBay seller refunded me the original 17 bucks so they are sending another for free. I’m a happy camper...
  5. Nov 22, 2019 at 3:25 PM
    I like the length of the stock antenna and don’t get good reception until it’s over half way up.
  6. Nov 27, 2019 at 12:58 PM
    Tried another factory aerial. It went up fine, then when down a hideous grinding sound. So I trimmed it, still did it, trimmed some more. Then it wouldn’t go down. “Helped” it go down, it grinded and broke the ribbon, again. So I have a 7 incher with the adapter that goes down in the housing. Hope I still get my classic rock....
    SlvrSlug likes this.
  7. Dec 3, 2019 at 1:26 PM
    619D0095-7507-45F2-B29A-FC722128C53C.jpg Well seems I have just as good reception. 60 bucks...:annoyed:
    SFT4R1 likes this.
  8. Dec 9, 2019 at 1:31 PM
    I've replace my retractable antenna twice over the years and you need to make sure all pieces of the old antenna are out of the motor. You may have some piece stuck in there?
    When I did it, I double checked to make sure the old pieces were exactly the same length as the new one.
    I also only used Toyota antennas.
  9. Dec 9, 2019 at 9:06 PM
    I kind of like it. I’m into R/C cars and boats which have shorty antennas. It adds character...And I get reception instantly...
  10. Dec 20, 2019 at 6:43 PM
    Yodaforce
    Yodaforce New Member
    Matt
    1997 4Runner SR5 5-Speed
    Finally replaced the busted motorized one. It had about a foot or so of old nylon coil stuck in the motor gearing.
    To me, its 150% satisfying to watch the power antenna extend on a 22 year old truck. Reception is great.
  11. Dec 20, 2019 at 7:38 PM
    Blocks the view if you ask me. The antenna technology has grown since.
  12. Dec 29, 2019 at 9:43 AM
    Rallypoint_1
    Rallypoint_1 New Member
    Bill
    Pasadena, California
    98’ Evergreen Pearl 4Runner
    4.56’s Yukon Grizzly locker(rear)
    I had the power antenna work up to 2 months ago. It stopped going down...stuck in the up position. Made noise anytime you turn the ign on. Removed it and did the Taco whip mod. Kinda pricy for the parts but I like the simplicity of it.
  13. Jan 17, 2020 at 11:07 AM
    blurcardi
    blurcardi New Member
    This is what I want to do. How?
  14. Jan 17, 2020 at 12:37 PM
  15. Jan 21, 2020 at 2:32 PM
    You can buy the replacement telescoping antenna from Toyota for that price.
    Antenna Mast 86337-35111 1 $55.76 Shipped
    McGeorge Toyota on-line sells them.
    16runnerblue likes this.
  16. Apr 16, 2020 at 9:04 AM
    DesertRoads
    DesertRoads New Member
    Utah
    Silver '99 4Runner Limited
    HVAC tape over the holes in the glass headlights
    Stubby antenna's are known for poor reception. My power antenna is dead too, but I keep using it as it's not broken. Hopefully you find something that works for your needs.
  17. Apr 16, 2020 at 9:23 AM
    Actually this one gets good reception. It was expensive for a stubby aerial...Must have a lot of copper in it...
  18. Apr 16, 2020 at 9:41 AM
    DesertRoads
    Utah
    Definitely must. Copper is key. I usually rebuild my antenna's to include lots of copper in them. I've used CB antenna's as radio antenna's as I want the better reception.
  19. Apr 16, 2020 at 11:29 AM
    I do get bad interference when my cell phone is charging......
  20. Apr 17, 2020 at 11:25 AM
    Ace115
    Ace115 New Member
    Andrew
    2000 T4R 4x SR5
    Hey guys. I’m brand new here and have a lot of questions about a new to me 2000 4runner. My antenna is broken. I use one of the cheap AutoZone specials on a Tacoma a few years ago and it worked fine. Will that not work on the 4runner? Also how do it get all of the old antenna out?
    thanks in advance to anyone that can help.
  21. Apr 17, 2020 at 12:18 PM
    If the width/length of the mast and the length of the plastic teeth are EXACTLY the same as the 4Runner's, I don't see why not.
    With mine, I think I just turned on the radio and it puked out the old section. But it was long enough to grab.
    If there was a tiny section broken off and is stuck in the motor, I am not sure exactly.
  22. Apr 17, 2020 at 1:46 PM
    More than likely, No. Notice the pic it has an adapter to slide down in the original housing. Without it you wont be able to secure the top with the jewel. It only has one bolt on the lower section to securing it. Unless you replace the whole motor with a new unit.
  23. Apr 20, 2020 at 12:15 PM
    Ace115
    Ace115 New Member
    Andrew
    2000 T4R 4x SR5
    Thanks all, so how do I take out the old parts?
  24. Apr 20, 2020 at 12:28 PM
    Step 1: remove the inner fender well bolts and bend the plastic forward. Like two bolts.
    Step 2: remove bolt holding aerial housing onto body.
    Step 3: remove jewel from top of the unit. Usually needle nose pliers will work.
    Step 4: Drink a Diet Coke and repeat backwards to install.
    Ace115 likes this.
  25. Apr 20, 2020 at 12:47 PM
    If you mean just replace the mast. Remove the jewel. Turn the radio on it will spit it out. Then put new mast in the hole and turn radio off it will retract and install jewel back....
  26. Apr 20, 2020 at 12:49 PM
    Then drink a Diet Coke.....
  27. Apr 21, 2020 at 7:18 AM
    Make sure you compare the old plastic teeth with the new one. If they are not the same length, you have a piece stuck in the motor. If you cut the new one to the same length, you will just destroy the new one.
  28. Jun 1, 2020 at 6:39 PM
    John Riggins
    John Riggins New Member
    Baby 2001 4runner
    pretty much stock minus fender flares and running boards
    Yep, I bought a 14 inch black whip antenna, couldn't be happier.
