Analysis Paralysis...will the stock TRD rims fit on a 285/70/17 tire?
Discussion in 'Wheels & Tires' started by BGB_SharkDiver, Jan 22, 2021.
  1. Jan 22, 2021 at 5:50 PM
    BGB_SharkDiver
    BGB_SharkDiver [OP] New Member
    Brandon
    2018 Toyota 4Runner TRD Off-Road Premium
    Lol. Velcro patches on trim above glove box. Stickers on inside of lift gate. More $ on mods soon, that is why I'm joining this forum...
    Would prefer to keep the stock TRD wheels that came with the 4runner. Would like to get Raised White Lettering on new 285/70/17s, seems that only the BFG KO2 offers RWL in 285/70/17.
    • Will the stock TRD rim that came with the 265/70/17 fit a BFG 285/70/17?
    • Without any unnatural spacers etc? Anybody doing this?
    Longtime lurker since buying my 2018 Off-Road Premium Aug '18. Have spent far too much time looking at options trying to educate myself; and enjoy the forum.
    Looking to put slightly bigger tires than the stock 265/70/17 Nitto Grapplers, and maybe a 2-3" lift if I can ever decide on which manufacturer to go with.
    Appreciate any thoughts or comments!
  2. Jan 22, 2021 at 5:51 PM
    Mtbpsych
    Mtbpsych New Member
    Yes and you might need a lift.
  3. Jan 22, 2021 at 6:04 PM
    BGB_SharkDiver
    Brandon
    Thanks @Mtbpsych ! That was a fast reply! The lift is coming. I figured I only needed tires + lift but the shop I'm talking to quoted me wheels and is saying they're needed to make it all fit.
    Maybe its b/c I'm not that into wheels, but to me the stock wheels are just as cool as any of the aftermarket rims I see around. So for the extra $900, I'd like to keep my TRD wheels if they'll work.
  4. Jan 22, 2021 at 6:15 PM
    Mtbpsych
    Mtbpsych New Member
    You could make those stock sema style wheels fit with the 285’s! I’ve seen multiple builds with that setup on Instagram and what not so I don’t see why it wouldn’t work! It is on the thinner side of wheels, so maybe someone else can chime in. I’m sure in order to be 100% safe and for liability on their end, they won’t put it on as I think it’s a 7” wide wheel.
  5. Jan 22, 2021 at 6:57 PM
    I have been running mine for a couple years with no problems whatsoever.
  6. Jan 22, 2021 at 7:51 PM
    BGB_SharkDiver
    Brandon
  7. Jan 22, 2021 at 8:24 PM
    OpBalance
    OpBalance New Member
    Yes you can. They’re 7” wide wheels, and 285/70’s aren’t recommended for 7” wheels, which is why most chain tire shops won’t do it. But people have been running 285’s on the TRD Pro wheels for 5 years now with no issues.
    if you are going E rated tires anyway, then get 275’s in the KO2’s and lift later. If not, you’ll need some minor trimming and a lift for the 285’s
  8. Jan 23, 2021 at 7:59 AM
    kmeeg LionRunner
    Is yours a 2018 TRD Offroad Premium? Do you still have your TRD Offroad wheels?
    TRD Offroad wheels meet the requirement to mount 285/70R17 tires.
    Yes since TRD Pro wheels are skinny they are not recommended for 285/70R17.
    If you want to keep TRD Pro wheels you don't have to settle for 275/70R17. You can go for a taller tire like 255/80R17.
    As far as I've seen 255s only got Load E, so onroad comfort would be compromised. In 275s you can have something like a Falken Wildpeak Load C. One of my buddies have them and it's good onroad.
  9. Jan 24, 2021 at 8:43 PM
    BGB_SharkDiver
    Brandon
    Thanks @kmeeg and yes mine is a '18 ORP. Original tires/wheels are on it (pic in post at beginning of thread). From your and others comments it seems the risk is that the stock TRP rims are on the narrower side, apparently 7", and most on here are saying that 285s "need" a rim that is 7.5" at the lower end of narrowness.
    So, while doable, what is the issue posed by a narrower stock rim of 7" on 285s?
    Is it a matter of fit on the vehicle, or an issue w/that narrower rim becoming a big problem if you go to air down and drop tire pressure?
  10. Jan 24, 2021 at 9:38 PM
    kmeeg LionRunner
    Just want to clear few things;
    1. According to the first pic on the post, looks to me that is a TRD Pro wheel. Not a TRD Offroad wheel.
    2. I do not know what is the reason why tire manufacturers state 7.5" minimum width wheels for 285/70R17. Not sure if it will loose a bead at low air pressure or for some sort of safety factor. I'd suggest you check the specs from the tire manufacturer site, not what tire seller tell you.
