Another leveling thread
Discussion in 'Suspension' started by Gstick, Oct 23, 2021.
  1. Oct 23, 2021 at 1:33 PM
    Gstick
    Gstick [OP] New Member
    19' TRD OFF ROAD
    I am looking for a mild 1.5"-1.75" (MAX) front lift to level out my 19' TRD OR. I'm not sure whether to go with the 5100 Billies, or go with new struts/shocks & new coil springs front/rear. I don't haul heavy & I am not a hard core off roader. The maximum height tire that I will run is a 32" (255/75/17). Considering Dobinsons, OME, or Ironman also. Been researching alot & I am concerned with the QC of the Ironman. Any opinions ?
  2. Oct 23, 2021 at 1:55 PM
    Mtbpsych
    Mtbpsych New Member
    Plenty of people run those setups here, they all have their pros and cons. Just comes down to what your use will be and what you’re willing to pay. From what I’ve seen, Ironman has great customer service and products.
    Roland likes this.
  3. Oct 24, 2021 at 4:14 AM
    We run a RevTek kit with stock shocks in the front, and the RevTek supplied shocks in the rear, along with JBA control arms in the front. They, (RevTek) have lots of different options as far as lift/leveling height, we had the dealer install the lift/leveling kit, that was supplied with diff. drop also. Just another option, we do not do a lot of "heavy" off-road either, just enough to get a "taste." BTW, we run 275-70-17's20201222_095107[702]JBA UCA.jpg
  4. Oct 24, 2021 at 6:39 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    FWIW - Kit availability may come into play. At least a couple of kits I've researched are on backorder well into next year.
    Roland and Mtbpsych like this.
  5. Oct 24, 2021 at 6:45 AM
    For your uses, I would just get some adjustable shocks and keep your stock coils.
    That's what I did and it was inexpensive and works great!
    I went with Eibach adjustable front shocks because I thought they rode better than the bilstein 5100's.
    Toy4X4, SlvrSlug and Roland like this.
  6. Oct 30, 2021 at 5:34 AM
    Gstick
    19' TRD OFF ROAD
    Thanks for that recommendation ! I will look into the Eibach adjustable shocks.
    nimby[QUOTED] likes this.
  7. Nov 2, 2021 at 8:39 PM
    Xombie2000
    Xombie2000 New Member
    2016 4RUNNER trail
    Checkout the forums for cornfed suspension. I got 1.5” in the front. It was easy to install.
  8. Nov 3, 2021 at 4:37 AM
    dolbytone
    dolbytone New Member
    2020 TRD Off Road
    Is leveling just a do what I want thing or is there an actual reason to level your truck?
  9. Nov 3, 2021 at 5:17 PM
    Gstick
    19' TRD OFF ROAD
    Thanks, but I don't want to do a spacer lift.
  10. Nov 4, 2021 at 7:13 PM
    Also, Toytec sells a 1.6" front lift coil for our trucks.