    3. Atleast fitment wise both my TRD ORP and Limited 285/70R17 did not rub on stock UCA or SPC UCA. I don't use any wheel spacers. My Limited has 2.5 lift front with stock UCA and 1.5in lift rear. My TRD ORP has 3in front with SPC UCA and 2in rear. On both of them I had rubbing on inner fender liner so I had to push that plastic forward.
    BCAkgZ5sb8svhgfu1Ja6Dvj4PnqCuYZmc-hHE8jj_0c6ced1471cff06905bd3b25630c336b1e4002ef.jpg
    hrm4wxwwSYm_xzI1oB9NJIJusioGggJBEFvqopnw_7b4049548f9409e671d860792b662eedfe057671.jpg
    I'm not at all trying to say TRD Offroad wheels are the best for 285/70R17 tires. All I say is it just meet the minimum requirement by tire manufacture.
    Anyways I'm not an expert. I'm just a user just sharing my experience.. :)
    blackcloud08 and jester243 like this.
  11. Jan 25, 2021 at 10:25 AM
    Tuco S.
    Tuco S. New Member
    I just had some E load 255/80R17 Toyos installed, and the on-road comfort is actually quite awesome. Stock suspension, no lift (yet).
    A lot of guys run 285/70R17 on Pro rims even though at 7" wide they are supposedly too narrow per tire manufacturer recommendations. As far as I understand it, the problem running that size on Pro rims is that they have enough offset to cause rubbing even with a lift in many cases. OR/Trail rims are 7.5" wide but aren't offset as much, thus less likely to rub.
  12. Jan 25, 2021 at 11:26 AM
    BGB_SharkDiver
    Brandon
    @kmeeg - Fantastic feedback, thank you. Appreciate the coaching and pointing me to those sites and the data.
    @Tuco S. - thanks for the feedback.
    Appreciate those chiming in, interesting to learn!
    :cheers:
  13. Jan 25, 2021 at 12:28 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    I have them and no issues.
  14. Jan 25, 2021 at 12:48 PM
    OpBalance
    Hi jacking thread: how many threads are you showing in your coil overs?
  15. Jan 25, 2021 at 1:07 PM
    Daytonaviolet
    Bay Area, CA
    rears seem high as it’s in drive way. I did 6 turns on drivers side and 5 turns on passenger. 23.5” fronts and 24” rears.
    jester243 likes this.
  16. Jan 25, 2021 at 1:12 PM
    BGB_SharkDiver
    Brandon
  17. Jan 25, 2021 at 3:27 PM
    OpBalance
    Yeah I know, was just curious. I’m 6 on both sides, drivers settled .5”. Looking at what to bump them up to, maybe 10/8? Thanks for the info
    Daytonaviolet[QUOTED] likes this.
  18. Jan 25, 2021 at 3:51 PM
    Daytonaviolet
    Bay Area, CA
    What’s your rears like ? 2”?
    I think 10/8 will fix the lean. 2.5 turns should be 1/2” which you want.
  19. Jan 25, 2021 at 4:19 PM
    OpBalance
    Yeah 2” rears. I kind of dig the rake, but feel like I could get away with fixing the lean and going up a little more and still maintain some slight forward rake.
  20. Jan 26, 2021 at 6:54 AM
    BGB_SharkDiver
    Brandon
    Do any of you guys that move from stock 265s to 285s and a lift; experience a noticeable difference when you're sitting higher/more top heavy?
    Does it feel less secure or annoyingly top heavy?
  21. Jan 26, 2021 at 6:59 AM
    OpBalance
    Come on man, you literally gain 0.5” of height from 285’s. And the lift does not make it top heavy. At some point you need to just start doing and stop over thinking. These forums can get counterproductive to a point.
  22. Jan 26, 2021 at 7:02 AM
    BGB_SharkDiver
    Brandon
    I'll concede the point as this is a known developmental area for me. Truth is, I was ready to pull the trigger and then my best friend threw a wet blanket on all my ideas telling me to leave it stock and blah blah blah. Appreciate all the feedback.
  23. Jan 26, 2021 at 7:03 AM
    OpBalance
    I’m just saying that sometimes too much info is counterproductive. Lift your 4Runner and enjoy it!!
  24. Jan 26, 2021 at 7:07 AM
    kmeeg LionRunner
    All 3 of my 4runners lifted. I lift when they are factory fresh. I like a mild lift and 285/70R17s. They look soo good than stock 265s to me personally.
  25. Jan 26, 2021 at 7:32 AM
    Not at all, you will love the way it feels with new suspension, it performs on road much better than stock. It will not have the excessive lean in turns, and will get rid of the nose dive on braking. Off road goes without saying.
  26. Jan 26, 2021 at 11:03 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Yeah these are all intelligent lifts. Go put a 5 inch lift on though, and that's a different story.
  27. Jan 26, 2021 at 11:15 AM
    Daytonaviolet
    Bay Area, CA
    I think with 10/8 turns you’ll be 2” higher and fix the lean :)
    how are you turning the perch ? On the truck ?
